09-01-2010, 14:19 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 617865 Status: Offline Thanks Meter: 111 | k810 strenge problem , anyboby have solution? here is log: SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R8BF003 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BF003 Language Package: S_ASIA_LEVAN CDA article: CDA102779/87 CDA version: R1A Default article: cxc1250813 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED any how , i see that it is cid52,so i flash it with different version of cid52(like:R8BF003 and other downgread version ).but when i identify it. it's detected as k700 everytime now please tell someone that , what is the problem and what to do for it ? |
09-02-2010, 07:43 | #4 (permalink) | |
Member: 617865 Status: Offline Thanks Meter: 111 | Quote: RUNNING v 1.085/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R8BF003 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BF003 Language Package: S_ASIA_LEVAN CDA article: CDA102779/87 CDA version: R1A Default article: cxc1250813 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:2B5FC6FB2380816325209EB6 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 16 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\gdfs_in_ssw_format\db2020\K810_GDFS_ SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "88171252" SIGNING... Elapsed: 43 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\eroms\db2020\DB2020EROM_CNV_RED52_BR OWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "63425462" SIGNING... Elapsed: 10 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K810i Brand:Generic MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KC001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KC001_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 3 secs. after write gdfs mobile is detected as k810 but still in white light blinking,so i reflash it.here is log SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "C:\Documents and Settings\sun\My Documents\Downloads\R1KC001_1250811_GENERIC_SM.ssw " CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "C:\Documents and Settings\sun\My Documents\Downloads\R1KC001_FS_FRANCE_SM_RED_CID52 .ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4180 Will flash 209 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 758 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R8BF003 prgCXC1250811_GENERIC_SM MAPP CXC version: R8BF003 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. after flash it again detect as k700, and the problem is as same as befor.isn't it strenge,now what to do ? | |
09-02-2010, 08:24 | #6 (permalink) | |
RUNNING v 1.085/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KC001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KC001_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:AF936D882380816325209EB6 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 15 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\gdfs_in_ssw_format\db2020\K810_GDFS_ SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "81384165" SIGNING... Elapsed: 42 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\eroms\db2020\DB2020EROM_CNV_RED52_BR OWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "25884450" SIGNING... Elapsed: 13 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K810i Brand:Generic MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KC001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KC001_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 3 secs. after this procces,i insert lcd and check what happen and the result is as same as befor,white light blink.and after this i identifi it and it again k700. see log here : CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35315302748002 ACTIVE CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KC001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1KC001_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 4 secs. is any idea ? | |
09-03-2010, 10:33 | #12 (permalink) |
Product Manager Join Date: Jan 2009 Location: Philippines Pure Pinoy Age: 37
Member: 943187 Status: Offline Thanks Meter: 584 | mates, i have same problem ive try replaced, replacement lcd shows only please wait then restart. but i try orig lcd it works for me...make sure your gdfs correct as k810... hope it helps... |
09-03-2010, 12:55 | #13 (permalink) | |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
