09-27-2010, 10:40 | #61 (permalink) |
No Life Poster Join Date: Nov 2006 Location: poland krakow
Member: 389207 Status: Offline Thanks Meter: 61 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01194400426619] OTP LOCKED:1 CID:54 PAF:0 IMEI:01194400426619 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "25585160" SIGNING... Unlock DONE Elapsed: 26 secs. |
10-29-2010, 01:51 | #62 (permalink) |
Insane Poster Join Date: Jan 2007
Member: 435600 Status: Offline Thanks Meter: 7 | LG GR500 Succesful unlock Procedure is as follows: 1.0 Open SETOOL and look for model in 'A2 tab' 2.0 thick "Signed mode" in 'Settings' tab 3.0 Take out battery for 5 secs, and then put it in 4.0 Click on "Unlock Repair" 5.0 Press camera button and keep while... 6.0 Insert USB cable (I used a generic one for 5610, V8) 7.0 Once it is detected, depress the camera button 8.0 Wait 9.0 When finish disconnect USB cable take out battery If succesful unlock you will see at the end of log something like this: LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "03840878" If you do not see something like this, repeat procedure It took me two times to get the unlock done in my phone but is very easy and straightforward to do it ! Cheers ! |
The Following User Says Thank You to mrx2k For This Useful Post: |
11-08-2010, 13:19 | #63 (permalink) |
Junior Member Join Date: Aug 2006 Location: Tohana
Member: 336823 Status: Offline Thanks Meter: 10 | LG GR500 Successfully Unlcoked 11/8/2010 5:39:00 PM SIGNED MODE (USING SERVER) 11/8/2010 5:39:00 PM CFG:100000000000 11/8/2010 5:39:09 PM ChipID900,EMP protocol:0401 11/8/2010 5:39:09 PM BOOTROM MODE DETECTED 11/8/2010 5:39:09 PM OTP DBG: [1,54,0,01201*] 11/8/2010 5:39:10 PM OTP LOCKED:1 CID:54 PAF:0 IMEI:01201******* CERT:RED 11/8/2010 5:39:15 PM LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 11/8/2010 5:39:15 PM LDR CAPS:SYSTEM FLASH SIGNATURE 11/8/2010 5:39:23 PM LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 11/8/2010 5:39:23 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM 11/8/2010 5:39:23 PM WRITING CLEAR SIMLOCK UNITS... 11/8/2010 5:39:23 PM SIMLOCK CODES SET TO "43116328" 11/8/2010 5:39:23 PM SIGNING... 11/8/2010 5:39:26 PM Unlock DONE 11/8/2010 5:39:26 PM Elapsed: 25 secs. |
11-08-2010, 13:19 | #64 (permalink) |
Member: 336823 Status: Offline Thanks Meter: 10 | LG GR500 Successfully Unlcoked 11/8/2010 5:39:00 PM SIGNED MODE (USING SERVER) 11/8/2010 5:39:00 PM CFG:100000000000 11/8/2010 5:39:09 PM ChipID900,EMP protocol:0401 11/8/2010 5:39:09 PM BOOTROM MODE DETECTED 11/8/2010 5:39:09 PM OTP DBG: [1,54,0,012011********] 11/8/2010 5:39:10 PM OTP LOCKED:1 CID:54 PAF:0 IMEI:01201******* CERT:RED 11/8/2010 5:39:15 PM LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 11/8/2010 5:39:15 PM LDR CAPS:SYSTEM FLASH SIGNATURE 11/8/2010 5:39:23 PM LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 11/8/2010 5:39:23 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM 11/8/2010 5:39:23 PM WRITING CLEAR SIMLOCK UNITS... 11/8/2010 5:39:23 PM SIMLOCK CODES SET TO "43116328" 11/8/2010 5:39:23 PM SIGNING... 11/8/2010 5:39:26 PM Unlock DONE 11/8/2010 5:39:26 PM Elapsed: 25 secs. |
12-13-2010, 15:22 | #66 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 65
Member: 316241 Status: Offline Thanks Meter: 62 | RUNNING v 1.01/UNI CARD SERIAL 00033212 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01179300878719] OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300878719 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "16553248" phone detached Elapsed: 146 secs. |
12-13-2010, 15:23 | #67 (permalink) |
Member: 316241 Status: Offline Thanks Meter: 62 | unlock gr500 RUNNING v 1.01/UNI CARD SERIAL 00033212 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01179300878719] OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300878719 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "16553248" phone detached Elapsed: 146 secs. |
01-25-2011, 05:25 | #71 (permalink) |
Registered User Join Date: Feb 2005 Age: 42
Member: 119183 Status: Offline Thanks Meter: 1 | unlock 100 % tested con button camera RUNNING v 1.01/UNI CARD SERIAL 00080059 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01194400072176] OTP LOCKED:1 CID:54 PAF:0 IMEI:01194400072176 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "10417632" phone detached Elapsed: 237 secs. |
09-12-2011, 13:24 | #75 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01179300552114] OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300552114 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:HYDCXC1723919_1B2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "05503817" SIGNING ... Unlock DONE Elapsed: 27 secs. camra key for bootmode |
j132 08 week 46 not unlocked by se tool | bonghernz | SETool2 | 4 | 01-05-2009 03:49 |
W350i unlock by se tool | naneurix | SETool2 | 0 | 10-25-2008 10:13 |
k-800 CID-53 can i unlock by se tool | akhtar416786 | SETool2 | 3 | 06-29-2008 10:25 |
Free Patch Unlock by SE Tool v0.914013/UNI | Toreck | SETool2 | 31 | 11-20-2007 11:25 |
New 3G lg`s unlock in SE Tool | .::Indian::. | Redbox | 5 | 03-18-2005 12:47 |
