11-16-2011, 12:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Dublin
Member: 746630 Status: Offline Thanks Meter: 23 | LT15i ARC dead after unlock please help Experia Arc LT15i, setool vercion 1.1201 Try to flash I couldn't, setool doesn't see the phone. any way to make it alive except riff jtag? Thank you |
01-14-2012, 02:07 | #6 (permalink) |
Member: 746630 Status: Offline Thanks Meter: 23 | Here is the procedure but doesn't work for me can't load trim area,how to repair totally damaged s1 android phones, based on msm7227,qsd8250, using alternative security bypass using testpoint? a: Here is procedure. okay, here is example how to resurrect totally dead x10 phone. so, we have x10 phone with totally erased semcboot and trim area. phone does not turn on, does not connect to pc anyhow. lets resurrect it. run setool2, select x10 as model, select com port as interface ( one where GPG resurrection cables connected ) 1. on options set signed mode,altbypass mode, use testpoint (gnd type) 2. connect GPG x10 resurrection craddle to phone, press RECOVERY follow program instructions. important notice: for msm7227 phones, insert battery in phone after you attach testpoint. btw, as phone has erased semcboot, you do not need apply testpoint that time. however, that is very special case, so for simplicity lets apply testpoint all time. here is operation output: Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT ATTACH USB CABLE TO PHONE,THEN PRESS "READY" PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" RUNNING S1_LOADER VER "R4A024" SWITCHING TO "USB" ... PLEASE ATTACH TURNED OFF PHONE NOW RUNNING S1_LOADER VER "R4A024" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A024" WRITING SEMCBOOT ... Checking TA ... MINOR ERROR [ MISC_CLASS: MISC_ERROR, TA_set_config_failed ] Writing config ... MINOR ERROR [ MISC_CLASS: MISC_ERROR, TA_invalid,_format_may_be_required ] Formatting ... Checking MISC TA ... MINOR ERROR [ MISC_CLASS: MISC_ERROR, TA_invalid,_format_may_be_required ] Writing config ... MINOR ERROR [ MISC_CLASS: MISC_ERROR, TA_invalid,_format_may_be_required ] Formatting ... SUCCESS now we recovered semcboot and prepared trim area for loading. if phone only had erased semcboot, it will already work after that step. but our phone TOTALLY damaged, so lets proceed with second step: we need now load trim area. options are same for step1 + "format gdfs when writing" checked, select x10.zip in misc.edit and press "write gdfs". ( any trim area, read from corresponding model live phone will work ) follow program instructions. here is operation output: Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000110 Will write GDFS now. DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT ATTACH USB CABLE TO PHONE,THEN PRESS "READY" PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" RUNNING S1_LOADER VER "R4A024" SWITCHING TO "USB" ... PLEASE ATTACH TURNED OFF PHONE NOW RUNNING S1_LOADER VER "R4A024" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A024" Can't get IMEI will write 1010 units done will write 53 units done Phone detached Elapsed: 23 secs. finally, we need rebuild imei and security zone. for that, check same options as for step1 + "do full unlock instead of usercode reset","allow to change imei when unlocking" checked, press "unlock/repair", follow program instructions here is operation output: Code: THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010010010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT ATTACH USB CABLE TO PHONE,THEN PRESS "READY" PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" RUNNING S1_LOADER VER "R4A024" SWITCHING TO "USB" ... PLEASE ATTACH TURNED OFF PHONE NOW RUNNING S1_LOADER VER "R4A024" LOADER AID: 0001 FLASH ID: "002C/00B3" LOADER VERSION: "r4A024" Can't get IMEI REQUESTED : 359419030xxxxx Checking for HWConfig ... Waiting for calculation process ... RESPONSE: "SUCCESS" [826] Checking for signature ... signature found, skipping calculation WRITING SEMCBOOT ... WRITING HWCONFIG ... Unlock DONE Elapsed: 20 secs. from now on, phone is full repaired, testpoint cradle not needed. reflash phone with any suitable firmware. q: how to repair totally damaged s1 android phones, based on qsd8x55, using alternative security bypass using testpoint? a: operation is very same, just select usb as interface and do not check "use testpoint (gnd type)" |
The Following User Says Thank You to evaireland For This Useful Post: |
