Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2008
Member: 834998 Status: Offline Thanks: 165
| Lt18 xperia arc unlock failed SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT ATTACH USB CABLE TO PHONE,THEN PRESS "READY" PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 13 secs. |
| | #3 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2012 Location: Anaheim Hills,Chandler,USA Age: 27
Member: 1729975 Status: Online Sonork: 100.1595998 Thanks: 1,694
| instead of this Quote:
Remove Test Point put battery and Press Ready... USB hub cannot supply sufficient to the phone | |
| | #4 (permalink) |
| PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R9B031" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: A50ED08AA9835C89C668089ECD002C43F66DFB56 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI : 35344005132842 MODEL (from GDFS): LT18i SOFTWARE VERSION: 1253-8238_4.0.2.A.0.62 CUSTOM VERSION: 1255-2667_R8D FILESYSTEM VERSION: WORLD-i_4.0.2.A.0.62 SERIAL NO: BX9031RNTQ |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: CASTELLI - BS.AS - ARGENTINA
Member: 1057178 Status: Offline Sonork: UseGooGle Thanks: 252
| Unlock done by usb. bad Untick Setool Options! try this... INSTALL ADB DRIVERS ++++++++++++++++ Tick Sign.. Tick By Pass.... Droid 2.x or up ++++++++++++++++ Code: DEVICE ID: 66453F2BC2CC4D0C57BEC31B4381AF37D0B72EA6 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01268400259992 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1187] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... FINALIZING ... Unlock DONE Elapsed: 264 secs. br Polaco |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2003 Location: NIGERIA, HEART OF AFRICA
Member: 34594 Status: Offline Thanks: 24
| if you are using a window 7 operating system, you might consider trying it on an xp. it happen to me sometime but was solved with an xp operating system. d fone does not require batt for unlocking, just make sure ur testpoint is right and follow d on-screen instruction. BR Ayoade |
| The Following User Says Thank You to ayoade For This Useful Post: |
| | #12 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks: 956
| Quote:
| The Following User Says Thank You to yassinek85 For This Useful Post: |
| | #14 (permalink) |
| Junior Member ![]() ![]() Join Date: Mar 2007
Member: 477064 Status: Offline Thanks: 8
| Quote: REMOVE TESTPOINT NOW, THEN PRESS "READY" do this Remove Test Point put battery and Press Ready... USB hub cannot supply sufficient to the phone good job its work |
| The Following User Says Thank You to kamel0404 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:06 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
