Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 12-13-2009, 11:55   #1 (permalink)
Member: 542963
loader GDFS startup failed, that is fatal k310
v0.915057/UNI
CARD SERIAL: 00042612
Loaded 51 flash descriptors
CFG:000000000000
llbug: COM5 open error: "The system cannot find the file specified"
Can't load ID loader !
Elapsed: 1 secs.
CFG:000000000000
llbug: COM6 open error: "The system cannot find the file specified"
Elapsed: 1 secs.
CFG:000000000000
ChipID:8040,EMP protocol:0301
NEW SECURITY (MARITA RESPIN) PHONE
PHONE STATE: "RETAIL"
FLASH CID: 0050
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:50 PAF:1 IMEI:35727501743861 CERT:RED
FLASH CID:50 COLOR:RED
setGDFS_params failed
failed to setup GDFS
Elapsed: 7 secs.
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
PRELOADER SECURITY BYPASS ENABLED
CFG:111100000000
FLASH CID: 0050
Speed:921600
LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695
FLASH ID:897E
LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009
loader startup: executed
GDFS startup failed,error is 04 [1D]
Elapsed: 11 secs.
POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
PHONEBOOK NOT DETECTED IN GDFS FILE
CFG:101000000100
Will write GDFS now.
FLASH CID: 0050
Speed:921600
FLASH ID:897E
Elapsed: 16 secs.
Old 12-13-2009, 12:06   #2 (permalink)
Member: 302596
use USB cable to unlock this phone
The Following User Says Thank You to maxieboy For This Useful Post:
Old 12-13-2009, 12:07   #3 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
bro select main file and flash it and dont chek any box in option............................ok
ak
Old 12-13-2009, 12:26   #4 (permalink)
Member: 542963
k310
thanx brother now want to know k310 cid 52 unlock free or not
Old 12-13-2009, 12:32   #5 (permalink)
Member: 302596
CID 52 if free.. just use test sim
Old 12-13-2009, 12:53   #6 (permalink)
algerienbox's Avatar
Member: 591880
*creat restore
*check 1/2/3 in seeting
*clic unlock/repair
you need a teste sim for that
please help K750i dead loader GDFS startup failed, that is fatal samirtelecom Sony Ericsson 10 11-28-2010 14:41
loader GDFS startup failed, that is fatal abuzarkhurram SETool2 18 07-18-2009 14:36
W610i loader GDFS startup failed, that is fatal mohit_kripalu01 Sony Ericsson Hardware Repair Area 9 02-26-2009 15:11
W610i loader GDFS startup failed, that is fatal mohit_kripalu01 Sony Ericsson Hardware Repair Area 7 02-25-2009 04:16
k310i loader fs startup failed, that is fatal Chandreshswami SETool2 2 07-29-2008 09:17
Page generated in 0.27234 seconds with 11 queries
