05-08-2012, 14:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | w20i server error SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 48, UNLOCK 212 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01238200956368 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 17 secs. |
05-09-2012, 06:04 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | CID 80,81 if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. you can not unlock last SEMC A2 phone ( j108 ) with CSCA method. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
