09-11-2015, 18:31 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | LG H345 Unlocked done But still Locked By Choosing H345KTGO with Lgtool Connecting with H345KTGO Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Connected Receiving phone info Getting phone info Model: H345KTGO Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8916 Firmware Released: Apr 17 2015 11:57:14 Firmware Compiled: Mar 10 2015 06:00:00 Firmware Version: EAAAANVZD/MPSS.DPM.2.0.c11-00014-M8936FAAAANUZM-1 IMEI: 359562-06-519084-1 Connect mode: Normal Info received Unlocking phone Unlock: Start Backuping NVM to file: Backups\H345KTGO_nvm_359562065190841_2015-9-11_9-55-45.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\H345KTGO_efs_359562065190841_2015-9-11_10-0-55.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 272 bytes Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Downloading file /nv/item_files/conf/geran.conf 1.35 Kb Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 3.08 Kb Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Downloading file /nv/item_files/conf/mc.conf 888 bytes Downloading file /nv/item_files/conf/mcfg.conf 216 bytes Downloading file /nv/item_files/conf/mcpm.conf 154 bytes Downloading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Downloading file /nv/item_files/conf/mmode.conf 2.39 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 266 bytes Downloading file /nv/item_files/conf/pbm.conf 238 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 491 bytes Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes Downloading file /nv/item_files/conf/reg.conf 1.38 Kb Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 513 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes Downloading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Downloading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Downloading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Downloading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Downloading file /nv/item_files/conf/wl1ul.conf 40 bytes Downloading file /nv/item_files/conf/wms.conf 558 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/rfnv/00022982 529 bytes Downloading file /nv/item_files/rfnv/00023759 150 bytes Downloading file /nv/item_files/rfnv/00023761 150 bytes Downloading file /nv/item_files/rfnv/00024227 761 bytes Downloading file /nv/item_files/rfnv/00024229 825 bytes Downloading file /nv/item_files/rfnv/00024237 697 bytes Downloading file /nv/item_files/rfnv/00024253 769 bytes Downloading file /nv/item_files/rfnv/00024254 787 bytes Downloading file /nv/item_files/rfnv/00024255 748 bytes Downloading file /nv/item_files/rfnv/00024964 193 bytes Downloading file /nv/item_files/rfnv/00024965 193 bytes Downloading file /nv/item_files/rfnv/00024966 193 bytes Downloading file /nv/item_files/rfnv/00024967 193 bytes Downloading file /nv/item_files/rfnv/00024972 2.49 Kb Downloading file /nv/item_files/rfnv/00024973 2.49 Kb Downloading file /nv/item_files/rfnv/00024974 2.49 Kb Downloading file /nv/item_files/rfnv/00024975 2.49 Kb Downloading file /nv/item_files/rfnv/00025004 192 bytes Downloading file /nv/item_files/rfnv/00025005 192 bytes Downloading file /nv/item_files/rfnv/00025006 192 bytes Downloading file /nv/item_files/rfnv/00025007 192 bytes Downloading file /nv/item_files/rfnv/00025044 160 bytes Downloading file /nv/item_files/rfnv/00025045 160 bytes Downloading file /nv/item_files/rfnv/00025046 160 bytes Downloading file /nv/item_files/rfnv/00025047 160 bytes Downloading file /nv/item_files/rfnv/00025533 225 bytes Downloading file /nv/item_files/rfnv/00025535 225 bytes Downloading file /nv/item_files/rfnv/00025543 225 bytes Downloading file /nv/item_files/rfnv/00025618 1.00 Kb Downloading file /nv/item_files/rfnv/00025619 1.00 Kb Downloading file /nv/item_files/rfnv/00025620 1.00 Kb Downloading file /nv/item_files/rfnv/00025625 1.00 Kb Downloading file /nv/item_files/rfnv/00025626 1.00 Kb Downloading file /nv/item_files/rfnv/00025627 1.00 Kb Downloading file /nv/item_files/rfnv/00025632 1.00 Kb Downloading file /nv/item_files/rfnv/00025634 1.00 Kb Downloading file /nv/item_files/rfnv/00025642 1.00 Kb Downloading file /nv/item_files/rfnv/00025676 1.00 Kb Downloading file /nv/item_files/rfnv/00025678 1.00 Kb Downloading file /nv/item_files/rfnv/00025686 1.00 Kb Downloading file /nv/item_files/rfnv/00027473 131 bytes Downloading file /nv/item_files/rfnv/00027474 131 bytes Downloading file /nv/item_files/rfnv/00027475 131 bytes Downloading file /nv/item_files/rfnv/00027476 131 bytes Downloading file /nv/item_files/rfnv/00027477 131 bytes Downloading file /nv/item_files/rfnv/00027478 131 bytes Downloading file /nv/item_files/rfnv/00027479 131 bytes Downloading file /nv/item_files/rfnv/00027481 131 bytes Downloading file /nv/item_files/rfnv/00027482 131 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/conf/policyman.conf 172 bytes Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking... Checking connect in LAF-Emergency Mode: OK Imei: 359562065190841 Pid: CH32S150625002784 ModelName: LG-H345 BatteryLevel: 95% DeviceSwVersion: H34510b DeviceFactoryVersion: LGH345AT-01-V10b-310-260-APR-17-2015+0 ChipsetPlatform: msm8916 HardwareRevision: rev_10 LafSwVersion: 1.1 DeviceFactoryOutVersion: LGH345AT-00-V10b-TMO-US-APR-17-2015+0 Dumping Security Backup... Reading modemst1 [15400, c00] Reading modemst1: OK Reading modemst2 [16000, c00] Reading modemst2: OK Backuping Security to file: Backups\H345KTGO_security_359562065190841_2015-9-11_10-10-37.sbf Writing security to file... Writing security to file: OK Dumping Security Backup: OK Flashing Patched Security... Writing modemst1 [15400, c00] Writing modemst1: OK Writing modemst2 [16000, c00] Writing modemst2: OK Flashing Patched Security: OK Switching to normal mode... Please power on the phone and wait some minutes to continue... In some cases you should select the item "LG Software" in the dialog "USB connection" and reconnect USB-cable... Switching to normal mode: OK Writing NVM-Backup from file: Backups\H345KTGO_nvm_359562065190841_2015-9-11_9-55-45.sbf Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Writing EFS-Backup from file: Backups\H345KTGO_efs_359562065190841_2015-9-11_10-0-55.sbf Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Uploading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Uploading file /nv/item_files/conf/cgps_pe.conf 272 bytes Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Uploading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Uploading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Uploading file /nv/item_files/conf/geran.conf 1.35 Kb Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Uploading file /nv/item_files/conf/ims.conf 3.08 Kb Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Uploading file /nv/item_files/conf/mc.conf 888 bytes Uploading file /nv/item_files/conf/mcfg.conf 216 bytes Uploading file /nv/item_files/conf/mcpm.conf 154 bytes Uploading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Uploading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Uploading file /nv/item_files/conf/mmode.conf 2.39 Kb Uploading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes Uploading file /nv/item_files/conf/onex_srch.conf 266 bytes Uploading file /nv/item_files/conf/pbm.conf 238 bytes Uploading file /nv/item_files/conf/ps_config_info.conf 491 bytes Uploading file /nv/item_files/conf/qmi_data.conf 88 bytes Uploading file /nv/item_files/conf/reg.conf 1.38 Kb Uploading file /nv/item_files/conf/rrc_feature.conf 43 bytes Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Uploading file /nv/item_files/conf/uimdrv.conf 513 bytes Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Uploading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Uploading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes Uploading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Uploading file /nv/item_files/conf/wl1_fet.conf 41 bytes Uploading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Uploading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Uploading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Uploading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Uploading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Uploading file /nv/item_files/conf/wl1ul.conf 40 bytes Uploading file /nv/item_files/conf/wms.conf 558 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Uploading file /nv/item_files/rfnv/00022982 529 bytes Uploading file /nv/item_files/rfnv/00023759 150 bytes Uploading file /nv/item_files/rfnv/00023761 150 bytes Uploading file /nv/item_files/rfnv/00024227 761 bytes Uploading file /nv/item_files/rfnv/00024229 825 bytes Uploading file /nv/item_files/rfnv/00024237 697 bytes Uploading file /nv/item_files/rfnv/00024253 769 bytes Uploading file /nv/item_files/rfnv/00024254 787 bytes Uploading file /nv/item_files/rfnv/00024255 748 bytes Uploading file /nv/item_files/rfnv/00024964 193 bytes Uploading file /nv/item_files/rfnv/00024965 193 bytes Uploading file /nv/item_files/rfnv/00024966 193 bytes Uploading file /nv/item_files/rfnv/00024967 193 bytes Uploading file /nv/item_files/rfnv/00024972 2.49 Kb Uploading file /nv/item_files/rfnv/00024973 2.49 Kb Uploading file /nv/item_files/rfnv/00024974 2.49 Kb Uploading file /nv/item_files/rfnv/00024975 2.49 Kb Uploading file /nv/item_files/rfnv/00025004 192 bytes Uploading file /nv/item_files/rfnv/00025005 192 bytes Uploading file /nv/item_files/rfnv/00025006 192 bytes Uploading file /nv/item_files/rfnv/00025007 192 bytes Uploading file /nv/item_files/rfnv/00025044 160 bytes Uploading file /nv/item_files/rfnv/00025045 160 bytes Uploading file /nv/item_files/rfnv/00025046 160 bytes Uploading file /nv/item_files/rfnv/00025047 160 bytes Uploading file /nv/item_files/rfnv/00025533 225 bytes Uploading file /nv/item_files/rfnv/00025535 225 bytes Uploading file /nv/item_files/rfnv/00025543 225 bytes Uploading file /nv/item_files/rfnv/00025618 1.00 Kb Uploading file /nv/item_files/rfnv/00025619 1.00 Kb Uploading file /nv/item_files/rfnv/00025620 1.00 Kb Uploading file /nv/item_files/rfnv/00025625 1.00 Kb Uploading file /nv/item_files/rfnv/00025626 1.00 Kb Uploading file /nv/item_files/rfnv/00025627 1.00 Kb Uploading file /nv/item_files/rfnv/00025632 1.00 Kb Uploading file /nv/item_files/rfnv/00025634 1.00 Kb Uploading file /nv/item_files/rfnv/00025642 1.00 Kb Uploading file /nv/item_files/rfnv/00025676 1.00 Kb Uploading file /nv/item_files/rfnv/00025678 1.00 Kb Uploading file /nv/item_files/rfnv/00025686 1.00 Kb Uploading file /nv/item_files/rfnv/00027473 131 bytes Uploading file /nv/item_files/rfnv/00027474 131 bytes Uploading file /nv/item_files/rfnv/00027475 131 bytes Uploading file /nv/item_files/rfnv/00027476 131 bytes Uploading file /nv/item_files/rfnv/00027477 131 bytes Uploading file /nv/item_files/rfnv/00027478 131 bytes Uploading file /nv/item_files/rfnv/00027479 131 bytes Uploading file /nv/item_files/rfnv/00027481 131 bytes Uploading file /nv/item_files/rfnv/00027482 131 bytes Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes Uploading file /nv/reg_files/conf/policyman.conf 172 bytes Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything). Unlock: Finish Phone successfully unlocked |
The Following User Says Thank You to godwin For This Useful Post: |
11-17-2015, 15:05 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | Universal Tool version: 2.53 OS Version: Windows 7 [NT 6.1] Service Pack 1 Administrative privileges: yes Locale: UnitedStates / English CPU frequency: 2933 MHz Total memory: 3284 MB Free memory: 636 MB Free space on system disk C:\: 143.00 GB Free space on disk D:\: 26.00 GB Free space on disk E:\: 17.00 GB Free space on disk F:\: 61 MB Free space on disk G:\: 16.00 GB Free space on disk H:\: 17.00 GB Free space on disk I:\: 21.00 GB You are not using Windows XP. Correct work can only be guaranteed on Windows XP operating system. Connecting with H345KT Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Connected Receiving phone info Getting phone info Model: H345KT Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8916 data port: I/O error: Connecting with H345KT Connected Disconnected Connecting with H345KT Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Connected Receiving phone info Getting phone info Model: H345KT Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8916 data port: timeout: Connecting with H345KT Connected Disconnected Connecting with H345KT Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled". Connected Receiving phone info Getting phone info Model: H345KT Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8916 Firmware Released: May 21 2015 17:05:03 Firmware Compiled: Apr 22 2015 05:00:00 Firmware Version: EAAAANVZD/MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1 IMEI: 359562-06-191652-0 Connect mode: Normal Info received Receiving phone info Getting phone info Model: H345KT Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8916 Firmware Released: May 21 2015 17:05:03 Firmware Compiled: Apr 22 2015 05:00:00 Firmware Version: EAAAANVZD/MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1 IMEI: 359562-06-191652-0 Connect mode: Normal Info received Unlocking phone Unlock: Start Backuping NVM to file: Backups\H345KT_nvm_359562061916520_2015-11-17_19-24-5.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\H345KT_efs_359562061916520_2015-11-17_19-27-17.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 272 bytes Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Downloading file /nv/item_files/conf/geran.conf 1.35 Kb Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 3.08 Kb Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Downloading file /nv/item_files/conf/mc.conf 888 bytes Downloading file /nv/item_files/conf/mcfg.conf 216 bytes Downloading file /nv/item_files/conf/mcpm.conf 154 bytes Downloading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Downloading file /nv/item_files/conf/mmode.conf 2.39 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 266 bytes Downloading file /nv/item_files/conf/pbm.conf 238 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 491 bytes Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes Downloading file /nv/item_files/conf/reg.conf 1.38 Kb Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 513 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes Downloading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Downloading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Downloading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Downloading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Downloading file /nv/item_files/conf/wl1ul.conf 40 bytes Downloading file /nv/item_files/conf/wms.conf 558 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/rfnv/00022982 529 bytes Downloading file /nv/item_files/rfnv/00023759 150 bytes Downloading file /nv/item_files/rfnv/00023761 150 bytes Downloading file /nv/item_files/rfnv/00024227 777 bytes Downloading file /nv/item_files/rfnv/00024229 827 bytes Downloading file /nv/item_files/rfnv/00024237 696 bytes Downloading file /nv/item_files/rfnv/00024253 773 bytes Downloading file /nv/item_files/rfnv/00024254 783 bytes Downloading file /nv/item_files/rfnv/00024255 742 bytes Downloading file /nv/item_files/rfnv/00024964 193 bytes Downloading file /nv/item_files/rfnv/00024965 193 bytes Downloading file /nv/item_files/rfnv/00024966 193 bytes Downloading file /nv/item_files/rfnv/00024967 193 bytes Downloading file /nv/item_files/rfnv/00024972 2.49 Kb Downloading file /nv/item_files/rfnv/00024973 2.49 Kb Downloading file /nv/item_files/rfnv/00024974 2.49 Kb Downloading file /nv/item_files/rfnv/00024975 2.49 Kb Downloading file /nv/item_files/rfnv/00025004 192 bytes Downloading file /nv/item_files/rfnv/00025005 192 bytes Downloading file /nv/item_files/rfnv/00025006 192 bytes Downloading file /nv/item_files/rfnv/00025007 192 bytes Downloading file /nv/item_files/rfnv/00025044 160 bytes Downloading file /nv/item_files/rfnv/00025045 160 bytes Downloading file /nv/item_files/rfnv/00025046 160 bytes Downloading file /nv/item_files/rfnv/00025047 160 bytes Downloading file /nv/item_files/rfnv/00025533 225 bytes Downloading file /nv/item_files/rfnv/00025535 225 bytes Downloading file /nv/item_files/rfnv/00025543 225 bytes Downloading file /nv/item_files/rfnv/00025618 1.00 Kb Downloading file /nv/item_files/rfnv/00025619 1.00 Kb Downloading file /nv/item_files/rfnv/00025620 1.00 Kb Downloading file /nv/item_files/rfnv/00025625 1.00 Kb Downloading file /nv/item_files/rfnv/00025626 1.00 Kb Downloading file /nv/item_files/rfnv/00025627 1.00 Kb Downloading file /nv/item_files/rfnv/00025632 1.00 Kb Downloading file /nv/item_files/rfnv/00025634 1.00 Kb Downloading file /nv/item_files/rfnv/00025642 1.00 Kb Downloading file /nv/item_files/rfnv/00025676 1.00 Kb Downloading file /nv/item_files/rfnv/00025678 1.00 Kb Downloading file /nv/item_files/rfnv/00025686 1.00 Kb Downloading file /nv/item_files/rfnv/00027473 131 bytes Downloading file /nv/item_files/rfnv/00027474 131 bytes Downloading file /nv/item_files/rfnv/00027475 131 bytes Downloading file /nv/item_files/rfnv/00027476 131 bytes Downloading file /nv/item_files/rfnv/00027477 131 bytes Downloading file /nv/item_files/rfnv/00027478 131 bytes Downloading file /nv/item_files/rfnv/00027479 131 bytes Downloading file /nv/item_files/rfnv/00027481 131 bytes Downloading file /nv/item_files/rfnv/00027482 131 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/conf/policyman.conf 172 bytes Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking... Checking connect in LAF-Emergency Mode: OK Imei: 359562061916520 Pid: CD23S150424001413 ModelName: LG-H345 BatteryLevel: 77% DeviceSwVersion: H34510d DeviceFactoryVersion: LGH345AT-00-V10d-TMO-US-MAY-21-2015+0 ChipsetPlatform: msm8916 HardwareRevision: rev_10 LafSwVersion: 1.1 DeviceFactoryOutVersion: LGH345AT-00-V10d-TMO-US-MAY-21-2015+0 Dumping Security Backup... Reading modemst1 [15400, c00] Reading modemst1: OK Reading modemst2 [16000, c00] Reading modemst2: OK Backuping Security to file: Backups\H345KT_security_359562061916520_2015-11-17_19-29-13.sbf Writing security to file... Writing security to file: OK Dumping Security Backup: OK Flashing Patched Security... Writing modemst1 [15400, c00] Writing modemst1: OK Writing modemst2 [16000, c00] Writing modemst2: OK Flashing Patched Security: OK Switching to normal mode... Switching to normal mode: OK Writing NVM-Backup from file: Backups\H345KT_nvm_359562061916520_2015-11-17_19-24-5.sbf Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Writing EFS-Backup from file: Backups\H345KT_efs_359562061916520_2015-11-17_19-27-17.sbf Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Uploading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Uploading file /nv/item_files/conf/cgps_pe.conf 272 bytes Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Uploading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Uploading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Uploading file /nv/item_files/conf/geran.conf 1.35 Kb Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Uploading file /nv/item_files/conf/ims.conf 3.08 Kb Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Uploading file /nv/item_files/conf/mc.conf 888 bytes Uploading file /nv/item_files/conf/mcfg.conf 216 bytes Uploading file /nv/item_files/conf/mcpm.conf 154 bytes Uploading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Uploading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Uploading file /nv/item_files/conf/mmode.conf 2.39 Kb Uploading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes Uploading file /nv/item_files/conf/onex_srch.conf 266 bytes Uploading file /nv/item_files/conf/pbm.conf 238 bytes Uploading file /nv/item_files/conf/ps_config_info.conf 491 bytes Uploading file /nv/item_files/conf/qmi_data.conf 88 bytes Uploading file /nv/item_files/conf/reg.conf 1.38 Kb Uploading file /nv/item_files/conf/rrc_feature.conf 43 bytes Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Uploading file /nv/item_files/conf/uimdrv.conf 513 bytes Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Uploading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Uploading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes Uploading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Uploading file /nv/item_files/conf/wl1_fet.conf 41 bytes Uploading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Uploading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Uploading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Uploading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Uploading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Uploading file /nv/item_files/conf/wl1ul.conf 40 bytes Uploading file /nv/item_files/conf/wms.conf 558 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Uploading file /nv/item_files/rfnv/00022982 529 bytes Uploading file /nv/item_files/rfnv/00023759 150 bytes Uploading file /nv/item_files/rfnv/00023761 150 bytes Uploading file /nv/item_files/rfnv/00024227 777 bytes Uploading file /nv/item_files/rfnv/00024229 827 bytes Uploading file /nv/item_files/rfnv/00024237 696 bytes Uploading file /nv/item_files/rfnv/00024253 773 bytes Uploading file /nv/item_files/rfnv/00024254 783 bytes Uploading file /nv/item_files/rfnv/00024255 742 bytes Uploading file /nv/item_files/rfnv/00024964 193 bytes Uploading file /nv/item_files/rfnv/00024965 193 bytes Uploading file /nv/item_files/rfnv/00024966 193 bytes Uploading file /nv/item_files/rfnv/00024967 193 bytes Uploading file /nv/item_files/rfnv/00024972 2.49 Kb Uploading file /nv/item_files/rfnv/00024973 2.49 Kb Uploading file /nv/item_files/rfnv/00024974 2.49 Kb Uploading file /nv/item_files/rfnv/00024975 2.49 Kb Uploading file /nv/item_files/rfnv/00025004 192 bytes Uploading file /nv/item_files/rfnv/00025005 192 bytes Uploading file /nv/item_files/rfnv/00025006 192 bytes Uploading file /nv/item_files/rfnv/00025007 192 bytes Uploading file /nv/item_files/rfnv/00025044 160 bytes Uploading file /nv/item_files/rfnv/00025045 160 bytes Uploading file /nv/item_files/rfnv/00025046 160 bytes Uploading file /nv/item_files/rfnv/00025047 160 bytes Uploading file /nv/item_files/rfnv/00025533 225 bytes Uploading file /nv/item_files/rfnv/00025535 225 bytes Uploading file /nv/item_files/rfnv/00025543 225 bytes Uploading file /nv/item_files/rfnv/00025618 1.00 Kb Uploading file /nv/item_files/rfnv/00025619 1.00 Kb Uploading file /nv/item_files/rfnv/00025620 1.00 Kb Uploading file /nv/item_files/rfnv/00025625 1.00 Kb Uploading file /nv/item_files/rfnv/00025626 1.00 Kb Uploading file /nv/item_files/rfnv/00025627 1.00 Kb Uploading file /nv/item_files/rfnv/00025632 1.00 Kb Uploading file /nv/item_files/rfnv/00025634 1.00 Kb Uploading file /nv/item_files/rfnv/00025642 1.00 Kb Uploading file /nv/item_files/rfnv/00025676 1.00 Kb Uploading file /nv/item_files/rfnv/00025678 1.00 Kb Uploading file /nv/item_files/rfnv/00025686 1.00 Kb Uploading file /nv/item_files/rfnv/00027473 131 bytes Uploading file /nv/item_files/rfnv/00027474 131 bytes Uploading file /nv/item_files/rfnv/00027475 131 bytes Uploading file /nv/item_files/rfnv/00027476 131 bytes Uploading file /nv/item_files/rfnv/00027477 131 bytes Uploading file /nv/item_files/rfnv/00027478 131 bytes Uploading file /nv/item_files/rfnv/00027479 131 bytes Uploading file /nv/item_files/rfnv/00027481 131 bytes Uploading file /nv/item_files/rfnv/00027482 131 bytes Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes Uploading file /nv/reg_files/conf/policyman.conf 172 bytes Uploading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything). Unlock: Finish Phone successfully unlocked same here not unlock b.r yuvi |
The Following User Says Thank You to Yuvi For This Useful Post: |
11-19-2015, 23:56 | #5 (permalink) |
Insane Poster Join Date: May 2011 Location: Morocco, france...
Member: 1581092 Status: Offline Sonork: 100.1605440 Thanks Meter: 35 | Unlocking phone Unlock: Start Backuping NVM to file: Backups\H345KTGO_nvm_359562068097654_2015-11-19_4-7-21.sbf Dump NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Dumping NVM... Dumping NVM: OK Switching to normal mode... Switching to normal mode: OK Dump NVM: Finish Backuping EFS to file: Backups\H345KTGO_efs_359562068097654_2015-11-19_4-12-21.sbf Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Downloading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Downloading file /nv/item_files/conf/cgps_pe.conf 272 bytes Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Downloading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Downloading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Downloading file /nv/item_files/conf/geran.conf 1.35 Kb Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Downloading file /nv/item_files/conf/ims.conf 3.08 Kb Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Downloading file /nv/item_files/conf/mc.conf 888 bytes Downloading file /nv/item_files/conf/mcfg.conf 216 bytes Downloading file /nv/item_files/conf/mcpm.conf 154 bytes Downloading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Downloading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Downloading file /nv/item_files/conf/mmode.conf 2.39 Kb Downloading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes Downloading file /nv/item_files/conf/onex_srch.conf 266 bytes Downloading file /nv/item_files/conf/pbm.conf 238 bytes Downloading file /nv/item_files/conf/ps_config_info.conf 491 bytes Downloading file /nv/item_files/conf/qmi_data.conf 88 bytes Downloading file /nv/item_files/conf/reg.conf 1.38 Kb Downloading file /nv/item_files/conf/rrc_feature.conf 43 bytes Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Downloading file /nv/item_files/conf/uimdrv.conf 513 bytes Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Downloading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Downloading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes Downloading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Downloading file /nv/item_files/conf/wl1_fet.conf 41 bytes Downloading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Downloading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Downloading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Downloading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Downloading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Downloading file /nv/item_files/conf/wl1ul.conf 40 bytes Downloading file /nv/item_files/conf/wms.conf 558 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Downloading file /nv/item_files/rfnv/00022982 529 bytes Downloading file /nv/item_files/rfnv/00023759 150 bytes Downloading file /nv/item_files/rfnv/00023761 150 bytes Downloading file /nv/item_files/rfnv/00024227 770 bytes Downloading file /nv/item_files/rfnv/00024229 827 bytes Downloading file /nv/item_files/rfnv/00024237 705 bytes Downloading file /nv/item_files/rfnv/00024253 778 bytes Downloading file /nv/item_files/rfnv/00024254 783 bytes Downloading file /nv/item_files/rfnv/00024255 764 bytes Downloading file /nv/item_files/rfnv/00024964 193 bytes Downloading file /nv/item_files/rfnv/00024965 193 bytes Downloading file /nv/item_files/rfnv/00024966 193 bytes Downloading file /nv/item_files/rfnv/00024967 193 bytes Downloading file /nv/item_files/rfnv/00024972 2.49 Kb Downloading file /nv/item_files/rfnv/00024973 2.49 Kb Downloading file /nv/item_files/rfnv/00024974 2.49 Kb Downloading file /nv/item_files/rfnv/00024975 2.49 Kb Downloading file /nv/item_files/rfnv/00025004 192 bytes Downloading file /nv/item_files/rfnv/00025005 192 bytes Downloading file /nv/item_files/rfnv/00025006 192 bytes Downloading file /nv/item_files/rfnv/00025007 192 bytes Downloading file /nv/item_files/rfnv/00025044 160 bytes Downloading file /nv/item_files/rfnv/00025045 160 bytes Downloading file /nv/item_files/rfnv/00025046 160 bytes Downloading file /nv/item_files/rfnv/00025047 160 bytes Downloading file /nv/item_files/rfnv/00025533 225 bytes Downloading file /nv/item_files/rfnv/00025535 225 bytes Downloading file /nv/item_files/rfnv/00025543 225 bytes Downloading file /nv/item_files/rfnv/00025618 1.00 Kb Downloading file /nv/item_files/rfnv/00025619 1.00 Kb Downloading file /nv/item_files/rfnv/00025620 1.00 Kb Downloading file /nv/item_files/rfnv/00025625 1.00 Kb Downloading file /nv/item_files/rfnv/00025626 1.00 Kb Downloading file /nv/item_files/rfnv/00025627 1.00 Kb Downloading file /nv/item_files/rfnv/00025632 1.00 Kb Downloading file /nv/item_files/rfnv/00025634 1.00 Kb Downloading file /nv/item_files/rfnv/00025642 1.00 Kb Downloading file /nv/item_files/rfnv/00025676 1.00 Kb Downloading file /nv/item_files/rfnv/00025678 1.00 Kb Downloading file /nv/item_files/rfnv/00025686 1.00 Kb Downloading file /nv/item_files/rfnv/00027473 131 bytes Downloading file /nv/item_files/rfnv/00027474 131 bytes Downloading file /nv/item_files/rfnv/00027475 131 bytes Downloading file /nv/item_files/rfnv/00027476 131 bytes Downloading file /nv/item_files/rfnv/00027477 131 bytes Downloading file /nv/item_files/rfnv/00027478 131 bytes Downloading file /nv/item_files/rfnv/00027479 131 bytes Downloading file /nv/item_files/rfnv/00027481 131 bytes Downloading file /nv/item_files/rfnv/00027482 131 bytes Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes Downloading file /nv/reg_files/conf/policyman.conf 172 bytes Checking Emergency Mode... Mode: Normal Switching to Emergency Mode... Mode: Emergency Checking connect in LAF-Emergency Mode... Checking... Checking... Checking connect in LAF-Emergency Mode: OK Imei: 359562068097654 Pid: CH31S150721003281 ModelName: LG-H345 BatteryLevel: 85% DeviceSwVersion: H34510f DeviceFactoryVersion: LGH345AT-00-V10f-TMO-US-AUG-16-2015+0 ChipsetPlatform: msm8916 HardwareRevision: rev_10 LafSwVersion: 1.1 DeviceFactoryOutVersion: LGH345AT-00-V10f-TMO-US-AUG-16-2015+0 Dumping Security Backup... Reading modemst1 [15400, c00] Reading modemst1: OK Reading modemst2 [16000, c00] Reading modemst2: OK Backuping Security to file: Backups\H345KTGO_security_359562068097654_2015-11-19_4-18-47.sbf Writing security to file... Writing security to file: OK Dumping Security Backup: OK Flashing Patched Security... Writing modemst1 [15400, c00] Writing modemst1: OK Writing modemst2 [16000, c00] Writing modemst2: OK Flashing Patched Security: OK Switching to normal mode... Switching to normal mode: OK Writing NVM-Backup from file: Backups\H345KTGO_nvm_359562068097654_2015-11-19_4-7-21.sbf Flash NVM: Start Getting phone info... Getting phone info: OK Switching to NVM mode... Switching to NVM mode: OK Flashing NVM... Flashing NVM: OK Switching to normal mode... Switching to normal mode: OK Flash NVM: Finish Writing EFS-Backup from file: Backups\H345KTGO_efs_359562068097654_2015-11-19_4-12-21.sbf Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes Uploading file /nv/item_files/conf/cgps_me.conf 1.74 Kb Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes Uploading file /nv/item_files/conf/cgps_pe.conf 272 bytes Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes Uploading file /nv/item_files/conf/cgps_sm.conf 1.44 Kb Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 760 bytes Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb Uploading file /nv/item_files/conf/data_config_info.conf 5.06 Kb Uploading file /nv/item_files/conf/geran.conf 1.35 Kb Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes Uploading file /nv/item_files/conf/ims.conf 3.08 Kb Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb Uploading file /nv/item_files/conf/mc.conf 888 bytes Uploading file /nv/item_files/conf/mcfg.conf 216 bytes Uploading file /nv/item_files/conf/mcpm.conf 154 bytes Uploading file /nv/item_files/conf/mcs_cfcm.conf 240 bytes Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.12 Kb Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes Uploading file /nv/item_files/conf/mmgsdi.conf 1.69 Kb Uploading file /nv/item_files/conf/mmode.conf 2.39 Kb Uploading file /nv/item_files/conf/nas_mm.conf 1.42 Kb Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes Uploading file /nv/item_files/conf/onex_srch.conf 266 bytes Uploading file /nv/item_files/conf/pbm.conf 238 bytes Uploading file /nv/item_files/conf/ps_config_info.conf 491 bytes Uploading file /nv/item_files/conf/qmi_data.conf 88 bytes Uploading file /nv/item_files/conf/reg.conf 1.38 Kb Uploading file /nv/item_files/conf/rrc_feature.conf 43 bytes Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes Uploading file /nv/item_files/conf/uimdrv.conf 513 bytes Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 1.54 Kb Uploading file /nv/item_files/conf/wl1_ant_nv.conf 35 bytes Uploading file /nv/item_files/conf/wl1_ant_switch_band_nv.conf 47 bytes Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes Uploading file /nv/item_files/conf/wl1_dl_nv.conf 37 bytes Uploading file /nv/item_files/conf/wl1_fet.conf 41 bytes Uploading file /nv/item_files/conf/wl1_harq_buf_flush_tmr.conf 47 bytes Uploading file /nv/item_files/conf/wl1_nbr_nv.conf 44 bytes Uploading file /nv/item_files/conf/wl1_qta_rota.conf 37 bytes Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes Uploading file /nv/item_files/conf/wl1_srch_e1d_nv.conf 45 bytes Uploading file /nv/item_files/conf/wl1m_mdsp_recovery_nv.conf 46 bytes Uploading file /nv/item_files/conf/wl1ul.conf 40 bytes Uploading file /nv/item_files/conf/wms.conf 558 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_gps_victim_1x_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_hdr_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/im_desense_lte_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_1x_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/backoff/non_im_desense_gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/1x_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/disable_sw_mitigation 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm1_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm2_victim_gsm3_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm1_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm3_victim_gsm2_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_1x_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_hdr_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_lte_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_tdscdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/gsm_victim_wcdma_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/hdr_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/lte_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/tdscdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/blank/wcdma_victim_gsm_aggr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes Uploading file /nv/item_files/rfnv/00022982 529 bytes Uploading file /nv/item_files/rfnv/00023759 150 bytes Uploading file /nv/item_files/rfnv/00023761 150 bytes Uploading file /nv/item_files/rfnv/00024227 770 bytes Uploading file /nv/item_files/rfnv/00024229 827 bytes Uploading file /nv/item_files/rfnv/00024237 705 bytes Uploading file /nv/item_files/rfnv/00024253 778 bytes Uploading file /nv/item_files/rfnv/00024254 783 bytes Uploading file /nv/item_files/rfnv/00024255 764 bytes Uploading file /nv/item_files/rfnv/00024964 193 bytes Uploading file /nv/item_files/rfnv/00024965 193 bytes Uploading file /nv/item_files/rfnv/00024966 193 bytes Uploading file /nv/item_files/rfnv/00024967 193 bytes Uploading file /nv/item_files/rfnv/00024972 2.49 Kb Uploading file /nv/item_files/rfnv/00024973 2.49 Kb Uploading file /nv/item_files/rfnv/00024974 2.49 Kb Uploading file /nv/item_files/rfnv/00024975 2.49 Kb Uploading file /nv/item_files/rfnv/00025004 192 bytes Uploading file /nv/item_files/rfnv/00025005 192 bytes Uploading file /nv/item_files/rfnv/00025006 192 bytes Uploading file /nv/item_files/rfnv/00025007 192 bytes Uploading file /nv/item_files/rfnv/00025044 160 bytes Uploading file /nv/item_files/rfnv/00025045 160 bytes Uploading file /nv/item_files/rfnv/00025046 160 bytes Uploading file /nv/item_files/rfnv/00025047 160 bytes Uploading file /nv/item_files/rfnv/00025533 225 bytes Uploading file /nv/item_files/rfnv/00025535 225 bytes Uploading file /nv/item_files/rfnv/00025543 225 bytes Uploading file /nv/item_files/rfnv/00025618 1.00 Kb Uploading file /nv/item_files/rfnv/00025619 1.00 Kb Uploading file /nv/item_files/rfnv/00025620 1.00 Kb Uploading file /nv/item_files/rfnv/00025625 1.00 Kb Uploading file /nv/item_files/rfnv/00025626 1.00 Kb Uploading file /nv/item_files/rfnv/00025627 1.00 Kb Uploading file /nv/item_files/rfnv/00025632 1.00 Kb Uploading file /nv/item_files/rfnv/00025634 1.00 Kb Uploading file /nv/item_files/rfnv/00025642 1.00 Kb Uploading file /nv/item_files/rfnv/00025676 1.00 Kb Uploading file /nv/item_files/rfnv/00025678 1.00 Kb Uploading file /nv/item_files/rfnv/00025686 1.00 Kb Uploading file /nv/item_files/rfnv/00027473 131 bytes Uploading file /nv/item_files/rfnv/00027474 131 bytes Uploading file /nv/item_files/rfnv/00027475 131 bytes Uploading file /nv/item_files/rfnv/00027476 131 bytes Uploading file /nv/item_files/rfnv/00027477 131 bytes Uploading file /nv/item_files/rfnv/00027478 131 bytes Uploading file /nv/item_files/rfnv/00027479 131 bytes Uploading file /nv/item_files/rfnv/00027481 131 bytes Uploading file /nv/item_files/rfnv/00027482 131 bytes Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes Uploading file /nv/reg_files/conf/policyman.conf 172 bytes Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything). Unlock: Finish Phone successfully unlocked same here 2 not unlock |
The Following User Says Thank You to h666h For This Useful Post: |
