04-06-2010, 07:34 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | k810 i white screen blinking help CARD SERIAL 00128326 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35945101908003 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):K810i MAPP CXC article: R8BA024 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BA024 Language Package: S_ASIA_LEVAN CDA article: CDA102779/87 CDA version: R1A Default article: cxc1250813 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BA024_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100110000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35945101908003 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "H:\SE Flesh Files\k810\cid53\r8ba024\R8BA024_1250811_GENERIC_S M.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "H:\SE Flesh Files\k810\cid53\r8ba024\r8ba024_fs_america_2_sm_r ed_cid53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4180 Will flash 209 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed USERCODE RESET TO "0000" using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 865 secs. i flesh phone but not solve helpppppppppppp sir |
04-06-2010, 08:41 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
04-07-2010, 05:23 | #5 (permalink) |
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | RUNNING v 1.01/UNI CARD SERIAL 00128326 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35945101908003 CERT:N/A FLASH CID:53 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R8BA024 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BA024 Language Package: S_ASIA_LEVAN CDA article: CDA102779/87 CDA version: R1A Default article: cxc1250813 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BA024_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 12 secs. |
04-07-2010, 05:51 | #7 (permalink) |
Junior Member Join Date: May 2007
Member: 499599 Status: Offline Thanks Meter: 3 | boss info_tech did you ask the cutomer about what happen to the unit? anyway try this solution sometimes when the unit expirience water damage thats the thing will happen to your unit specialy ericson units! so i sudjest you need to open first the unit and clean it first in the inside using liquid solutions before you re program it try and tested by me! hope this will help you........ |
k1 white screen blink . please help me ..... | hamid123 | Smart-Clip | 11 | 04-07-2011 12:38 |
k810i white screen blinking-flashing ok-did repair tp-still set shows as k700 -help | zonetrichur | Sony Ericsson | 3 | 10-07-2009 07:13 |
K320 white screen blinking-help | zonetrichur | Sony Ericsson | 2 | 04-08-2009 07:55 |
k810 cid53 white screen | kb8to24 | Sony Ericsson | 4 | 08-09-2008 17:30 |
w810i sonyerixon logo blinking & then white screen blinking | cellindia1 | Sony Ericsson Hardware Repair | 4 | 07-02-2007 05:06 |
