06-24-2012, 12:10 | #1 (permalink) |
Insane Poster Join Date: Dec 2010 Location: SPEEDTECH Mobile Solution Age: 36
Member: 1467522 Status: Offline Sonork: 100.1596014 Thanks Meter: 32 | LU6800 Pattern Lock Factory Reset By LGE Tool Tool's - Se Tool Activated LGE - CA-101 USB Cable Procedure Code: To connect the phone you should enter into download mode Or via service menu in normal mode - switch usb to cp Mind that the accumulator should be fully charged If you need to enter into the service menu type "3845#*6800#" in the number dialing window If the phone doesnt load into normal mode due to a corruption you can launch it in download mode manually: To switch to Download Mode you should disconnect cable and power off the phone. Then push and hold volume up button and while holding them connect the cable to the phone |
The Following User Says Thank You to speedXtech14 For This Useful Post: |
10-12-2012, 05:22 | #2 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | To connect the phone you should remove accumulator and then connect the cable to the handset If you need to enter into the LG service menu type "3845#*6800#" in the number dialing window To enter the provider hidden menu you need type service password which is shown in the log then type service password once more Usually the service password is 147789 Connecting with LU6800 data port: timeout: Connecting with LU6800 data port: timeout: Connecting with LU6800 Phone not found. Please connect phone to PC. Action cancelled Connecting with LU6800 data port: timeout: Connecting with LU6800 Action cancelled Connecting with LU6800 data port: timeout: Connecting with LU6800 Firmware Version: LU680128 Bluetooth Address: A8:92:2C:48:F1:72 Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 00:33:02 Connect mode: Normal Meid unlock code 03de0dba00875f6b Firmware Version: LU680128 SPC: 000000 MEID: A1000019A388D1 Mobile ESN: 805922C9 Bluetooth Address: A8:92:2C:48:F1:72 Phone Number(MDN): 09696730817 min1: 6730817 min2: 969 SSD_A: 245E951D391F5FCC SSD_B: 995DCE214F1B7D48 AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 428 MNC: 0 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually OMAP User Data Clear Done AP part has been successfully reseted If you want to continue work with the handset you should reconnect it with special buttons pressed as you did it when you connected the first time Don't forget to restart the phone Factory defaults successfully restored |
11-03-2015, 09:14 | #3 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | LG LU6800 gmail unlocked OK LGE Tool version: 2.45 OS Version: Windows 7 [NT 6.1] Administrative privileges: yes Locale: UnitedStates / English CPU frequency: 2095 MHz Total memory: 3021 MB Free memory: 1060 MB Free space on system disk C:\: 171.00 GB Free space on disk E:\: 295.00 GB You are not using Windows XP. Correct work can only be guaranteed on Windows XP operating system. Connecting with LU6800 Firmware Version: LU680128 Bluetooth Address: 70:05:14:43:34:5E Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 00:33:02 Connect mode: Normal Meid unlock code 013513ff01a7ab2f Firmware Version: LU680128 SPC: 000000 MEID: A00000312BCFAD Mobile ESN: 80109884 Bluetooth Address: 70:05:14:43:34:5E Phone Number(MDN): 01055679630 min1: 5679630 min2: 015 SSD_A: 7EBF8113E59F8816 SSD_B: 025DCAD2FC788B9A AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 450 MNC: 6 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually Protocol: Invalid response:OMAP failed to answer Don't forget to restart the phone Disconnected Connecting with LU6800 Firmware Version: LU680128 Bluetooth Address: 70:05:14:43:34:5E Connected Receiving phone info Firmware Released: 19:00:00 Firmware Compiled: 00:33:02 Connect mode: Normal Meid unlock code 013513ff01a7ab2f Firmware Version: LU680128 SPC: 000000 MEID: A00000312BCFAD Mobile ESN: 80109884 Bluetooth Address: 70:05:14:43:34:5E Phone Number(MDN): 01000000000 min1: 0000000 min2: 100 SSD_A: 0000000000000000 SSD_B: 0000000000000000 AKEY: 00000000000044967056 User Lock Code: 0000 MCC: 450 MNC: 6 Info received Restoring to factory defaults Cant switch the mobile phone to download mode You can make it manually OMAP User Data Clear Done AP part has been successfully reseted If you want to continue work with the handset you should reconnect it with special buttons pressed as you did it when you connected the first time Don't forget to restart the phone Factory defaults successfully restored |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
