05-29-2014, 09:30 | #1 (permalink) |
Junior Member Join Date: Feb 2007 Location: Perm
Member: 452521 Status: Offline Thanks Meter: 3 | lenovo k900 cant restore imei Code: 16:45.671 To connect to the handset it should be rooted first 16:45.671 You can make it manually or by LgeTool (only Android 4.0.4 version supported). 16:45.671 Adb interface should be enabled in the handset 16:45.671 <B>LGE Tool version:</B> 2.36 16:45.687 <B>OS Version:</B> Windows XP [NT 5.1] Service Pack 3 16:45.687 <B>Administrative privileges:</B> yes 16:45.687 <B>Locale:</B> RussianFederation / Russian 16:45.687 <B>CPU frequency:</B> 3292 MHz 16:45.687 <B>Total memory:</B> 2986 MB 16:45.687 <B>Free memory:</B> 1020 MB 16:45.687 <B>Free space on system disk C:\:</B> 6.00 GB 16:45.687 <B>Free space on disk D:\:</B> 39.00 GB 16:45.687 <B>Free space on disk E:\:</B> 15.00 GB 16:45.687 <B>Free space on disk F:\:</B> 202.00 GB 18:22.968 Connecting with <b>K900</b> 18:22.984 Waiting for device... 18:23.468 Device Found: Medfield67B30B25 18:29.015 sending psi (size 98304) ... 18:37.593 sending ebl (size 193056) ... 18:54.468 ebl version XMM6360_1312.300_M1S1 protocol version 1 18:54.468 boot success 18:54.468 Connected 18:54.468 Receiving phone info 18:54.953 Device Found: Medfield67B30B25 18:54.953 Dumping nvm ... Code: 54:31.156 Connecting with <b>K900</b> 54:31.171 Waiting for device... 54:52.703 Device Found: Medfield67B30B25 55:08.046 sending psi (size 98304) ... 55:16.515 sending ebl (size 193056) ... 55:33.390 ebl version XMM6360_1312.300_M1S1 protocol version 1 55:33.390 boot success 55:33.390 Connected 55:33.390 Receiving phone info 55:33.906 Device Found: Medfield67B30B25 55:33.921 Dumping nvm ... 55:37.812 Error: Common: Internal error: Question: Is it possible to solve my problem with restoring IMEI? |
09-16-2014, 11:35 | #2 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2224016 Status: Offline Thanks Meter: 0 | i got the same problem with you so my curiousity was here, is this software cant work for k900 or what? because i had run software and also rooted the device already. but also facing the same problem while the software running till dumping nvm then the whole thing goes error..... so whats wrong with it? |
