Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 10-13-2008, 16:23   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
>>> K810i Red Blink Repaired with TP <<<
SE K800i red blink has successfully been repaired by tp method. Thanks to Mr laser for the wonderful software...
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401231376 CERT:N/A
FLASH CID:52 COLOR:RED
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
PREPARING...
ATTACH TP #1 AND PRESS "READY"
RELEASE TP #1 AND PRESS "READY"
TP #1 LOOKS OKAY
DONE
Elapsed: 35 secs.
TESTPOINT REPAIR STAGE #2 STARTED
Open COM port OK
Speed:921600
ATTACH TP #2 AND PRESS "READY"
Trying to launch embedded bootloader...
TP #2 LOOKS OKAY
RELEASE TP #2 AND PRESS "READY"
INT LDRB2020_PRELOADER_FOR_SETOOL2
WRITING EROM...
DONE
Elapsed: 86 secs.
Open COM port OK
Speed:921600
FLASH CID:49 COLOR:BROWN
LDR:060721 1021 DB2020_SERVICE_LOADER
Flash ID check:897E
Flash props sent ok
writing D:\SE Tool\setool_v41\setool v41\gdfs_in_ssw_format\db2020\K800_GDFS_SSW.ssw
CURRENT FLASH FILE CID:49
SSW uses complete hash, hash len is:640
Will flash 32 blocks...
SSW loading returns:0
Setting up GDFS...
OTP WRITE NOT EXECUTED.
Writing simlocks...
ALL UNLOCK/LOCK CODES SET TO "27635862"
Signing...
control keys complete.
full sig complete.
Elapsed: 53 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
writing D:\SE Tool\setool_v41\setool v41\eroms\db2020\DB2020EROM_CNV_RED51_BROWN_CID49_ DB2020.ssw
SSW uses complete hash, hash len is:80
Will flash 4 blocks...
Setting up GDFS...
Writing simlocks...
ALL UNLOCK/LOCK CODES SET TO "71748325"
Signing...
full sig complete.
Elapsed: 16 secs.
The Following User Says Thank You to zeel_zeel For This Useful Post:
Old 10-13-2008, 22:43   #2 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thank you For sharing
...so can you post any video how to repair with tp or explaine what porcedure to repair with Tp ..
B.R,
Tétouan Gsm
Old 10-14-2008, 14:52   #3 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
B.R,
Tétouan Gsm
Here is the procedure >>>>
1. it is only and only for professionals.
users,advanced users, please "go away".
2. testpoint is +3.3 voltage, connected to specific pin.
we suggesting to use +3.3v battery
(battery ground MUST be connected with phone's GROUND)
3. go to emptyboard fill & repair.
4. select any db2020 model.
5. press "TP STAGE #1". read instructions and execute them.
6. press "TP STAGE #2". read instructions and execute them.
7. phone is BROWN now.
8. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format.
9. if flashing went fine, flash db2020 erom with needed CID.
10. phone now retail and repaired. fullflash phone as usual.
testpoint pictures (courtesy of drea_mbox team) included.
after SETOOL2 db2020 testpoint procedure phone FULLY
working in "alternative security bypass" mode without ANY restrictions.
Testpoint pics can be found in setool folder...
The Following 3 Users Say Thank You to zeel_zeel For This Useful Post:
>>> Test Report >>> W580i Red Blink Repair w/o TP >>>> Free >>>> zeel_zeel SETool2 26 11-17-2010 18:59
K800 Red Blink Repaired via TP adnanskyland SETool2 17 02-11-2010 17:13
>>> SE K610i Red Blink Repaired with TP <<< zeel_zeel SETool2 0 10-08-2008 18:11
k800i red blinking repaired with dbss v3.4 alfox DreamBox 0 04-22-2008 09:05
w580i red blinking repaired with dream alfox DreamBox 0 04-14-2008 11:14
Page generated in 0.36688 seconds with 11 queries
