09-07-2009, 13:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Post here succesfully REPAIRED phones by new version of setool (>=0.915043) Code: CFG:00000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 28 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306501496208 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:10000000000000 RESET MODE STARTED RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306501496208 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 12 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306501496208 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID check:2019 Flash props sent ok writing "D:\Stuff\Boxes\SeTool\Setool2g\gdfs_in_ssw_format\db2020\Z710_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "45350635" SIGNING... Elapsed: 43 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306501496208 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID check:2019 Flash props sent ok writing "D:\Stuff\Boxes\SeTool\Setool2g\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "35777177" SIGNING... Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306501496208 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 FLASH ID check:2019 Flash props sent ok writing "D:\Stuff\Boxes\SeTool\firmwares\Sony Ericsson\z710\R1JC002_RED52\R1JC002_1250434_GENERIC_CN.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "D:\Stuff\Boxes\SeTool\firmwares\Sony Ericsson\z710\R1JC002_RED52\R1JC002_FS_AMERICA_2_CN_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 2660 Will flash 133 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached |
09-07-2009, 13:45 | #2 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Z550a repaired as well! Code: SIGNED MODE (USING SERVER) CFG:10000000000000 RESET MODE STARTED NEW SECURITY (MARITA RESPIN) PHONE RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501431061 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 24 secs. CFG:00000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501431061 CERT:BROWN LDR:DB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID check:897E Flash props sent ok writing "D:\Stuff\Boxes\SeTool\Setool2g\gdfs_in_ssw_format\db2010\z550_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "12462761" SIGNING... Elapsed: 102 secs. CFG:00000000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501431061 CERT:BROWN LDR:DB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID check:897E Flash props sent ok writing "D:\Stuff\Boxes\SeTool\Setool2g\eroms\db2010\db2012_erom_cid51.ssw" CURRENT FLASH FILE CID:36 Matching CID according file... SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "46164267" SIGNING... Elapsed: 26 secs. SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501431061 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID check:897E Flash props sent ok writing "D:\Stuff\Boxes\SeTool\firmwares\Sony Ericsson\z550\R6GA004_CXC1250583_ML_RED_CID51.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 6780 Will flash 339 blocks... SSW loading returns:0 writing "D:\Stuff\Boxes\SeTool\firmwares\Sony Ericsson\z550\R6GA004_FS_ROGERS_ML_RED_CID51.ssw" CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 1940 Will flash 97 blocks... SSW loading returns:0 LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 587 secs. |
The Following User Says Thank You to y3kt For This Useful Post: |
09-07-2009, 14:44 | #5 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Procedure is simple: 1) Select model 2) Tick SIGNED MODE and fill username/password for server (this is required, if you don't hav account then buy one) 3) Now press RECOVERY and phone will be reseted and converte to brown 4) Go to Empty Fill Tab and flash GDFS IN SSW format 5) If step 4) was Ok then flash EROM with rewuired CID 6) Flash phone now (MAIN+FS+CUSTOMIZATION) Now your phone should be alive if is not hardware damaged. You need to use COM/UFS as interface for DB20xx, for DB2020 you can use USB as well, Luck! |
09-07-2009, 17:22 | #6 (permalink) |
Insane Poster Join Date: Nov 2007 Location: london
Member: 627707 Status: Offline Thanks Meter: 10 | GDFS repaired on a K800i. Code: 07/09/2009 11:52:46 v0.915043/UNI 07/09/2009 11:52:46 CARD SERIAL: XXXXXXXX 07/09/2009 11:52:46 Loaded 51 flash descriptors 07/09/2009 11:56:11 CFG:00000000000000 07/09/2009 11:56:28 ChipID:9900,EMP protocol:0301 07/09/2009 11:56:28 BOOTROM MODE DETECTED 07/09/2009 11:56:28 Speed:921600 07/09/2009 11:56:28 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXX CERT:N/A 07/09/2009 11:56:29 FLASH CID:49 COLOR:BROWN 07/09/2009 11:56:29 LDR:060721 1021 DB2020_SERVICE_LOADER 07/09/2009 11:56:29 FLASH ID check:897E 07/09/2009 11:56:29 Flash props sent ok 07/09/2009 11:56:29 writing "C:\Documents and Settings\Work\Desktop\v0.915043\gdfs_in_ssw_format\db2020\K800_GDFS_SSW.ssw" 07/09/2009 11:56:31 CURRENT FLASH FILE CID:49 07/09/2009 11:56:31 SSW uses full hash, hash len is: 640 07/09/2009 11:56:31 Will flash 32 blocks... 07/09/2009 11:56:47 SSW loading returns:0 07/09/2009 11:56:47 Setting up GDFS... 07/09/2009 11:56:48 OTP WRITE NOT EXECUTED 07/09/2009 11:56:48 WRITING CLEAR SIMLOCK UNITS... 07/09/2009 11:56:49 SIGNING... 07/09/2009 11:56:49 Elapsed: 38 secs. 07/09/2009 13:11:49 CFG:00000000000000 07/09/2009 13:12:10 ChipID:9900,EMP protocol:0301 07/09/2009 13:12:10 BOOTROM MODE DETECTED 07/09/2009 13:12:10 Speed:921600 07/09/2009 13:12:10 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXX CERT:N/A 07/09/2009 13:12:10 FLASH CID:49 COLOR:BROWN 07/09/2009 13:12:28 LDR:060721 1021 DB2020_SERVICE_LOADER 07/09/2009 13:12:28 FLASH ID check:897E 07/09/2009 13:12:28 Flash props sent ok 07/09/2009 13:12:28 writing "C:\Documents and Settings\Work\Desktop\v0.915043\eroms\db2020\DB2020EROM_CNV_RED49_BROWN_CID49_DB2020.ssw" 07/09/2009 13:12:29 CURRENT FLASH FILE CID:49 07/09/2009 13:12:29 SSW uses full hash, hash len is: 80 07/09/2009 13:12:29 Will flash 4 blocks... 07/09/2009 13:12:31 SSW loading returns:0 07/09/2009 13:12:32 Setting up GDFS... 07/09/2009 13:12:32 OTP WRITE NOT EXECUTED 07/09/2009 13:12:32 WRITING CLEAR SIMLOCK UNITS... 07/09/2009 13:12:34 SIGNING... 07/09/2009 13:12:34 Elapsed: 45 secs. 07/09/2009 13:15:56 Loaded 51 flash descriptors 07/09/2009 13:21:29 SIGNED MODE (USING SERVER) 07/09/2009 13:21:29 ALTERNATIVE SECURITY BYPASS ENABLED 07/09/2009 13:21:29 PRELOADER SECURITY BYPASS ENABLED 07/09/2009 13:21:29 CFG:10110000000000 07/09/2009 13:21:33 ChipID:9900,EMP protocol:0301 07/09/2009 13:21:33 07/09/2009 13:21:33 PHONE STATE: "RETAIL" 07/09/2009 13:21:33 FLASH CID: 0049 07/09/2009 13:21:33 Speed:921600 07/09/2009 13:21:33 FLASH ID check:897E 07/09/2009 13:21:33 Flash props sent ok 07/09/2009 13:21:33 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXX CERT:RED 07/09/2009 13:21:33 FLASH CID:49 COLOR:RED 07/09/2009 13:21:34 07/09/2009 13:21:34 Model (from GDFS):K800i 07/09/2009 13:21:34 MAPP CXC article: R1ED001 prgCXC1250210_GENERIC_WI 07/09/2009 13:21:34 MAPP CXC version: R1ED001 07/09/2009 13:21:34 Language Package: TEMS 07/09/2009 13:21:34 CDA article: CDA12345678/123 07/09/2009 13:21:35 CDA version: R2A 07/09/2009 13:21:35 Default article: cxc1722435 07/09/2009 13:21:35 Default version: R2B 07/09/2009 13:21:35 PROVIDER: 000-00 07/09/2009 13:21:35 SIMLOCKS NOT DETECTED 07/09/2009 13:21:35 07/09/2009 13:21:35 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 07/09/2009 13:21:35 07/09/2009 13:21:35 BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 07/09/2009 13:21:35 07/09/2009 13:21:35 SECURITY UNITS BACKUP CREATED. 07/09/2009 13:21:35 Elapsed: 5 secs. 07/09/2009 13:22:14 SIGNED MODE (USING SERVER) 07/09/2009 13:22:14 CFG:10001000000000 07/09/2009 13:22:18 ChipID:9900,EMP protocol:0301 07/09/2009 13:22:18 07/09/2009 13:22:18 PHONE STATE: "RETAIL" 07/09/2009 13:22:18 FLASH CID: 0049 07/09/2009 13:22:18 Speed:921600 07/09/2009 13:22:19 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXX CERT:RED 07/09/2009 13:22:19 FLASH CID:49 COLOR:RED 07/09/2009 13:22:20 PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 07/09/2009 13:22:20 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 07/09/2009 13:22:20 FLASH ID check:897E 07/09/2009 13:22:20 Flash props sent ok 07/09/2009 13:22:20 writing "C:\Flash Files\Setool\SONY ERICSSON FLASH FILES\DB2020\K800i\CID 49\M\R1ED001_1250210_GENERIC_WI.ssw.cry" 07/09/2009 13:22:24 CURRENT FLASH FILE CID:49 07/09/2009 13:22:24 SSW uses full hash, hash len is: 9100 07/09/2009 13:22:25 Will flash 455 blocks... 07/09/2009 13:26:09 SSW loading returns:0 07/09/2009 13:26:09 writing "C:\Flash Files\Setool\SONY ERICSSON FLASH FILES\DB2020\K800i\CID 49\FS\R1ED001_EUROPE_2_fs.ssw.cry" 07/09/2009 13:26:12 CURRENT FLASH FILE CID:49 07/09/2009 13:26:12 SSW uses full hash, hash len is: 4420 07/09/2009 13:26:13 Will flash 221 blocks... 07/09/2009 13:28:18 SSW loading returns:0 07/09/2009 13:28:21 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 07/09/2009 13:28:21 loader startup: executed 07/09/2009 13:28:35 loader GDFS startup: executed 07/09/2009 13:28:42 loader filesystem startup: executed 07/09/2009 13:28:42 loader unlock: executed 07/09/2009 13:28:42 using GENERIC phone customization 07/09/2009 13:28:42 tpa/preset/custom/C3_PCA_G3v2.cer 07/09/2009 13:28:42 tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm 07/09/2009 13:28:42 tpa/preset/custom/customize.xml 07/09/2009 13:28:43 tpa/preset/custom/DESKTOP_HOOK_2.itm 07/09/2009 13:28:43 tpa/preset/custom/Entrust.net Root Certificate.cer 07/09/2009 13:28:43 tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt 07/09/2009 13:28:43 tpa/preset/custom/FM_PICTURES_HOOK_3.itm 07/09/2009 13:28:43 tpa/preset/custom/FM_SOUNDS_HOOK_3.itm 07/09/2009 13:28:44 tpa/preset/custom/FM_THEMES_HOOK_3.itm 07/09/2009 13:28:44 tpa/preset/custom/FM_VIDEOS_HOOK_3.itm 07/09/2009 13:28:44 tpa/preset/custom/GAMES_HOOK_3.itm 07/09/2009 13:28:44 tpa/preset/custom/GTE_CyberTrust_Root.cer 07/09/2009 13:28:44 tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt 07/09/2009 13:28:45 tpa/preset/custom/Root.cer 07/09/2009 13:28:45 tpa/preset/custom/SEMC_E2E_Root_CA.crt 07/09/2009 13:28:45 tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm 07/09/2009 13:28:45 tpa/preset/custom/ThawtePremium.der 07/09/2009 13:28:45 tpa/preset/custom/ThawteServerCA.cer 07/09/2009 13:28:45 tpa/preset/custom/Utiroot.cer 07/09/2009 13:28:45 tpa/preset/custom/VeriSignClass3Root.cer 07/09/2009 13:28:46 tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt 07/09/2009 13:28:46 Phone detached 07/09/2009 13:28:47 Elapsed: 392 secs. |
09-07-2009, 17:36 | #7 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Bhumi Sang Mpu Aryya Wiraraja.
Member: 616567 Status: Offline Thanks Meter: 187 | Quote:
1. Select phone model. 2. Only tick signed mode in Setting tab.. 3. Back to main tab and just press "Recovery" 4. Phone will be converted to Brown state. 5. Go to empty fill and add needed gdfs in ssw format and press "Flash" button. 6. The add needed erom file and press flash.. 7. Last step is to full flash the phone... | |
6300 blue screen..succesfully repaired phone by mixkey 3.2 ver5.0 | xander_0375 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 09-13-2009 00:25 |
Post all Succesfully Repaired Phones using McnPro Box | PhoneCareCenter | McnPro Box | 11 | 07-18-2009 16:25 |
someone who killed any phone with different version of terminator 2.0??? | Wriwolff | Sony Ericsson | 1 | 01-18-2003 10:23 |
