Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-15-2014, 02:39   #1 (permalink)
griff26's Avatar
Member: 192663
Thanks Meter: 31
LG d686 dead after flash
Is there any solution to recover LG D686 dead after flash, cant reconnect to lg tool, gives error Protocol: Failed to enter flashtool mode 4001. In device manager i can see LGE AndroidNet usb serial port (com 58). Hopefully somebody knows what to do. Thanks.
Old 09-12-2014, 16:34   #2 (permalink)
Member: 1415177
same problem, dead after lgtool flash, cannot reconnect, giving error 4001
Old 10-15-2014, 14:22   #3 (permalink)
Member: 2274664
I have the same problem...
Old 10-27-2014, 12:27   #4 (permalink)
Crazy Poster
Member: 1527490
Thanks Meter: 2
I have same problem, after flashing with lgetool
Old 04-07-2015, 21:01   #5 (permalink)
slav-on's Avatar
Member: 52495
Thanks Meter: 25
same problem
after flashing dead
nodownload mode? only reconnect Protocol: Failed to enter flashtool mode 4001
Old 04-14-2015, 15:03   #6 (permalink)
Member: 1553789
Are you using any usb hub or connecting a handset directly to the pc with usb cable?
Old 05-12-2015, 08:11   #7 (permalink)
Member: 303407
Thanks Meter: 8
me too after flashing lgetool dead
Old 05-14-2015, 06:11   #8 (permalink)
Member: 1553789
What version of lgetool was used?
Old 05-25-2015, 06:28   #9 (permalink)
griff26's Avatar
Member: 192663
Thanks Meter: 31
You need to use sp flashtool which can be found by searching the forum. I have included a link with scatter, preloader, dsp_bl and boot files for this model(D686). After flashing these files the phone will be able to enter download mode again by pressing volume up while inserting usb cable then just use the official LG mobile support tool(recovery update option) or search LG section for KDZ flashtool.
LGD686
Old 09-03-2015, 11:08   #10 (permalink)
Member: 360614
Thanks Meter: 63
LGD686
mine also dead after flash with lgtool. sp tool doesn't detect phone why? phone is detected from device manager
Old 09-17-2015, 10:42   #11 (permalink)
Member: 196126
Thanks Meter: 80
LGD686
https://drive.google.com/file/d/0B10...hfeWY3dWM/view
LG -D686. Не могу прошить.
radez-kovel skypew if need help
The Following User Says Thank You to radez For This Useful Post:
Old 09-21-2015, 15:21   #12 (permalink)
Member: 1553789
Achyut
Could you tell what version of LgeTool you used? If it possible- write here logs from the flashing. They can be found in the logs folder.
Old 09-22-2015, 21:40   #13 (permalink)
Member: 196126
Thanks Meter: 80
Originally Posted by radez View Post
test point photo is at the bottom of second link
Enjoy
Old 09-30-2015, 23:33   #14 (permalink)
Member: 2159707
Sonork: 100.1654321
i need da test point of lg-d686 couse i can't get it
Old 11-10-2015, 21:56   #15 (permalink)
Member: 2223880
Thanks Meter: 2
iґll send the image via pm, i cannot upload it
The Following User Says Thank You to aaronvera For This Useful Post:
Page generated in 0.21462 seconds with 8 queries
