06-19-2014, 19:46 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Cameroon
Member: 1433726 Status: Offline Sonork: 100.1644838 Thanks Meter: 106 | LG E739 successfuly unlocked by LGtool of SETOOL Connecting with E739 Connected Receiving phone info Getting phone info Model: E739 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 512 MB NAND Flash Size: 2 GB CPU: MSM8255 Firmware Released: Jan 23 2013 13:43:08 Firmware Compiled: Aug 10 2011 13:00:00 Firmware Version: E739/E739-M8X55-V10u-JAN-23-2013-XX IMEI: 012903-00-103677-2 Bluetooth Address: F0:1C:13:87:95:1C Connect mode: Normal Info received Unlocking phone Unlock: Start Dump Security: Start This solution based on custom firmware. You should reflash firmware if you have any problems after operations. Getting phone info... Getting phone info: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Checking connect with Loader... Loader Not Found Flashing Loader... Checking Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Set Trust Mode... Set Trust Mode: OK Get DloadParams... Get DloadParams: OK Send Partition Table... Send Partition Table: OK Flashing Bootable Partitions... Checking BCPL... Checking BCPL: LOCKED Sending BCPE... Sending BCPE: 1 Checking BCPL... Checking BCPL: UNLOCKED Flashing Partition: DBL... Initializing partition: 0x0000000f [DBL]... Initializing partition: 0x0000000f [DBL]: OK Writing Partition... Flashing Partition: DBL: OK Flashing Partition: OSBL... Initializing partition: 0x00000011 [OSBL]... Initializing partition: 0x00000011 [OSBL]: OK Writing Partition... Flashing Partition: OSBL: OK Flashing Bootable Partitions: OK Dload Finalization... Dload Finalization: OK Switching to normal mode... Switching to normal mode: OK Flashing Loader: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Init Loader... Init Loader: OK Dumping Security... Reading Part Table... Reading Part Table: OK Dumping Security: OK Backuping Security to file: Backups\E739_security_012903001036772_2014-6-19_20-27-52.sbf Dump Security: Finish Flash Security: Start Flashing Security... Flashing Security: STEP 1... Reading Part Table... Reading Part Table: OK Flashing Security: STEP 1: OK Switching to normal mode... Switching to normal mode: OK Flashing Security: STEP 2... Security-Finalizing... Rebooting... Security-Finalizing: OK Flashing Security: STEP 2: OK Flash Security: Finish Unlock: Finish Phone successfully unlocked Disconnected |
08-19-2015, 12:43 | #2 (permalink) |
Insane Poster Join Date: Aug 2010 Location: albania Age: 41
Member: 1375750 Status: Offline Thanks Meter: 8 | Connecting with E739 Connected Receiving phone info Getting phone info Model: E739 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 512 MB NAND Flash Size: 2 GB CPU: MSM8255 Firmware Released: Jan 23 2013 13:43:08 Firmware Compiled: Aug 10 2011 13:00:00 Firmware Version: E739/E739-M8X55-V10u-JAN-23-2013-XX IMEI: 012903-00-051932-3 Bluetooth Address: F0:1C:13:17:884 Connect mode: Normal Info received Unlocking phone Unlock: Start Dump Security: Start This solution based on custom firmware. You should reflash firmware if you have any problems after operations. Getting phone info... Getting phone info: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Checking connect with Loader... Loader Not Found Flashing Loader... Checking Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Set Trust Mode... Set Trust Mode: OK Get DloadParams... Get DloadParams: OK Send Partition Table... Send Partition Table: OK Flashing Bootable Partitions... Checking BCPL... Checking BCPL: LOCKED Sending BCPE... Sending BCPE: 1 Checking BCPL... Checking BCPL: UNLOCKED Flashing Partition: DBL... Initializing partition: 0x0000000f [DBL]... Initializing partition: 0x0000000f [DBL]: OK Writing Partition... Flashing Partition: DBL: OK Flashing Partition: OSBL... Initializing partition: 0x00000011 [OSBL]... Initializing partition: 0x00000011 [OSBL]: OK Writing Partition... Flashing Partition: OSBL: OK Flashing Bootable Partitions: OK Dload Finalization... Dload Finalization: OK Switching to normal mode... Switching to normal mode: OK Flashing Loader: OK Checking Emergency Mode... data port: I/O error: Disconnected Connecting with E739 Connected Receiving phone info Getting phone info Model: E739 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 512 MB NAND Flash Size: 2 GB CPU: MSM8255 Firmware Released: Jan 23 2013 13:43:08 Firmware Compiled: Aug 10 2011 13:00:00 Firmware Version: E739/E739-M8X55-V10u-JAN-23-2013-XX IMEI: 012866-00-043480-3 Bluetooth Address: F0:1C:13:85:E2:42 Connect mode: Normal Info received Unlocking phone Unlock: Start Dump Security: Start This solution based on custom firmware. You should reflash firmware if you have any problems after operations. Getting phone info... Getting phone info: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Checking connect with Loader... Loader Not Found Flashing Loader... Checking Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Set Trust Mode... Set Trust Mode: OK Get DloadParams... Get DloadParams: OK Send Partition Table... Send Partition Table: OK Flashing Bootable Partitions... Checking BCPL... Checking BCPL: LOCKED Sending BCPE... Sending BCPE: 1 Checking BCPL... Checking BCPL: UNLOCKED Flashing Partition: DBL... Initializing partition: 0x0000000f [DBL]... Initializing partition: 0x0000000f [DBL]: OK Writing Partition... Flashing Partition: DBL: OK Flashing Partition: OSBL... Initializing partition: 0x00000011 [OSBL]... Initializing partition: 0x00000011 [OSBL]: OK Writing Partition... Flashing Partition: OSBL: OK Flashing Bootable Partitions: OK Dload Finalization... Dload Finalization: OK Switching to normal mode... Switching to normal mode: OK Flashing Loader: OK Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in Emergency Mode... Checking connect in Emergency Mode: OK Init Loader... Init Loader: OK Dumping Security... Reading Part Table... Reading Part Table: OK Dumping Security: OK Backuping Security to file: Backups\E739_security_012866000434803_2015-8-19_13-41-16.sbf Dump Security: Finish Flash Security: Start Flashing Security... Flashing Security: STEP 1... Reading Part Table... Reading Part Table: OK Flashing Security: STEP 1: OK Switching to normal mode... Switching to normal mode: OK Flashing Security: STEP 2... Security-Finalizing... Rebooting... Security-Finalizing: OK Flashing Security: STEP 2: OK Flash Security: Finish Unlock: Finish Phone successfully unlocked |
The Following User Says Thank You to donaltinos For This Useful Post: |
