08-25-2010, 07:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: ..::INDIA::..
Member: 364815 Status: Offline Thanks Meter: 72 | LG GT400 successfully unlocked by setool Tick on sign mode then press unlock no need to flash the fone SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,3598XXXXXXXX] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803242897 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "40885121" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 92 secs. thnx to the_laser and setool team b/r GsmLab INDIA |
The Following 6 Users Say Thank You to deecee For This Useful Post: |
08-25-2010, 15:09 | #3 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 47
Member: 106234 Status: Offline Thanks Meter: 7 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803181687] OTP LOCKED:1 CID:54 PAF:0 IMEI:35xxxxxxxxxxxxx CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... eraseSecData,err details:00000064 Unlock FAILED Elapsed: 25 secs. can somebody tel me any ideea? |
09-02-2010, 17:44 | #4 (permalink) |
Junior Member Join Date: May 2009 Location: Holland
Member: 1023377 Status: Offline Thanks Meter: 1 | I am trying to unlock a gt400 and I cant seem to connect the phone. I have read here on this forum and people say that I should connect the phone while pressing the volume button up but this is not working for me. Is there another way to unlock this phone should I install some drivers. |
09-04-2010, 15:58 | #5 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 53
Member: 103635 Status: Offline Thanks Meter: 86 | volume button up = correct Quote:
good luck | |
09-09-2010, 19:46 | #6 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803133757] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803133757 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "25543511" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 379 secs. |
The Following 2 Users Say Thank You to Alexandro Monte For This Useful Post: |
09-15-2010, 12:57 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: GSM-CLINIQUE.COM, SOUTH COAST Age: 43
Member: 54945 Status: Offline Thanks Meter: 22 | RUNNING v 1.087/UNI CARD SERIAL 00037381 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 46 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803085528] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803085528 CERT:RED Unlock DONE Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 23 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110010000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803085528] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803085528 CERT:RED Unlock DONE Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803085528] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803085528 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "55021412" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 67 secs. unlock perfect only tick SIGNED MODE |
The Following 3 Users Say Thank You to TOZE For This Useful Post: |
11-14-2010, 12:14 | #8 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | Lg gt-400 unlock successfully SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803202481] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803202481 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "88801131" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 41 secs. |
The Following User Says Thank You to gsmexpertgsmexp For This Useful Post: |
02-05-2011, 15:20 | #11 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | RUNNING v 1.089/UNI CARD SERIAL 00093587 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 llbug:read error: "Incorrect function" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803248967] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803248967 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "44768647" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 82 secs. |
08-05-2011, 14:16 | #12 (permalink) |
No Life Poster Join Date: May 2007 Location: *** TUNISIA *** Age: 41
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | CONNECTING USE VOLUME UP BUTTON PRESSED AND CONNECT WITH MICRO USB for BOOTROM mode use VOLUME DOWN + CAMERA and insert USB RUNNING v 1.1099/01.12/UNI CARD SERIAL 001XXXXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803126200] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803126200 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "48645400" SIGNING... Unlock DONE |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
