Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 09-27-2010, 10:40   #61 (permalink)
Member: 389207
Thanks Meter: 61
No need jumper
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID900,EMP protocol:0401
BOOTROM MODE DETECTED
OTP DBG: [1,54,0,01194400426619]
OTP LOCKED:1 CID:54 PAF:0 IMEI:01194400426619 CERT:RED
LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2
LDR CAPS:SYSTEM FLASH SIGNATURE
LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM
WRITING CLEAR SIMLOCK UNITS...
SIMLOCK CODES SET TO "25585160"
SIGNING...
Unlock DONE
Elapsed: 26 secs.
Old 10-29-2010, 01:51   #62 (permalink)
Member: 435600
Thanks Meter: 7
LG GR500 Succesful unlock
Procedure is as follows:
1.0 Open SETOOL and look for model in 'A2 tab'
2.0 thick "Signed mode" in 'Settings' tab
3.0 Take out battery for 5 secs, and then put it in
4.0 Click on "Unlock Repair"
5.0 Press camera button and keep while...
6.0 Insert USB cable (I used a generic one for 5610, V8)
7.0 Once it is detected, depress the camera button
8.0 Wait
9.0 When finish disconnect USB cable take out battery
If succesful unlock you will see at the end of log something like this:
ALL UNLOCK/LOCK CODES SET TO "03840878"
If you do not see something like this, repeat procedure
It took me two times to get the unlock done in my phone
but is very easy and straightforward to do it !
Cheers !
The Following User Says Thank You to mrx2k For This Useful Post:
Old 11-08-2010, 13:19   #63 (permalink)
Member: 336823
Thanks Meter: 10
LG GR500 Successfully Unlcoked
11/8/2010 5:39:00 PM SIGNED MODE (USING SERVER)
11/8/2010 5:39:00 PM CFG:100000000000
11/8/2010 5:39:09 PM ChipID900,EMP protocol:0401
11/8/2010 5:39:09 PM BOOTROM MODE DETECTED
11/8/2010 5:39:09 PM OTP DBG: [1,54,0,01201*]
11/8/2010 5:39:10 PM OTP LOCKED:1 CID:54 PAF:0 IMEI:01201******* CERT:RED
11/8/2010 5:39:15 PM LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2
11/8/2010 5:39:15 PM LDR CAPS:SYSTEM FLASH SIGNATURE
11/8/2010 5:39:23 PM LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2
11/8/2010 5:39:23 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM
11/8/2010 5:39:23 PM WRITING CLEAR SIMLOCK UNITS...
11/8/2010 5:39:23 PM SIMLOCK CODES SET TO "43116328"
11/8/2010 5:39:23 PM SIGNING...
11/8/2010 5:39:26 PM Unlock DONE
11/8/2010 5:39:26 PM Elapsed: 25 secs.
Old 11-08-2010, 13:19   #64 (permalink)
Member: 336823
Thanks Meter: 10
11/8/2010 5:39:09 PM OTP DBG: [1,54,0,012011********]
Old 11-15-2010, 10:10   #65 (permalink)
Member: 492265
Thanks Meter: 5
lg gr500 unlock succesfully by setool
Originally Posted by mohsin-* View Post
as was reported by few users, it is enough to press "volume up" for bootrom mode, no need shortcut.
thanks for this useful post
Old 12-13-2010, 15:22   #66 (permalink)
Member: 316241
Thanks Meter: 62
RUNNING v 1.01/UNI
CARD SERIAL 00033212
USBFLASH DRIVER VERSION 02.02.00.05
CFG:100000000000
OTP DBG: [1,54,0,01179300878719]
OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300878719 CERT:RED
LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B
LDR CAPS:SYSTEM SIGNATURE
LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D
ALL UNLOCK/LOCK CODES SET TO "16553248"
phone detached
Elapsed: 146 secs.
Old 12-13-2010, 15:23   #67 (permalink)
Member: 316241
Thanks Meter: 62
unlock gr500
RUNNING v 1.01/UNI
CFG:100000000000
phone detached
Elapsed: 146 secs.
Old 01-18-2011, 08:27   #68 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
Originally Posted by sweetboy View Post
with camera buton all ok boot mode thanks setool
This one is correct/ no need to make jumper
Old 01-24-2011, 14:44   #69 (permalink)
Member: 1483847
Thanks Meter: 4
Lg usb driver gr 500 fd plz give me urjently
Old 01-24-2011, 18:49   #70 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 773
Good information bro......
Old 01-25-2011, 05:25   #71 (permalink)
Registered User
Member: 119183
unlock
100 % tested con button camera
RUNNING v 1.01/UNI
CARD SERIAL 00080059
CFG:100000000000
OTP DBG: [1,54,0,01194400072176]
OTP LOCKED:1 CID:54 PAF:0 IMEI:01194400072176 CERT:RED
ALL UNLOCK/LOCK CODES SET TO "10417632"
phone detached
Elapsed: 237 secs.
Old 04-27-2011, 12:24   #72 (permalink)
Member: 67584
Thanks Meter: 13
Thank's bro
But for bootrom we have to press "Volum up"+"Camera key"
Good luck bro!!!
Old 06-26-2011, 12:04   #73 (permalink)
mouradb3's Avatar
Member: 498262
Thanks Meter: 16
thx man good job
i unlocked one juste now
Old 08-15-2011, 08:29   #74 (permalink)
Member: 560909
tanx bro.. good work
Old 09-12-2011, 13:24   #75 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
CFG:100000000000
OTP DBG: [1,54,0,01179300552114]
OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300552114 CERT:RED
LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2
LDR:HYDCXC1723919_1B2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2
WRITING CLEAR SIMLOCK UNITS ...
SIMLOCK CODES SET TO "05503817"
SIGNING ...
Unlock DONE
Elapsed: 27 secs.
camra key for bootmode
j132 08 week 46 not unlocked by se tool bonghernz SETool2 4 01-05-2009 03:49
W350i unlock by se tool naneurix SETool2 0 10-25-2008 10:13
k-800 CID-53 can i unlock by se tool akhtar416786 SETool2 3 06-29-2008 10:25
Free Patch Unlock by SE Tool v0.914013/UNI Toreck SETool2 31 11-20-2007 11:25
New 3G lg`s unlock in SE Tool .::Indian::. Redbox 5 03-18-2005 12:47
Page generated in 0.34869 seconds with 11 queries
