09-28-2012, 20:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Mars
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | LG KU580 not turn on the phone will not turn on after unlock !!! but detected by setool for unlock you can help me for this problem Code: 28/09/2012 20:50:40 SIGNED MODE (USING SERVER) 28/09/2012 20:50:40 CFG:100000000000 28/09/2012 20:50:57 ChipID: C802, EMP protocol: 0401 28/09/2012 20:50:57 BOOTROM MODE DETECTED 28/09/2012 20:50:57 OTP DBG: [1,54,0,35473801147764] 28/09/2012 20:50:58 OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN 28/09/2012 20:50:58 LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E 28/09/2012 20:50:58 LDR CAPS: SYSTEM SIGNATURE 28/09/2012 20:51:00 LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F 28/09/2012 20:51:00 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM 28/09/2012 20:51:00 WRITING CLEAR SIMLOCK UNITS ... 28/09/2012 20:51:00 SIMLOCK CODES SET TO "81217532" 28/09/2012 20:51:00 SIGNING ... 28/09/2012 20:51:00 Unlock DONE 28/09/2012 20:51:00 Elapsed: 20 secs. akh84 |
The Following User Says Thank You to akh84 For This Useful Post: |
09-28-2012, 20:05 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
Regards | |
The Following User Says Thank You to Haicha For This Useful Post: |
09-28-2012, 20:07 | #3 (permalink) |
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | thanks bro for you'r reply how and what firmware flasher log LGE TOOL 1.78 Code: Connecting with KU580 Warning: For proper work, battery must be fully charged Reconnect battery and connect cable to the phone Port opened, waiting for phone ping... CPU: DB3150 P2B/R2A Ericcson Mobile Platform: v4.1 Chip Class: DB31xx Fuse Locks: RETAIL SECURITY Security Domain (Color): BLUE (factory) OTP Lock: Locked OTP CID: 54 OTP PAF: 0 OTP IMEI: 35473801147764000 Flash CID: 54 Flash PAF: 0 IMEI: 354738-01-147764-0-00 Effective CID: 54 Effective PAF: 0 Sending ACC Preloader Sending APP Preloader Sending ACC Loader Sending APP Loader data port: timeout: Last edited by akh84; 09-28-2012 at 20:16. |
09-28-2012, 21:11 | #4 (permalink) |
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | report flash can not flash Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "C:\SETOOL\BIN-KU580W-V10a-OCT-15-2007-OPEN-NLD\cxc000000_U300_PHONE_MCP_NAND_B26.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 396 blocks ... llbug: blk write fail.fatal [A2_fout_ssw] can't send NET packet subblock (00CA0000/00010000) NAK Elapsed: 58 secs. |
09-28-2012, 23:03 | #8 (permalink) |
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | write GDFS error !!! Code: SIGNED MODE (USING SERVER) CFG:100000000000 Will write GDFS now. ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM will write 254 units [gdfs_writevar] err: 000B Elapsed: 11 secs. |
09-29-2012, 11:09 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | flash Code: dist\gdfs_in_ssw_format\A2\ku580_drm_fix.ssw dist\gdfs_in_ssw_format\A2\ku580_syspart_fix.ssw |
The Following User Says Thank You to the_laser For This Useful Post: |
09-29-2012, 13:46 | #10 (permalink) | |
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | Quote:
but still the same problem the phone will not turn on Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "C:\SETOOL\gdfs_in_ssw_format\A2\ku580_drm_fix.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 9 blocks ... SSW file accepted writing "C:\SETOOL\gdfs_in_ssw_format\A2\ku580_syspart_fix.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 54 Will flash 9 blocks ... SSW file accepted Elapsed: 24 secs. Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "52836888" SIGNING ... Unlock DONE Elapsed: 9 secs. | |
09-29-2012, 17:13 | #12 (permalink) |
Member: 1733938 Status: Offline Sonork: 100.1617311 Thanks Meter: 34 | all ok but phone always off Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "C:\SETOOL\BIN-KU580W-V10a-OCT-15-2007-OPEN-NLD\cxc000000_U300_PHONE_MCP_NAND_B26.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 396 blocks ... SSW file accepted writing "C:\SETOOL\BIN-KU580W-V10a-OCT-15-2007-OPEN-NLD\KU580_FS_Img.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 1174 blocks ... SSW file accepted writing "C:\SETOOL\BIN-KU580W-V10a-OCT-15-2007-OPEN-NLD\KU580_FS_LGPXO_Img.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 307 blocks ... SSW file accepted Elapsed: 566 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM writing "C:\SETOOL\gdfs_in_ssw_format\A2\ku580_drm_fix.ssw" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 54 Will flash 9 blocks ... SSW file accepted writing "C:\SETOOL\gdfs_in_ssw_format\A2\ku580_syspart_fix.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 54 Will flash 9 blocks ... SSW file accepted Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35473801147764] OTP: LOCKED:1 CID:54 PAF:0 IMEI:35473801147764 CERT:BROWN LDR: 070413 1407 HYDCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_P3E LDR CAPS: SYSTEM SIGNATURE LDR: 070609 0828 HYDCXC1721611_1A2_DB31XX_PRODUCTION_LOADER_APP_SDRAM_NAND_P3F LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "03524722" SIGNING ... Unlock DONE Elapsed: 6 secs. |
09-29-2012, 17:21 | #13 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | was phone in working state, when you unlocked it ? i'm just tested ku580 unlock feature with current setool2 version and phone boot up just fine after unlock operation. anyway, here is last solution you could try to revive phone: 1. write repair flash BIN-KU580W-V10a-OCT-15-2007-OPEN-NLD.cry ( support area path: "/lg3g phones/ku580/ROM_IMAGE_FOR_REPAIR/" ) 2. break with "error: 33" at the very end, it is OKAY 3. now flash phone with normal flashes (all 3 - main,fs,pxo) 4. if phone do not have network coverage, write gdfs ( put dist\gdfs_in_bin_format\A2\Ku580\ku580_gdfs.zip in misc. edit , press write gdfs ) do not forget to remove and insert battery after each step of procedure. if after that phone still refuse to work, it is hardware problem. ps. this is not official support area, i'm writing here only if i have good mood and not visiting that section often. use official setool2 support forum, if you want full attention from my side. |
