03-08-2010, 15:54 | #31 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 185255 Status: Offline Thanks Meter: 42 | CARD SERIAL CFG:000010000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01201100128695] OTP LOCKED:1 CID:54 PAF:0 IMEI:01201100128695 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM Unlock FINISHED Elapsed: 25 secs. after phone not unlock please what the solution ,... may be from settings please i need an answer |
03-14-2010, 14:03 | #33 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | RUNNING v 1.01/UNI CARD SERIAL GR500 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01201100122497] OTP LOCKED:1 CID:54 PAF:0 IMEI:01201100122497 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "47087451" phone detached Elapsed: 16 secs. |
03-15-2010, 03:07 | #34 (permalink) | |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Quote:
unlock done with new setool 1.01 | |
03-19-2010, 11:53 | #35 (permalink) |
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | RUNNING v 1.01/UNI CARD SERIAL GR500 FIDO USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35432403118694] OTP LOCKED:1 CID:54 PAF:0 IMEI:35432403118694 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "75580463" phone detached Elapsed: 16 secs. |
04-05-2010, 07:01 | #37 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> LG GR500 Unlocked Successfully <<< Big Thanks to Mr Lemor for the boot mode trick... |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
04-05-2010, 12:20 | #38 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: SKN Caribbean Age: 41
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | Lg gr501 unlock done !!! Lg gr501 unlock done !!! Quote:
[IMG][/IMG] | |
The Following User Says Thank You to ky_bAttaUsAi For This Useful Post: |
04-05-2010, 15:51 | #39 (permalink) |
Freak Poster Join Date: Oct 2008 Location: London, UK
Member: 886346 Status: Offline Sonork: 100.1582496 Thanks Meter: 12 | Hi Guys, Need to press Camera Button for Bootrom mode............. BR |
The Following User Says Thank You to alahmed For This Useful Post: |
04-07-2010, 02:01 | #40 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 59
Member: 296918 Status: Offline Thanks Meter: 122 | Quote:
Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:D900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01179300573933] OTP LOCKED:1 CID:54 PAF:0 IMEI:0117xxxxxxxxxx CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRAM_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDRAM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "54635136" phone detached Elapsed: 13 secs. i have no need to test the jumper B.R. | |
The Following User Says Thank You to foo_men For This Useful Post: |
04-07-2010, 17:59 | #41 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,01179300988068] OTP LOCKED:1 CID:54 PAF:0 IMEI:01179300988068 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "86666570" phone detached Elapsed: 9 secs. |
04-07-2010, 22:47 | #42 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Need Drivers for GR500 Hi, I have been trying now for hours to find drivers for my GR500 to connect. Please I have tried updating it from even the gordons drivers found in the SETOOL folders and it not work. Please can some one please post me the drivers? I am using XP SP3. Thanks |
04-08-2010, 00:12 | #43 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: HPS
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | Quote:
and don't forget to check (signed mode) | |
04-08-2010, 20:01 | #44 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | My Phone is actually GR501 locked to bell canada. It seems like the cable was faulty so I changed it now the PC as for different drivers ( Generic Flash Device ) I searched the folder you pointed to but its not there. Can you say if this the right connection now and where can I find the right drivers |
j132 08 week 46 not unlocked by se tool | bonghernz | SETool2 | 4 | 01-05-2009 03:49 |
W350i unlock by se tool | naneurix | SETool2 | 0 | 10-25-2008 10:13 |
k-800 CID-53 can i unlock by se tool | akhtar416786 | SETool2 | 3 | 06-29-2008 10:25 |
Free Patch Unlock by SE Tool v0.914013/UNI | Toreck | SETool2 | 31 | 11-20-2007 11:25 |
New 3G lg`s unlock in SE Tool | .::Indian::. | Redbox | 5 | 03-18-2005 12:47 |
