03-21-2011, 13:26 | #19 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | i unlock without flashing with v1.104 setup \\\ See Log Here : SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803129627] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803129627 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "76186578" SIGNING... Unlock DONE Elapsed: 25 secs. |
The Following User Says Thank You to RAVI_SINGH For This Useful Post: |
07-26-2011, 13:50 | #20 (permalink) |
Insane Poster Join Date: Aug 2009 Location: islamabad
Member: 1096818 Status: Offline Sonork: 100.1592974 Thanks Meter: 68 | RUNNING v 1.1094/01.11/UNI CARD SERIAL 001xxxxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,359828xxxxxxxx] OTP LOCKED:1 CID:54 PAF:0 IMEI:3598280xxxxxxx CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "53817562" SIGNING... Unlock DONE Elapsed: 44 secs. jest SIGNED MODE camera and up volume just unlock bro malik raza |
08-04-2011, 12:03 | #21 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | RUNNING v 1.104/UNI CARD SERIAL 00075956 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803131489] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803131489 CERT:RED Unlock DONE Elapsed: 121 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110010000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803131489] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803131489 CERT:RED Unlock DONE Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803131489] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803131489 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "08745854" SIGNING... Unlock DONE Elapsed: 34 secs. |
08-05-2011, 14:08 | #22 (permalink) | |
No Life Poster Join Date: May 2007 Location: *** TUNISIA *** Age: 41
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | CONNECTING USE VOLUME UP BUTTON PRESSED AND CONNECT WITH MICRO USB for BOOTROM mode use VOLUME DOWN + CAMERA and insert USB Quote:
09-24-2011, 12:02 | #23 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | work me also latest veryan Elapsed: 118 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803232683] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982803232683 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "46720621" SIGNING ... Unlock DONE Elapsed: 28 secs. |
09-30-2011, 09:49 | #25 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Moroni Comoros Age: 49
Member: 127093 Status: Offline Thanks Meter: 22 | Unlock GT 400 without flash ok RUNNING v 1.1107/01.11/UNI CARD SERIAL xxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,3xxxxxxxxxxxxxx] OTP LOCKED:1 CID:54 PAF:0 IMEI:3xxxxxxxxxxxx CERT:RED operation not supported at the moment Elapsed: 43 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,3xxxxxxxxxxxxxxxxxxxxxx] OTP LOCKED:1 CID:54 PAF:0 IMEI:xxxxxxxxxxxxxx36 CERT:RED LDR:CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL 2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "86840442" SIGNING ... Unlock DONE Elapsed: 24 secs. |
03-29-2013, 00:27 | #26 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Hi to all If you face error A2_eraseSecData,err details:00000064 just flash gt400_syspart_fix.ssw from A2 gdfs.ssw then chek only signed mode press and hold volum up insert usb cable install drivers that's it Here is log RUNNING v 1.1295/01.14/UNI CARD SERIAL XXXXXXXXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: D900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803700967] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803700967 CERT:RED LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 LDR CAPS: SYSTEM FLASH SIGNATURE LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... A2_eraseSecData,err details:00000064 Unlock FAILED Elapsed: 31 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: D900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803700967] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803700967 CERT:RED LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 LDR CAPS: SYSTEM FLASH SIGNATURE LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "C:\Documents and Settings\Administrateur\Bureau\v1.1295\gdfs_in_ssw _format\A2\gt400_syspart_fix.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 13 blocks ... SSW file accepted Elapsed: 27 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: D900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982803700967] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803700967 CERT:RED LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 LDR CAPS: SYSTEM FLASH SIGNATURE LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "52100635" SIGNING ... Unlock DONE Elapsed: 23 secs. |
03-30-2015, 06:53 | #27 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | 3/30/2015 10:48:53 AM SIGNED MODE (USING SERVER) 3/30/2015 10:48:53 AM CFG:100000000000 3/30/2015 10:48:57 AM ChipID: D900, EMP protocol: 0401 3/30/2015 10:48:57 AM BOOTROM MODE DETECTED 3/30/2015 10:48:57 AM OTP DBG: [1,54,0,35982803002818] 3/30/2015 10:48:58 AM OTP: LOCKED:1 CID:54 PAF:0 IMEI:35982803002818 CERT:RED 3/30/2015 10:49:00 AM LDR: CXC1723918_DB3200_PRODUCTION_LOADER_ACC_SETOOL2 3/30/2015 10:49:00 AM LDR CAPS: SYSTEM FLASH SIGNATURE 3/30/2015 10:49:12 AM LDR: MATCXC1723919_1E2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_SETOOL2 3/30/2015 10:49:12 AM LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM 3/30/2015 10:49:12 AM WRITING CLEAR SIMLOCK UNITS ... 3/30/2015 10:49:13 AM SIMLOCK CODES SET TO "15623184" 3/30/2015 10:49:13 AM SIGNING ... 3/30/2015 10:49:14 AM Unlock DONE 3/30/2015 10:49:14 AM Elapsed: 21 secs. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
