Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Oct 2007
Member: 603261 Status: Offline Thanks: 105
| lt15a unlock problem Hi, i have a problem wit lt15a with setool, I have update my setool to the last version Phone has TAMPERED HWConfig, you must rebuild it. |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010 Age: 3
Member: 1315677 Status: Offline Thanks: 304
| post #10 HOW TO WORK WITH SEMC PDA PHONES |
| The Following User Says Thank You to :Aishur: For This Useful Post: |
| | #3 (permalink) |
| I have done as the procedure, actually I have done 2 MT16 yesterday, but this is new for me, I donīt know what does it means? Phone has TAMPERED HWConfig, you must rebuild it. Here is the log of the operation SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: C7B5E0937F5CF57727939CC2D52CF1247D7715A1 FLASH ID: "0098/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 01268xxxxxxx Phone has TAMPERED HWConfig, you must rebuild it. Unlock FAILED Elapsed: 39 secs. Can anyone explain me? Thanks |
| | #4 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2006 Location: Club-Berry Age: 35
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks: 3,708
| Have you followed the post Aishur showed to you? You need to completely repair phone. It is easy process. I can provide lt15a gdfs backup from working phone if you need. I have already repaired a couple of phones with this procedure. Let me know if you need it |
| The Following User Says Thank You to y3kt For This Useful Post: |
| | #5 (permalink) |
| the log output is correct, we assume you use the latest setool version. if the IMEI is correct and the phone is working, better to ask the_laser at setool forum anyway you can try tick 1+2+5+8 press unlock/repair and enter le correct imei when asked. |
| | #6 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: ATF Earth Age: 25
Member: 598395 Status: Online Thanks: 623
| Quote:
RUNNING v 1.1204/01.15/UNI CARD SERIAL 000xxxxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 61B01AEA77BA074EA71804E72144B60A247BA781 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 012685xxxxxxx Phone has TAMPERED HWConfig, you must rebuild it. Unlock FAILED Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 61B01AEA77BA074EA71804E72144B60A247BA781 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 012685xxxxxxxx Checking for signature ... Waiting for calculation process ... No credits left. signature calculation not done,err: 144 Unlock FAILED Elapsed: 18 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010010000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 61B01AEA77BA074EA71804E72144B60A247BA781 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01268xxxxxxxx Checking for signature ... REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 158 secs. | |
| The Following User Says Thank You to Sahil2007 For This Useful Post: |
| | #7 (permalink) |
| Hi, these are trim areas read from working phones, with these you can repair damaged gdfs phones. Don't use lt15i with lt15a phones and viceversa because you will not get network on the repaired phone. Luck! |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 280342 Status: Offline Thanks: 605
| DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: 9C0601254BF84BC4EC814B22612CABDE7E98C60F FLASH ID: "0098/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 01268700093439 REQUESTED : 01268700093419 Checking for HWConfig ... Waiting for calculation process ... RESPONSE: "SUCCESS" [826] Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1256] WRITING SEMCBOOT ... WRITING HWCONFIG ... Unlock DONE network on?????????????????????????? |
| The Following User Says Thank You to shadigsm For This Useful Post: |
| | #9 (permalink) | |
| Quote:
can you plz explain how to add those file to the SETOOLS Program Regard | |
| | #10 (permalink) | |
| Quote:
| | #13 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Sep 2008
Member: 854135 Status: Offline Thanks: 48
| Quote:
Finally I followed the post in setool support and I used the gdfs files that Y3k shared for me. The phone is unlocked and flashed with flash file of support but right now it doesnīt work without charger, I mean that when I power on the phone it starts but it inmediatly shows battery 0% and power off, and if I power it on with charger conected it works OK, at very beginning I thought that it was a battery problem but I have read that maybe itīs a bug of software. Can any one have any experience with this kind of problem? Thanks again. | |
| | #14 (permalink) |
| There is a free method to fix 0% battery problem, just search here in forum and you will find it! Luck! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
