10-05-2011, 06:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | m5650 still same problem........setool fail..? i flash it with setool. but still no luck. setool i am fail to solw this. pls correct me where i'm wrong see log Code: RUNNING v 1.1108/01.10/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:D900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDRAM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_RC.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 763 blocks ... ssw file accepted SIGNING ... Elapsed: 597 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:D900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDRAM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... [A2_fout_ssw] can't get ACK subblock (00520000/00010000) NAK Elapsed: 41 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:D900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDRAM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted SIGNING ... Processing script "D:\setool\M5650\m5650xija1.gdfs" ... Writing ACC GDFS var 0000/0002/0004 Writing ACC GDFS var 0000/0003/0004 Writing ACC GDFS var 0000/0004/0001 Writing ACC GDFS var 0000/0006/0006 Writing ACC GDFS var 0000/0007/0001 Writing ACC GDFS var 0000/0008/0001 Writing ACC GDFS var 0000/0009/0028 Writing ACC GDFS var 0000/000A/0028 Writing ACC GDFS var 0000/000E/000C Writing ACC GDFS var 0000/000F/0002 Writing ACC GDFS var 0000/0027/0008 Writing ACC GDFS var 0000/0028/0008 Writing ACC GDFS var 0000/0029/0008 Writing ACC GDFS var 0000/002A/0008 Writing ACC GDFS var 0000/002B/0008 Writing ACC GDFS var 0000/002C/0008 Writing ACC GDFS var 0000/002D/0008 Writing ACC GDFS var 0000/002E/0008 Writing ACC GDFS var 0000/002F/0008 Writing ACC GDFS var 0000/0030/0008 Writing ACC GDFS var 0000/0031/0008 Writing ACC GDFS var 0000/0032/0008 Writing ACC GDFS var 0000/0033/0008 Writing ACC GDFS var 0000/0034/0008 Writing ACC GDFS var 0000/0035/0008 Writing ACC GDFS var 0000/0036/0008 Writing ACC GDFS var 0000/0050/0001 Writing ACC GDFS var 0000/0051/0001 Writing ACC GDFS var 0000/0052/000A Writing ACC GDFS var 0000/0053/0002 Writing ACC GDFS var 0000/0054/0006 Writing ACC GDFS var 0000/0055/0002 Writing ACC GDFS var 0000/0056/0002 Writing ACC GDFS var 0000/0057/0002 Writing ACC GDFS var 0000/0058/0002 Writing ACC GDFS var 0000/0059/0001 Writing ACC GDFS var 0000/005A/0001 Writing ACC GDFS var 0000/005B/0001 Writing ACC GDFS var 0000/005C/0001 Writing ACC GDFS var 0000/005D/0001 Writing ACC GDFS var 0000/005E/0001 Writing ACC GDFS var 0000/005F/0001 Writing ACC GDFS var 0000/0060/0001 Writing ACC GDFS var 0000/0062/0001 Writing ACC GDFS var 0000/0063/0001 Writing ACC GDFS var 0000/0065/0001 Writing ACC GDFS var 0000/0066/0014 Writing ACC GDFS var 0000/00A2/0001 Writing ACC GDFS var 0000/00A4/0002 Writing ACC GDFS var 0000/00A5/0006 Writing ACC GDFS var 0000/00A6/0001 Writing ACC GDFS var 0000/00A7/0064 Writing ACC GDFS var 0000/00A8/00F8 Writing ACC GDFS var 0000/00A9/0001 Writing ACC GDFS var 0000/00AA/0400 Writing ACC GDFS var 0000/00AB/0280 Writing ACC GDFS var 0000/00AC/0080 Writing ACC GDFS var 0000/00AD/0040 Writing ACC GDFS var 0000/00AE/0006 Writing ACC GDFS var 0000/00AF/0001 Writing ACC GDFS var 0000/00B0/0004 Writing ACC GDFS var 0000/00B1/0002 Writing ACC GDFS var 0000/00B2/0100 Writing ACC GDFS var 0000/00B3/0200 Writing ACC GDFS var 0000/00B4/0001 Writing ACC GDFS var 0000/00B5/0001 Writing ACC GDFS var 0000/00B6/0001 Writing ACC GDFS var 0000/00B7/0002 Writing ACC GDFS var 0000/00B8/0006 Writing ACC GDFS var 0000/00B9/0006 Writing ACC GDFS var 0000/00BA/0006 Writing ACC GDFS var 0000/00EE/0001 Writing ACC GDFS var 0000/0118/0014 Writing ACC GDFS var 0000/0119/0002 Writing ACC GDFS var 0000/011A/0002 Writing ACC GDFS var 0000/011B/0002 Writing ACC GDFS var 0000/011C/0002 Writing ACC GDFS var 0000/0122/0001 Writing ACC GDFS var 0000/0123/0031 Writing ACC GDFS var 0000/0124/0001 Writing ACC GDFS var 0000/0125/0001 Writing ACC GDFS var 0000/0126/0003 Writing ACC GDFS var 0000/0127/0009 Writing ACC GDFS var 0000/0128/0001 Writing ACC GDFS var 0000/0129/0001 Writing ACC GDFS var 0000/012A/0001 Writing ACC GDFS var 0000/012B/0001 Writing ACC GDFS var 0000/012C/0001 Writing ACC GDFS var 0000/012D/0003 Writing ACC GDFS var 0000/012E/0003 Writing ACC GDFS var 0000/012F/0004 Writing ACC GDFS var 0000/0130/0004 Writing ACC GDFS var 0000/0131/0004 Writing ACC GDFS var 0000/0132/0004 Writing ACC GDFS var 0000/0133/0008 Writing ACC GDFS var 0000/0134/0005 Writing ACC GDFS var 0000/0135/0001 Writing ACC GDFS var 0000/0136/0001 Writing ACC GDFS var 0000/0137/0001 Writing ACC GDFS var 0000/0138/0061 Writing ACC GDFS var 0000/0139/0001 Writing ACC GDFS var 0000/013A/0001 Writing ACC GDFS var 0000/013B/0001 Writing ACC GDFS var 0000/013C/0001 Writing ACC GDFS var 0000/013D/0001 Writing ACC GDFS var 0000/013E/0001 Writing ACC GDFS var 0000/013F/0001 Writing ACC GDFS var 0000/0140/0001 Writing ACC GDFS var 0000/0141/0001 Writing ACC GDFS var 0000/0142/0001 Writing ACC GDFS var 0000/0143/0001 Writing ACC GDFS var 0000/0144/0001 Writing ACC GDFS var 0000/0145/0001 Writing ACC GDFS var 0000/0146/0001 Writing ACC GDFS var 0000/0147/0001 Writing ACC GDFS var 0000/0148/0001 Writing ACC GDFS var 0000/0149/0001 Writing ACC GDFS var 0000/014A/003D Writing ACC GDFS var 0000/014B/0001 Writing ACC GDFS var 0000/014C/0001 Writing ACC GDFS var 0000/014D/0001 Writing ACC GDFS var 0000/014E/0001 Writing ACC GDFS var 0000/014F/0001 Writing ACC GDFS var 0000/0150/0001 Writing ACC GDFS var 0000/0151/0001 Writing ACC GDFS var 0000/0152/0007 Writing ACC GDFS var 0000/0153/0001 Writing ACC GDFS var 0000/0154/003D Writing ACC GDFS var 0000/0155/0001 Writing ACC GDFS var 0000/0156/0001 Writing ACC GDFS var 0000/0157/0001 Writing ACC GDFS var 0000/0158/0001 Writing ACC GDFS var 0000/0159/0001 Writing ACC GDFS var 0000/015A/0001 Writing ACC GDFS var 0000/015B/0001 Writing ACC GDFS var 0000/015C/0001 Writing ACC GDFS var 0000/015D/0001 Writing ACC GDFS var 0000/015E/0001 Writing ACC GDFS var 0000/015F/0001 Writing ACC GDFS var 0000/0160/0001 Writing ACC GDFS var 0000/0161/0001 Writing ACC GDFS var 0000/0162/0001 Writing ACC GDFS var 0000/0163/0001 Writing ACC GDFS var 0000/0164/0001 Writing ACC GDFS var 0000/0165/0001 Writing ACC GDFS var 0000/0166/0001 Writing ACC GDFS var 0000/0167/0001 Writing ACC GDFS var 0000/016A/000A Writing ACC GDFS var 0000/016B/0001 Writing ACC GDFS var 0000/016C/000F Writing ACC GDFS var 0000/0186/000A Writing ACC GDFS var 0000/0187/0002 Writing ACC GDFS var 0000/0188/001E Writing ACC GDFS var 0000/0189/0002 Writing ACC GDFS var 0000/018A/0002 Writing ACC GDFS var 0000/018B/0002 Writing ACC GDFS var 0000/018C/0002 Writing ACC GDFS var 0000/018D/0002 Writing ACC GDFS var 0000/018E/0002 Writing ACC GDFS var 0000/018F/0001 Writing ACC GDFS var 0000/0190/0001 Writing ACC GDFS var 0000/0191/0001 Writing ACC GDFS var 0000/0192/0001 Writing ACC GDFS var 0000/0193/0001 Writing ACC GDFS var 0000/0194/0004 Writing ACC GDFS var 0000/0195/0004 Writing ACC GDFS var 0000/0196/0004 Writing ACC GDFS var 0000/0197/0004 Writing ACC GDFS var 0000/0198/0004 Writing ACC GDFS var 0000/0199/0001 Writing ACC GDFS var 0000/019A/0001 Writing ACC GDFS var 0000/019B/0004 Writing ACC GDFS var 0000/019C/000A Writing ACC GDFS var 0000/019D/0001 Writing ACC GDFS var 0000/019F/0001 Writing ACC GDFS var 0000/01A1/0004 Writing ACC GDFS var 0000/01A2/0001 Writing ACC GDFS var 0000/01A3/0001 Writing ACC GDFS var 0000/01A4/0001 Writing ACC GDFS var 0000/01A5/0001 Writing ACC GDFS var 0000/01A6/0001 Writing ACC GDFS var 0000/01A7/0001 Writing ACC GDFS var 0000/01A8/0002 Writing ACC GDFS var 0000/01A9/0001 Writing ACC GDFS var 0000/01AA/0001 Writing ACC GDFS var 0000/01AB/0001 Writing ACC GDFS var 0000/01C2/0001 Writing ACC GDFS var 0000/01C3/0002 Writing ACC GDFS var 0000/01C4/0002 Writing ACC GDFS var 0000/01C5/0002 Writing ACC GDFS var 0000/01C6/0002 Writing ACC GDFS var 0000/01C7/0002 Writing ACC GDFS var 0000/01C8/0002 Writing ACC GDFS var 0000/01C9/0002 Writing ACC GDFS var 0000/01CA/0002 Writing ACC GDFS var 0000/01CB/0002 Writing ACC GDFS var 0000/01CC/0002 Writing ACC GDFS var 0000/01CD/0002 Writing ACC GDFS var 0000/01CE/0002 Writing ACC GDFS var 0000/01CF/0002 Writing ACC GDFS var 0000/01D0/0002 Writing ACC GDFS var 0000/01D1/0002 Writing ACC GDFS var 0000/01D2/0002 Writing ACC GDFS var 0000/01D3/0002 Writing ACC GDFS var 0000/01D4/0002 Writing ACC GDFS var 0000/01D5/0002 Writing ACC GDFS var 0000/01D6/0002 Writing ACC GDFS var 0000/01D7/0002 Writing ACC GDFS var 0000/01D8/0002 Writing ACC GDFS var 0000/01D9/0002 Writing ACC GDFS var 0000/01DA/0002 Writing ACC GDFS var 0000/01DB/0002 Writing ACC GDFS var 0000/01DC/0002 Writing ACC GDFS var 0000/01DD/0002 Writing ACC GDFS var 0000/01DE/0002 Writing ACC GDFS var 0000/01DF/0002 Writing ACC GDFS var 0000/01E0/0002 Writing ACC GDFS var 0000/01E1/0002 Writing ACC GDFS var 0000/01E2/0002 Writing ACC GDFS var 0000/01E3/0002 Writing ACC GDFS var 0000/01E4/0002 Writing ACC GDFS var 0000/01E5/0002 Writing ACC GDFS var 0000/01E6/0002 Writing ACC GDFS var 0000/01E7/0002 Writing ACC GDFS var 0000/01E8/0002 Writing ACC GDFS var 0000/01E9/0002 Writing ACC GDFS var 0000/01EA/0002 Writing ACC GDFS var 0000/01EB/0002 Writing ACC GDFS var 0000/01EC/0002 Writing ACC GDFS var 0000/01ED/0002 Writing ACC GDFS var 0000/01EE/0002 Writing ACC GDFS var 0000/01EF/0002 Writing ACC GDFS var 0000/01F0/0002 Writing ACC GDFS var 0000/01F1/0002 Writing ACC GDFS var 0000/01F2/0002 Writing ACC GDFS var 0000/01F3/0002 Writing ACC GDFS var 0000/01F4/0002 Writing ACC GDFS var 0000/01F5/0002 Writing ACC GDFS var 0000/01F6/0002 Writing ACC GDFS var 0000/01F7/0002 Writing ACC GDFS var 0000/01F8/0002 Writing ACC GDFS var 0000/01F9/0002 Writing ACC GDFS var 0000/01FA/0002 Writing ACC GDFS var 0000/01FB/0002 Writing ACC GDFS var 0000/01FC/0002 Writing ACC GDFS var 0000/01FD/0002 Writing ACC GDFS var 0000/01FE/0002 Writing ACC GDFS var 0000/01FF/0002 Writing ACC GDFS var 0000/0200/0002 Writing ACC GDFS var 0000/0201/0002 Writing ACC GDFS var 0000/0202/0002 Writing ACC GDFS var 0000/0203/0002 Writing ACC GDFS var 0000/0204/0002 Writing ACC GDFS var 0000/0205/0002 Writing ACC GDFS var 0000/0206/0002 Writing ACC GDFS var 0000/0207/0002 Writing ACC GDFS var 0000/0208/0002 Writing ACC GDFS var 0000/0209/0002 Writing ACC GDFS var 0000/020A/0002 Writing ACC GDFS var 0000/020B/0002 Writing ACC GDFS var 0000/020C/0002 Writing ACC GDFS var 0000/020D/0002 Writing ACC GDFS var 0000/020E/0002 Writing ACC GDFS var 0000/020F/0002 Writing ACC GDFS var 0000/0210/0002 Writing ACC GDFS var 0000/0211/0002 Writing ACC GDFS var 0000/0212/0002 Writing ACC GDFS var 0000/0213/0002 Writing ACC GDFS var 0000/0214/0002 Writing ACC GDFS var 0000/0215/0002 Writing ACC GDFS var 0000/0216/0002 Writing ACC GDFS var 0000/0217/0002 Writing ACC GDFS var 0000/0218/0002 Writing ACC GDFS var 0000/0219/0002 Writing ACC GDFS var 0000/021A/0002 Writing ACC GDFS var 0000/021B/0002 Writing ACC GDFS var 0000/021C/0002 Writing ACC GDFS var 0000/021D/0002 Writing ACC GDFS var 0000/021E/0002 Writing ACC GDFS var 0000/021F/0002 Writing ACC GDFS var 0000/0220/0002 Writing ACC GDFS var 0000/0221/0002 Writing ACC GDFS var 0000/0222/0002 Writing ACC GDFS var 0000/0223/0002 Writing ACC GDFS var 0000/0224/0002 Writing ACC GDFS var 0000/0225/0002 Writing ACC GDFS var 0000/0226/0002 Writing ACC GDFS var 0000/0227/0002 Writing ACC GDFS var 0000/0228/0002 Writing ACC GDFS var 0000/0229/0002 Writing ACC GDFS var 0000/022A/0002 Writing ACC GDFS var 0000/022B/0002 Writing ACC GDFS var 0000/022C/0002 Writing ACC GDFS var 0000/022D/0002 Writing ACC GDFS var 0000/022E/0002 Writing ACC GDFS var 0000/022F/0002 Writing ACC GDFS var 0000/0230/0002 Writing ACC GDFS var 0000/0231/0002 Writing ACC GDFS var 0000/0232/0002 Writing ACC GDFS var 0000/0233/0002 Writing ACC GDFS var 0000/0234/0002 Writing ACC GDFS var 0000/0235/0002 Writing ACC GDFS var 0000/0236/0002 Writing ACC GDFS var 0000/0237/0002 Writing ACC GDFS var 0000/0238/0002 Writing ACC GDFS var 0000/0239/0002 Writing ACC GDFS var 0000/023A/0002 Writing ACC GDFS var 0000/023B/0002 Writing ACC GDFS var 0000/023C/0002 Writing ACC GDFS var 0000/023D/0002 Writing ACC GDFS var 0000/023E/0002 Writing ACC GDFS var 0000/023F/0002 Writing ACC GDFS var 0000/0240/0002 Writing ACC GDFS var 0000/0241/0002 Writing ACC GDFS var 0000/0242/0002 Writing ACC GDFS var 0000/0243/0002 Writing ACC GDFS var 0000/0244/0002 Writing ACC GDFS var 0000/0245/0002 Writing ACC GDFS var 0000/0246/0002 Writing ACC GDFS var 0000/0247/0002 Writing ACC GDFS var 0000/0248/0002 Writing ACC GDFS var 0000/0249/0002 Writing ACC GDFS var 0000/024A/0002 Writing ACC GDFS var 0000/024B/0004 Writing ACC GDFS var 0000/024C/0004 Writing ACC GDFS var 0000/024D/0004 Writing ACC GDFS var 0000/024E/0004 Writing ACC GDFS var 0000/024F/0004 Writing ACC GDFS var 0000/0250/0004 Writing ACC GDFS var 0000/0251/0004 Writing ACC GDFS var 0000/0252/0004 Writing ACC GDFS var 0000/0253/0002 Writing ACC GDFS var 0000/0256/0004 Writing ACC GDFS var 0000/0257/0004 Writing ACC GDFS var 0000/0258/0004 Writing ACC GDFS var 0000/0259/0004 Writing ACC GDFS var 0000/025A/0004 Writing ACC GDFS var 0000/025B/0004 Writing ACC GDFS var 0000/025C/0004 Writing ACC GDFS var 0000/025D/0004 Writing ACC GDFS var 0000/025E/0002 Writing ACC GDFS var 0000/025F/0001 Writing ACC GDFS var 0000/0261/000B Writing ACC GDFS var 0000/0262/0016 Writing ACC GDFS var 0000/0263/0002 Writing ACC GDFS var 0000/0264/0002 Writing ACC GDFS var 0000/0265/0002 Writing ACC GDFS var 0000/0266/0002 Writing ACC GDFS var 0000/028A/0002 Writing ACC GDFS var 0000/028B/0001 Writing ACC GDFS var 0000/028F/0044 Writing ACC GDFS var 0000/0290/0004 Writing ACC GDFS var 0000/0291/0001 Writing ACC GDFS var 0000/0292/0001 Writing ACC GDFS var 0000/0293/000F Writing ACC GDFS var 0000/0294/0002 Writing ACC GDFS var 0000/0295/0001 Writing ACC GDFS var 0000/0296/0001 Writing ACC GDFS var 0000/0297/0001 Writing ACC GDFS var 0000/0298/0001 Writing ACC GDFS var 0000/0299/0001 Writing ACC GDFS var 0000/029A/0001 Writing ACC GDFS var 0000/029B/0001 Writing ACC GDFS var 0000/029C/000A Writing ACC GDFS var 0000/029D/000A Writing ACC GDFS var 0000/029E/0001 Writing ACC GDFS var 0000/029F/0001 Writing ACC GDFS var 0000/02A0/0010 Writing ACC GDFS var 0000/02A1/0010 Writing ACC GDFS var 0000/02A2/0010 Writing ACC GDFS var 0000/02A3/0010 Writing ACC GDFS var 0000/02A4/0001 Writing ACC GDFS var 0000/02A5/0001 Writing ACC GDFS var 0000/02A6/0002 Writing ACC GDFS var 0000/02A7/0002 Writing ACC GDFS var 0000/02A8/0002 Writing ACC GDFS var 0000/02A9/0001 Writing ACC GDFS var 0000/02AA/0001 Writing ACC GDFS var 0000/02AB/0002 Writing ACC GDFS var 0000/02AC/0002 Writing ACC GDFS var 0000/02AD/0001 Writing ACC GDFS var 0000/02AE/0001 Writing ACC GDFS var 0000/02AF/0003 Writing ACC GDFS var 0000/02B0/0003 Writing ACC GDFS var 0000/02B1/0003 Writing ACC GDFS var 0000/02B2/0003 Writing ACC GDFS var 0000/02B3/0003 Writing ACC GDFS var 0000/02B4/0003 Writing ACC GDFS var 0000/02B5/0003 Writing ACC GDFS var 0000/02B6/0003 Writing ACC GDFS var 0000/02B7/0003 Writing ACC GDFS var 0000/02B8/0003 Writing ACC GDFS var 0000/02B9/0003 Writing ACC GDFS var 0000/02BA/0003 Writing ACC GDFS var 0000/02BB/0003 Writing ACC GDFS var 0000/02BC/0003 Writing ACC GDFS var 0000/02BD/0003 Writing ACC GDFS var 0000/02BE/0003 Writing ACC GDFS var 0000/02BF/0003 Writing ACC GDFS var 0000/02C0/0003 Writing ACC GDFS var 0000/02C1/0003 Writing ACC GDFS var 0000/02C2/0003 Writing ACC GDFS var 0000/02C3/0003 Writing ACC GDFS var 0000/02C4/0003 Writing ACC GDFS var 0000/02C5/0003 Writing ACC GDFS var 0000/02C6/0003 Writing ACC GDFS var 0000/02C7/0003 Writing ACC GDFS var 0000/02C8/0003 Writing ACC GDFS var 0000/02C9/0003 Writing ACC GDFS var 0000/02CA/0003 Writing ACC GDFS var 0000/02CB/0003 Writing ACC GDFS var 0000/02CC/0003 Writing ACC GDFS var 0000/02CD/0001 Writing ACC GDFS var 0000/02DA/0001 Writing ACC GDFS var 0000/02DB/0003 Writing ACC GDFS var 0000/02DC/0003 Writing ACC GDFS var 0000/02DD/0003 Writing ACC GDFS var 0000/02DE/0003 Writing ACC GDFS var 0000/02DF/0001 Writing ACC GDFS var 0000/02E0/0002 Writing ACC GDFS var 0000/02E1/0002 Writing ACC GDFS var 0000/02E2/0002 Writing ACC GDFS var 0000/02E3/0002 Writing ACC GDFS var 0000/02E4/0002 Writing ACC GDFS var 0000/02E5/0002 Writing ACC GDFS var 0000/02E6/0002 Writing ACC GDFS var 0000/02E7/0002 Writing ACC GDFS var 0000/02E8/0002 Writing ACC GDFS var 0000/02E9/0001 Writing ACC GDFS var 0000/02EA/0001 Writing ACC GDFS var 0000/02EB/0001 Writing ACC GDFS var 0000/02EC/0001 Writing ACC GDFS var 0000/02ED/0001 Writing ACC GDFS var 0000/02EE/0001 Writing ACC GDFS var 0000/02EF/0001 Writing ACC GDFS var 0000/02F0/0001 Writing ACC GDFS var 0000/02F1/0001 Writing ACC GDFS var 0000/02F2/0002 Writing ACC GDFS var 0000/02F6/0001 Writing ACC GDFS var 0000/02F7/0001 Writing ACC GDFS var 0000/02F8/0001 Writing ACC GDFS var 0000/02F9/0001 Writing ACC GDFS var 0000/02FA/0001 Writing ACC GDFS var 0000/02FB/0001 Writing ACC GDFS var 0000/02FC/0001 Writing ACC GDFS var 0000/02FD/0001 Writing ACC GDFS var 0000/02FE/0001 Writing ACC GDFS var 0000/02FF/0001 Writing ACC GDFS var 0000/0300/0001 Writing ACC GDFS var 0000/0301/0054 Writing ACC GDFS var 0000/0302/0054 Writing ACC GDFS var 0000/0303/0054 Writing ACC GDFS var 0000/0304/0054 Writing ACC GDFS var 0000/0305/0054 Writing ACC GDFS var 0000/0306/0054 Writing ACC GDFS var 0000/0307/0054 Writing ACC GDFS var 0000/0308/0054 Writing ACC GDFS var 0000/0309/0054 Writing ACC GDFS var 0000/030A/0054 Writing ACC GDFS var 0000/030B/0054 Writing ACC GDFS var 0000/030C/0002 Writing ACC GDFS var 0000/030D/0002 Writing ACC GDFS var 0000/030E/0002 Writing ACC GDFS var 0000/030F/0002 Writing ACC GDFS var 0000/0310/0006 Writing ACC GDFS var 0000/0311/000A Writing ACC GDFS var 0000/0312/000A Writing ACC GDFS var 0000/0313/000A Writing ACC GDFS var 0000/0314/000A Writing ACC GDFS var 0000/0315/0100 Writing ACC GDFS var 0000/0316/0100 Writing ACC GDFS var 0000/0317/0100 Writing ACC GDFS var 0000/0318/0018 Writing ACC GDFS var 0000/0319/0018 Writing ACC GDFS var 0000/031A/0018 Writing ACC GDFS var 0000/031B/0018 Writing ACC GDFS var 0000/031C/0020 Writing ACC GDFS var 0000/031D/001A Writing ACC GDFS var 0000/031E/0002 Writing ACC GDFS var 0000/031F/0200 Writing ACC GDFS var 0000/0320/0004 Writing ACC GDFS var 0000/0321/0006 Writing ACC GDFS var 0000/0322/0008 Writing ACC GDFS var 0000/0323/0040 Writing ACC GDFS var 0000/0324/001A Writing ACC GDFS var 0000/0325/001A Writing ACC GDFS var 0000/0326/001A Writing ACC GDFS var 0000/0327/0020 Writing ACC GDFS var 0000/0328/0020 Writing ACC GDFS var 0000/0329/0020 Writing ACC GDFS var 0000/032A/04C0 Writing ACC GDFS var 0000/032B/04C0 Writing ACC GDFS var 0000/032C/04C0 Writing ACC GDFS var 0000/032D/04C0 Writing ACC GDFS var 0000/032E/04C0 Writing ACC GDFS var 0000/032F/04C0 Writing ACC GDFS var 0000/0330/04C0 Writing ACC GDFS var 0000/0331/04C0 Writing ACC GDFS var 0000/0332/04C0 Writing ACC GDFS var 0000/0333/04C0 Writing ACC GDFS var 0000/0334/04C0 Writing ACC GDFS var 0000/0335/04C0 Writing ACC GDFS var 0000/0336/04C0 Writing ACC GDFS var 0000/0337/04C0 Writing ACC GDFS var 0000/0338/04C0 Writing ACC GDFS var 0000/0339/04C0 Writing ACC GDFS var 0000/033A/04C0 Writing ACC GDFS var 0000/033B/04C0 Writing ACC GDFS var 0000/033C/04C0 Writing ACC GDFS var 0000/033D/04C0 Writing ACC GDFS var 0000/033E/04C0 Writing ACC GDFS var 0000/033F/04C0 Writing ACC GDFS var 0000/0340/04C0 Writing ACC GDFS var 0000/0341/04C0 Writing ACC GDFS var 0000/0342/04C0 Writing ACC GDFS var 0000/0343/04C0 Writing ACC GDFS var 0000/0344/04C0 Writing ACC GDFS var 0000/0345/04C0 Writing ACC GDFS var 0000/0346/04C0 Writing ACC GDFS var 0000/0347/04C0 Writing ACC GDFS var 0000/0348/04C0 Writing ACC GDFS var 0000/0349/04C0 Writing ACC GDFS var 0000/034A/04C0 Writing ACC GDFS var 0000/034B/04C0 Writing ACC GDFS var 0000/034C/04C0 Writing ACC GDFS var 0000/034D/04C0 Writing ACC GDFS var 0000/034E/04C0 Writing ACC GDFS var 0000/034F/04C0 Writing ACC GDFS var 0000/0350/04C0 Writing ACC GDFS var 0000/0351/04C0 Writing ACC GDFS var 0000/0352/04C0 Writing ACC GDFS var 0000/0353/04C0 Writing ACC GDFS var 0000/0354/04C0 Writing ACC GDFS var 0000/0355/04C0 Writing ACC GDFS var 0000/0356/04C0 Writing ACC GDFS var 0000/0357/04C0 Writing ACC GDFS var 0000/0358/04C0 Writing ACC GDFS var 0000/0359/04C0 Writing ACC GDFS var 0000/035A/04C0 Writing ACC GDFS var 0000/035B/04C0 Writing ACC GDFS var 0000/035C/04C0 Writing ACC GDFS var 0000/035D/04C0 Writing ACC GDFS var 0000/035E/04C0 Writing ACC GDFS var 0000/035F/04C0 Writing ACC GDFS var 0000/0360/04C0 Writing ACC GDFS var 0000/0361/04C0 Writing ACC GDFS var 0000/0362/04C0 Writing ACC GDFS var 0000/0363/04C0 Writing ACC GDFS var 0000/0364/04C0 Writing ACC GDFS var 0000/0365/04C0 Writing ACC GDFS var 0000/0366/04C0 Writing ACC GDFS var 0000/0367/04C0 Writing ACC GDFS var 0000/0368/04C0 Writing ACC GDFS var 0000/0369/04C0 Writing ACC GDFS var 0000/036A/04C0 Writing ACC GDFS var 0000/036B/04C0 Writing ACC GDFS var 0000/036C/04C0 Writing ACC GDFS var 0000/036D/04C0 Writing ACC GDFS var 0000/036E/04C0 Writing ACC GDFS var 0000/036F/04C0 Writing ACC GDFS var 0000/0370/04C0 Writing ACC GDFS var 0000/0371/04C0 Writing ACC GDFS var 0000/0372/04C0 Writing ACC GDFS var 0000/0373/04C0 Writing ACC GDFS var 0000/0374/04C0 Writing ACC GDFS var 0000/0375/00AE Writing ACC GDFS var 0000/0376/0020 Writing ACC GDFS var 0000/0377/0258 Writing ACC GDFS var 0000/0378/0002 Writing ACC GDFS var 0000/0379/0002 Writing ACC GDFS var 0000/037A/0002 Writing ACC GDFS var 0000/037B/0002 Writing ACC GDFS var 0000/037C/0010 Writing ACC GDFS var 0000/037D/0010 Writing ACC GDFS var 0000/037E/0010 Writing ACC GDFS var 0000/037F/0010 Writing ACC GDFS var 0000/0380/0018 Writing ACC GDFS var 0000/0381/0004 Writing ACC GDFS var 0000/0382/0004 Writing ACC GDFS var 0000/0383/0004 Writing ACC GDFS var 0000/0384/0004 Writing ACC GDFS var 0000/0385/0014 Writing ACC GDFS var 0000/0386/0014 Writing ACC GDFS var 0000/0387/001A Writing ACC GDFS var 0000/0388/0002 Writing ACC GDFS var 0000/0389/0110 Writing ACC GDFS var 0000/038A/0014 Writing ACC GDFS var 0000/038B/0030 Writing ACC GDFS var 0000/038C/0005 Writing ACC GDFS var 0000/038D/0004 Writing ACC GDFS var 0000/038E/0008 Writing ACC GDFS var 0000/038F/0008 Writing ACC GDFS var 0000/0390/0008 Writing ACC GDFS var 0000/0391/0008 Writing ACC GDFS var 0000/0392/0010 Writing ACC GDFS var 0000/0393/001A Writing ACC GDFS var 0000/0394/001A Writing ACC GDFS var 0000/0395/001A Writing ACC GDFS var 0000/0396/001A Writing ACC GDFS var 0000/0397/0010 Writing ACC GDFS var 0000/0398/0010 Writing ACC GDFS var 0000/0399/0010 Writing ACC GDFS var 0000/039A/0040 Writing ACC GDFS var 0000/039B/0001 Writing ACC GDFS var 0000/039C/0001 Writing ACC GDFS var 0000/039D/0001 Writing ACC GDFS var 0000/039E/0001 Writing ACC GDFS var 0000/039F/0002 Writing ACC GDFS var 0000/03A0/0001 Writing ACC GDFS var 0000/03A1/0004 Writing ACC GDFS var 0000/03A2/0004 Writing ACC GDFS var 0000/03A3/0004 Writing ACC GDFS var 0000/03A4/0001 Writing ACC GDFS var 0000/03A5/0001 Writing ACC GDFS var 0000/03A6/0001 Writing ACC GDFS var 0000/03A7/0004 Writing ACC GDFS var 0000/03B1/002A Writing ACC GDFS var 0000/03B2/0008 Writing ACC GDFS var 0000/03B3/0008 Writing ACC GDFS var 0000/03B4/0001 Writing ACC GDFS var 0000/03B5/0001 Writing ACC GDFS var 0000/03B6/0001 Writing ACC GDFS var 0000/03B7/0001 Writing ACC GDFS var 0000/03B8/0001 Writing ACC GDFS var 0000/03B9/0001 Writing ACC GDFS var 0000/03BA/0001 Writing ACC GDFS var 0000/03BB/0001 Writing ACC GDFS var 0000/03BC/0001 Writing ACC GDFS var 0000/03BD/0001 Writing ACC GDFS var 0000/03BE/0001 Writing ACC GDFS var 0000/03BF/0001 Writing ACC GDFS var 0000/03C0/0001 Writing ACC GDFS var 0000/03C1/0001 Writing ACC GDFS var 0000/03C2/0001 Writing ACC GDFS var 0000/03C3/0001 Writing ACC GDFS var 0000/03C4/0016 Writing ACC GDFS var 0000/03C5/0016 Writing ACC GDFS var 0000/03C6/0016 Writing ACC GDFS var 0000/03C7/0016 Writing ACC GDFS var 0000/03C8/0001 Writing ACC GDFS var 0000/03C9/0001 Writing ACC GDFS var 0000/03CA/0001 Writing ACC GDFS var 0000/03CB/0001 Writing ACC GDFS var 0000/03CC/0001 Writing ACC GDFS var 0000/03CD/0001 Writing ACC GDFS var 0000/03CE/0001 Writing ACC GDFS var 0000/03CF/0001 Writing ACC GDFS var 0000/03D4/04C0 Writing ACC GDFS var 0000/03DD/0100 Writing ACC GDFS var 0000/03DE/0002 Writing ACC GDFS var 0000/03E3/0001 Writing ACC GDFS var 0000/03E4/0001 Writing ACC GDFS var 0000/03E5/0001 Writing ACC GDFS var 0000/03E6/0001 Writing ACC GDFS var 0000/03E7/0001 Writing ACC GDFS var 0000/03EC/0004 Writing ACC GDFS var 0000/03FF/0004 Writing ACC GDFS var 0000/0400/0004 Writing ACC GDFS var 0000/0402/0001 Writing ACC GDFS var 0000/0403/001A Writing ACC GDFS var 0000/0404/001A Writing ACC GDFS var 0000/0405/001A Writing ACC GDFS var 0000/0407/0001 Writing ACC GDFS var 0000/0408/0001 Writing ACC GDFS var 0000/0409/0001 Writing ACC GDFS var 0000/040A/0001 Writing ACC GDFS var 0000/040B/0001 Writing ACC GDFS var 0000/040C/0001 Writing ACC GDFS var 0000/040D/0001 Writing ACC GDFS var 0000/040E/0001 Writing ACC GDFS var 0000/040F/0001 Writing ACC GDFS var 0000/0410/0001 Writing ACC GDFS var 0000/0411/0001 Writing ACC GDFS var 0000/0412/0001 Writing ACC GDFS var 0000/0413/0001 Writing ACC GDFS var 0000/0414/0001 Writing ACC GDFS var 0000/0415/0001 Writing ACC GDFS var 0000/0416/0001 Writing ACC GDFS var 0000/0417/0001 Writing ACC GDFS var 0000/0418/0001 Writing ACC GDFS var 0000/0419/0001 Writing ACC GDFS var 0000/041A/0001 Writing ACC GDFS var 0000/041B/0001 Writing ACC GDFS var 0000/041C/0001 Writing ACC GDFS var 0000/041D/0001 Writing ACC GDFS var 0000/041E/0001 Writing ACC GDFS var 0000/041F/0001 Writing ACC GDFS var 0000/0420/0001 Writing ACC GDFS var 0000/0421/0001 Writing ACC GDFS var 0000/0422/0001 Writing ACC GDFS var 0000/0423/0001 Writing ACC GDFS var 0000/0424/0001 Writing ACC GDFS var 0000/0425/0001 Writing ACC GDFS var 0000/0426/0001 Writing ACC GDFS var 0000/0427/0001 Writing ACC GDFS var 0000/0428/0001 Writing ACC GDFS var 0000/0429/0001 Writing ACC GDFS var 0000/042A/0001 Writing ACC GDFS var 0000/042B/000E Writing ACC GDFS var 0000/042C/000E Writing ACC GDFS var 0000/042D/000E Writing ACC GDFS var 0000/042E/000E Writing ACC GDFS var 0000/042F/0060 Writing ACC GDFS var 0000/0430/0060 Writing ACC GDFS var 0000/0431/0060 Writing ACC GDFS var 0000/0432/0060 Writing ACC GDFS var 0000/0433/0018 Writing ACC GDFS var 0000/0434/0018 Writing ACC GDFS var 0000/0435/0018 Writing ACC GDFS var 0000/0436/0018 Writing ACC GDFS var 0000/0437/0014 Writing ACC GDFS var 0000/0438/0002 Writing ACC GDFS var 0000/0439/0001 Writing ACC GDFS var 0000/043A/0001 Writing ACC GDFS var 0000/043B/0001 Writing ACC GDFS var 0000/043C/0001 Writing ACC GDFS var 0000/043D/0001 Writing ACC GDFS var 0000/043E/0001 Writing ACC GDFS var 0000/043F/0001 Writing ACC GDFS var 0000/0440/0001 Writing ACC GDFS var 0000/0441/0001 Writing ACC GDFS var 0000/0442/0001 Writing ACC GDFS var 0000/0443/0001 Writing ACC GDFS var 0000/0444/0001 Writing ACC GDFS var 0000/0445/0007 Writing ACC GDFS var 0000/0446/0007 Writing ACC GDFS var 0000/0447/0007 Writing ACC GDFS var 0000/0448/0007 Writing ACC GDFS var 0000/0449/0001 Writing ACC GDFS var 0000/044A/0003 Writing ACC GDFS var 0000/044B/0003 Writing ACC GDFS var 0000/044C/0003 Writing ACC GDFS var 0000/044D/0003 Writing ACC GDFS var 0000/0454/0020 Writing ACC GDFS var 0000/0455/0001 Writing ACC GDFS var 0000/0456/0001 Writing ACC GDFS var 0000/0457/0001 Writing ACC GDFS var 0000/0458/0001 Writing ACC GDFS var 0000/0459/0001 Writing ACC GDFS var 0000/045A/0001 Writing ACC GDFS var 0000/045B/0001 Writing ACC GDFS var 0000/045C/0001 Writing ACC GDFS var 0000/045D/0001 Writing ACC GDFS var 0000/045E/0001 Writing ACC GDFS var 0000/045F/0001 Writing ACC GDFS var 0000/0460/0001 Writing ACC GDFS var 0000/04CE/0200 Writing ACC GDFS var 0000/04CF/0200 Writing ACC GDFS var 0000/04D0/03DE Writing ACC GDFS var 0000/04D1/03DE Writing ACC GDFS var 0000/04D2/03DE Writing ACC GDFS var 0000/04D3/03DE Writing ACC GDFS var 0000/04D4/03DE Writing ACC GDFS var 0000/04D5/03DE Writing ACC GDFS var 0000/04D6/03DE Writing ACC GDFS var 0000/04D7/03DE Writing ACC GDFS var 0000/04D8/0006 Writing ACC GDFS var 0000/04D9/0006 Writing ACC GDFS var 0000/04DA/0006 Writing ACC GDFS var 0000/04DB/0006 Writing ACC GDFS var 0000/04DC/0004 Writing ACC GDFS var 0000/04DD/0004 Writing ACC GDFS var 0000/04DE/0004 Writing ACC GDFS var 0000/04DF/0004 Writing ACC GDFS var 0000/04E0/001E Writing ACC GDFS var 0000/04E1/001E Writing ACC GDFS var 0000/04E2/001E Writing ACC GDFS var 0000/04E3/001E Writing ACC GDFS var 0000/04E4/0001 Writing ACC GDFS var 0000/04E5/0001 Writing ACC GDFS var 0000/04E6/0001 Writing ACC GDFS var 0000/04E7/0001 Writing ACC GDFS var 0000/04E8/0001 Writing ACC GDFS var 0000/04E9/0001 Writing ACC GDFS var 0000/04EA/0001 Writing ACC GDFS var 0000/04EB/0001 Writing ACC GDFS var 0000/04EC/0001 Writing ACC GDFS var 0000/04ED/0001 Writing ACC GDFS var 0000/04EE/0001 Writing ACC GDFS var 0000/04F1/0001 Writing ACC GDFS var 0000/04F2/0001 Writing ACC GDFS var 0000/04F3/0001 Writing ACC GDFS var 0000/04F4/0001 Writing ACC GDFS var 0000/04F5/0001 Writing ACC GDFS var 0000/04F6/0001 Writing ACC GDFS var 0000/04F7/0001 Writing ACC GDFS var 0000/04F8/0001 Writing ACC GDFS var 0000/04F9/0001 Writing ACC GDFS var 0000/04FA/0001 Writing ACC GDFS var 0000/04FB/0001 Writing ACC GDFS var 0000/04FC/0001 Writing ACC GDFS var 0000/04FD/0001 Writing ACC GDFS var 0000/04FE/0001 Writing ACC GDFS var 0000/04FF/0001 Writing ACC GDFS var 0000/0501/0001 Writing ACC GDFS var 0000/0502/0001 Writing ACC GDFS var 0000/0503/0001 Writing ACC GDFS var 0000/0504/0005 Writing ACC GDFS var 0000/0505/0005 Writing ACC GDFS var 0000/0506/0005 Writing ACC GDFS var 0000/0507/0005 Writing ACC GDFS var 0000/0509/0001 Writing ACC GDFS var 0000/050A/0001 Writing ACC GDFS var 0000/050B/0001 Writing ACC GDFS var 0000/050C/0001 Writing ACC GDFS var 0000/050D/0001 Writing ACC GDFS var 0000/050E/000F Writing ACC GDFS var 0000/050F/000F Writing ACC GDFS var 0000/0510/000F Writing ACC GDFS var 0000/0511/000F Writing ACC GDFS var 0000/0512/000F Writing ACC GDFS var 0000/0513/000F Writing ACC GDFS var 0000/0514/000F Writing ACC GDFS var 0000/0515/000F Writing ACC GDFS var 0000/0516/000F Writing ACC GDFS var 0000/0517/000F Writing ACC GDFS var 0000/0518/000F Writing ACC GDFS var 0000/0519/000F Writing ACC GDFS var 0000/051A/000F Writing ACC GDFS var 0000/051B/000F Writing ACC GDFS var 0000/051C/000F Writing ACC GDFS var 0000/051D/000F Writing ACC GDFS var 0000/051E/0020 Writing ACC GDFS var 0000/051F/0020 Writing ACC GDFS var 0000/0520/0020 Writing ACC GDFS var 0000/0521/0020 Writing ACC GDFS var 0000/0522/0020 Writing ACC GDFS var 0000/0523/0020 Writing ACC GDFS var 0000/0524/0020 Writing ACC GDFS var 0000/0525/0020 Writing ACC GDFS var 0000/0526/0004 Writing ACC GDFS var 0000/0527/0004 Writing ACC GDFS var 0000/0528/0004 Writing ACC GDFS var 0000/0529/0004 Writing ACC GDFS var 0000/052A/0002 Writing ACC GDFS var 0000/052B/0002 Writing ACC GDFS var 0000/052C/0002 Writing ACC GDFS var 0000/052D/0001 Writing ACC GDFS var 0000/052E/0001 Writing ACC GDFS var 0000/052F/0001 Writing ACC GDFS var 0000/0530/0001 Writing ACC GDFS var 0000/0531/0001 Writing ACC GDFS var 0000/0532/0001 Writing ACC GDFS var 0000/0575/0001 Writing ACC GDFS var 0000/0576/0020 Writing ACC GDFS var 0000/0577/0020 Writing ACC GDFS var 0000/0578/0020 Writing ACC GDFS var 0000/0579/0020 Writing ACC GDFS var 0000/057A/0008 Writing ACC GDFS var 0000/057B/0008 Writing ACC GDFS var 0000/057C/0008 Writing ACC GDFS var 0000/057D/0008 Writing ACC GDFS var 0000/057E/0020 Writing ACC GDFS var 0000/057F/0020 Writing ACC GDFS var 0000/0580/0020 Writing ACC GDFS var 0000/0581/0020 Writing ACC GDFS var 0000/0582/0008 Writing ACC GDFS var 0000/0583/0008 Writing ACC GDFS var 0000/0584/0008 Writing ACC GDFS var 0000/0585/0008 Writing ACC GDFS var 0000/0586/0060 Writing ACC GDFS var 0000/0587/0060 Writing ACC GDFS var 0000/0588/0060 Writing ACC GDFS var 0000/0589/0060 Writing ACC GDFS var 0000/058A/0008 Writing ACC GDFS var 0000/058B/0008 Writing ACC GDFS var 0000/058C/0008 Writing ACC GDFS var 0000/058D/0008 Writing ACC GDFS var 0000/058E/0060 Writing ACC GDFS var 0000/058F/0060 Writing ACC GDFS var 0000/0590/0060 Writing ACC GDFS var 0000/0591/0060 Writing ACC GDFS var 0000/0592/0008 Writing ACC GDFS var 0000/0593/0008 Writing ACC GDFS var 0000/0594/0008 Writing ACC GDFS var 0000/0595/0008 Writing ACC GDFS var 0000/0596/0060 Writing ACC GDFS var 0000/0597/0060 Writing ACC GDFS var 0000/0598/0060 Writing ACC GDFS var 0000/0599/0060 Writing ACC GDFS var 0000/059A/0008 Writing ACC GDFS var 0000/059B/0008 Writing ACC GDFS var 0000/059C/0008 Writing ACC GDFS var 0000/059D/0008 Writing ACC GDFS var 0000/059E/0060 Writing ACC GDFS var 0000/059F/0060 Writing ACC GDFS var 0000/05A0/0060 Writing ACC GDFS var 0000/05A1/0060 Writing ACC GDFS var 0000/05A2/0008 Writing ACC GDFS var 0000/05A3/0008 Writing ACC GDFS var 0000/05A4/0008 Writing ACC GDFS var 0000/05A5/0008 Writing ACC GDFS var 0000/05B4/0001 Writing ACC GDFS var 0000/05CB/0008 Writing ACC GDFS var 0000/05CC/0008 Writing ACC GDFS var 0000/05CD/0008 Writing ACC GDFS var 0000/05CE/0008 Writing ACC GDFS var 0000/05CF/0001 Writing ACC GDFS var 0000/05D0/0001 Writing ACC GDFS var 0000/05D1/0001 Writing ACC GDFS var 0000/05D2/0001 Writing ACC GDFS var 0000/05D3/0001 Writing ACC GDFS var 0000/05D4/0001 Writing ACC GDFS var 0000/05D5/0001 Writing ACC GDFS var 0000/05D6/0008 Writing ACC GDFS var 0000/05DF/0001 Writing ACC GDFS var 0000/05E0/0001 Writing ACC GDFS var 0000/05E1/0001 Writing ACC GDFS var 0000/05E2/0001 Writing ACC GDFS var 0000/05E3/001E Writing ACC GDFS var 0000/05E4/001E Writing ACC GDFS var 0000/05E5/001E Writing ACC GDFS var 0000/05E6/001E Writing ACC GDFS var 0000/05E7/0002 Writing ACC GDFS var 0000/05E8/0002 Writing ACC GDFS var 0000/05E9/0002 Writing ACC GDFS var 0000/05EB/0001 Writing ACC GDFS var 0000/05EC/0002 Writing ACC GDFS var 0000/05ED/0002 Writing ACC GDFS var 0000/05EE/0002 Writing ACC GDFS var 0000/05EF/0002 Writing ACC GDFS var 0000/05F0/0002 Writing ACC GDFS var 0000/05F1/0002 Writing ACC GDFS var 0000/05F2/0002 Writing ACC GDFS var 0000/05F3/0002 Writing ACC GDFS var 0000/05F4/0002 Writing ACC GDFS var 0000/05F8/0001 Writing ACC GDFS var 0000/05F9/0001 Writing ACC GDFS var 0000/05FA/0001 Writing ACC GDFS var 0000/05FB/0001 Writing ACC GDFS var 0000/061E/0008 Writing ACC GDFS var 0000/061F/0008 Writing ACC GDFS var 0000/0620/0008 Writing ACC GDFS var 0000/0621/0008 Writing ACC GDFS var 0000/0622/0001 Writing ACC GDFS var 0000/0623/0001 Writing ACC GDFS var 0000/0624/0001 Writing ACC GDFS var 0000/0625/0001 Writing ACC GDFS var 0000/0626/0001 Writing ACC GDFS var 0000/0627/0001 Writing ACC GDFS var 0000/0628/0001 Writing ACC GDFS var 0000/0629/0001 Writing ACC GDFS var 0000/062A/0001 Writing ACC GDFS var 0000/062B/0005 Writing ACC GDFS var 0000/062C/0005 Writing ACC GDFS var 0000/062D/0005 Writing ACC GDFS var 0000/062E/0005 Writing ACC GDFS var 0000/062F/000F Writing ACC GDFS var 0000/0630/000F Writing ACC GDFS var 0000/0631/000F Writing ACC GDFS var 0000/0632/000F Writing ACC GDFS var 0000/0633/000F Writing ACC GDFS var 0000/0634/000F Writing ACC GDFS var 0000/0635/000F Writing ACC GDFS var 0000/0636/000F Writing ACC GDFS var 0000/0637/0001 Writing ACC GDFS var 0000/0638/0001 Writing ACC GDFS var 0000/0639/0001 Writing ACC GDFS var 0000/063A/0001 Writing ACC GDFS var 0000/063B/0003 Writing ACC GDFS var 0000/063C/0003 Writing ACC GDFS var 0000/063D/0003 Writing ACC GDFS var 0000/063E/0003 Writing ACC GDFS var 0000/063F/0006 Writing ACC GDFS var 0000/0640/0006 Writing ACC GDFS var 0000/0641/0006 Writing ACC GDFS var 0000/0642/0006 Writing ACC GDFS var 0000/0643/0004 Writing ACC GDFS var 0000/0644/0004 Writing ACC GDFS var 0000/0645/0004 Writing ACC GDFS var 0000/0646/0004 Writing ACC GDFS var 0000/0647/0002 Writing ACC GDFS var 0000/0648/0002 Writing ACC GDFS var 0000/0649/0002 Writing ACC GDFS var 0000/064A/0002 Writing ACC GDFS var 0000/064B/0004 Writing ACC GDFS var 0000/064C/0004 Writing ACC GDFS var 0000/064D/0004 Writing ACC GDFS var 0000/064E/0004 Writing ACC GDFS var 0000/064F/0001 Writing ACC GDFS var 0000/0650/0001 Writing ACC GDFS var 0000/0651/0001 Writing ACC GDFS var 0000/0652/0001 Writing ACC GDFS var 0000/0653/0001 Writing ACC GDFS var 0000/0654/0001 Writing ACC GDFS var 0000/0655/0001 Writing ACC GDFS var 0000/0656/0024 Writing ACC GDFS var 0000/0657/0024 Writing ACC GDFS var 0000/0658/0024 Writing ACC GDFS var 0000/0659/0024 Writing ACC GDFS var 0000/065A/0024 Writing ACC GDFS var 0000/065B/0024 Writing ACC GDFS var 0000/065C/0024 Writing ACC GDFS var 0000/065D/0024 Writing ACC GDFS var 0000/065E/0024 Writing ACC GDFS var 0000/065F/0024 Writing ACC GDFS var 0000/0660/0024 Writing ACC GDFS var 0000/0661/0024 Writing ACC GDFS var 0000/0662/0024 Writing ACC GDFS var 0000/0663/0024 Writing ACC GDFS var 0000/0664/0024 Writing ACC GDFS var 0000/0665/0024 Writing ACC GDFS var 0000/0666/000C Writing ACC GDFS var 0000/0667/000C Writing ACC GDFS var 0000/0668/000C Writing ACC GDFS var 0000/0669/000C Writing ACC GDFS var 0000/066A/000C Writing ACC GDFS var 0000/066B/000C Writing ACC GDFS var 0000/066C/000C Writing ACC GDFS var 0000/066D/000C Writing ACC GDFS var 0000/066E/0001 Writing ACC GDFS var 0000/066F/0001 Writing ACC GDFS var 0000/0670/0001 Writing ACC GDFS var 0000/0671/0001 Writing ACC GDFS var 0000/0672/0001 Writing ACC GDFS var 0000/0673/0002 Writing ACC GDFS var 0000/0674/0016 Writing ACC GDFS var 0000/0675/0001 Writing ACC GDFS var 0000/0678/0001 Writing ACC GDFS var 0000/0679/0001 Writing ACC GDFS var 0000/067A/0001 Writing ACC GDFS var 0000/067B/0001 Writing ACC GDFS var 0000/067C/0001 Writing ACC GDFS var 0000/067D/0001 Writing ACC GDFS var 0000/067E/0007 Writing ACC GDFS var 0000/067F/0007 Writing ACC GDFS var 0000/0680/0007 Writing ACC GDFS var 0000/0681/0007 Writing ACC GDFS var 0000/0682/0004 Writing ACC GDFS var 0000/0683/0004 Writing ACC GDFS var 0000/0684/0004 Writing ACC GDFS var 0000/0685/0004 Writing ACC GDFS var 0000/0686/0004 Writing ACC GDFS var 0000/0687/0004 Writing ACC GDFS var 0000/0688/0004 Writing ACC GDFS var 0000/0689/0004 Writing ACC GDFS var 0000/068A/0004 Writing ACC GDFS var 0000/068B/0004 Writing ACC GDFS var 0000/068C/0004 Writing ACC GDFS var 0000/068D/0004 Writing ACC GDFS var 0000/068E/0004 Writing ACC GDFS var 0000/068F/0004 Writing ACC GDFS var 0000/0690/0004 Writing ACC GDFS var 0000/0691/0004 Writing ACC GDFS var 0000/0692/0004 Writing ACC GDFS var 0000/0693/0004 Writing ACC GDFS var 0000/0694/0004 Writing ACC GDFS var 0000/0695/0004 Writing ACC GDFS var 0000/0696/0004 Writing ACC GDFS var 0000/0697/0004 Writing ACC GDFS var 0000/0698/0004 Writing ACC GDFS var 0000/0699/0004 Writing ACC GDFS var 0000/0702/0001 Writing ACC GDFS var 0000/0703/0001 Writing ACC GDFS var 0000/0704/0001 Writing ACC GDFS var 0000/0705/0001 Writing ACC GDFS var 0000/0708/0001 Writing ACC GDFS var 0000/0709/0001 Writing ACC GDFS var 0000/070B/0002 Writing ACC GDFS var 0000/070C/0001 Writing ACC GDFS var 0000/070D/0001 Writing ACC GDFS var 0000/070E/0030 Writing ACC GDFS var 0000/070F/0001 Writing ACC GDFS var 0000/0710/0001 Writing ACC GDFS var 0000/0711/0001 Writing ACC GDFS var 0000/0712/0001 Writing ACC GDFS var 0000/0713/0001 Writing ACC GDFS var 0000/0736/0001 Writing ACC GDFS var 0000/0737/0001 Writing ACC GDFS var 0000/0738/0001 Writing ACC GDFS var 0000/0739/0001 Writing ACC GDFS var 0000/073A/0001 Writing ACC GDFS var 0000/073E/0001 Writing ACC GDFS var 0000/073F/0001 Writing ACC GDFS var 0000/0746/0001 Writing ACC GDFS var 0000/0747/0001 Writing ACC GDFS var 0000/0748/0001 Writing ACC GDFS var 0000/0749/0001 Writing ACC GDFS var 0000/074E/0001 Writing ACC GDFS var 0000/074F/0001 Writing ACC GDFS var 0000/0750/0001 Writing ACC GDFS var 0000/0751/0001 Writing ACC GDFS var 0000/0762/04C0 Writing ACC GDFS var 0000/0763/04C0 Writing ACC GDFS var 0000/0764/04C0 Writing ACC GDFS var 0000/0765/04C0 Writing ACC GDFS var 0000/0766/04C0 Writing ACC GDFS var 0000/0767/04C0 Writing ACC GDFS var 0000/0768/04C0 Writing ACC GDFS var 0000/0769/04C0 Writing ACC GDFS var 0000/076A/04C0 Writing ACC GDFS var 0000/076B/04C0 Writing ACC GDFS var 0000/076C/04C0 Writing ACC GDFS var 0000/076D/04C0 Writing ACC GDFS var 0000/076E/04C0 Writing ACC GDFS var 0000/076F/04C0 Writing ACC GDFS var 0000/0770/04C0 Writing ACC GDFS var 0000/0771/04C0 Writing ACC GDFS var 0000/0772/04C0 Writing ACC GDFS var 0000/0773/04C0 Writing ACC GDFS var 0000/0774/04C0 Writing ACC GDFS var 0000/0775/04C0 Writing ACC GDFS var 0000/0776/04C0 Writing ACC GDFS var 0000/0777/04C0 Writing ACC GDFS var 0000/0778/04C0 Writing ACC GDFS var 0000/0779/04C0 Writing ACC GDFS var 0000/0784/0002 Writing ACC GDFS var 0000/0785/0002 Writing ACC GDFS var 0000/0786/0002 Writing ACC GDFS var 0000/0787/0002 Writing ACC GDFS var 0000/0788/000D Writing ACC GDFS var 0000/0789/000D Writing ACC GDFS var 0000/078A/000D Writing ACC GDFS var 0000/078B/000D Writing ACC GDFS var 0000/078C/000D Writing ACC GDFS var 0000/078D/000D Writing ACC GDFS var 0000/078E/000D Writing ACC GDFS var 0000/078F/000D Writing ACC GDFS var 0000/0790/001A Writing ACC GDFS var 0000/0791/001A Writing ACC GDFS var 0000/0792/001A Writing ACC GDFS var 0000/0793/001A Writing ACC GDFS var 0000/0794/001A Writing ACC GDFS var 0000/0795/001A Writing ACC GDFS var 0000/0796/001A Writing ACC GDFS var 0000/0797/001A Writing ACC GDFS var 0000/0817/0002 Writing ACC GDFS var 0000/0818/0002 Writing ACC GDFS var 0000/0819/0002 Writing ACC GDFS var 0000/0832/0005 Writing ACC GDFS var 0000/0833/0006 Writing ACC GDFS var 0000/0834/0001 Writing ACC GDFS var 0000/0930/0001 Writing ACC GDFS var 0000/0931/0001 Writing ACC GDFS var 0000/0932/0001 Writing ACC GDFS var 0000/0933/0001 Writing ACC GDFS var 0000/0934/0400 Writing ACC GDFS var 0000/0935/0258 Writing ACC GDFS var 0000/0936/0001 Writing ACC GDFS var 0000/0937/0001 Writing ACC GDFS var 0000/0938/0001 Writing GDFS var 0000/0002/0004 Writing GDFS var 0000/0003/0004 Writing GDFS var 0000/0004/0001 Writing GDFS var 0000/0005/0044 Writing GDFS var 0000/0006/0044 Writing GDFS var 0000/0007/0001 Writing GDFS var 0000/0008/0012 Writing GDFS var 0000/0009/0028 Writing GDFS var 0000/000A/0028 Writing GDFS var 0000/000D/0001 Writing GDFS var 0000/000E/000C Writing GDFS var 0000/000F/0002 Writing GDFS var 0000/0010/0001 Writing GDFS var 0000/001B/0026 Writing GDFS var 0000/001F/000E Writing GDFS var 0000/0020/0018 Writing GDFS var 0000/0021/0001 Writing GDFS var 0000/0022/0001 Writing GDFS var 0000/0023/0018 Writing GDFS var 0000/0024/0044 Writing GDFS var 0000/0025/0044 Writing GDFS var 0000/0026/0022 Writing GDFS var 0000/0027/0002 Writing GDFS var 0000/0028/0002 Writing GDFS var 0000/0029/0002 Writing GDFS var 0000/002A/0002 Writing GDFS var 0000/002B/0002 Writing GDFS var 0000/002C/0002 Writing GDFS var 0000/002D/0002 Writing GDFS var 0000/002E/0008 Writing GDFS var 0000/002F/0008 Writing GDFS var 0000/0030/0008 Writing GDFS var 0000/0031/0008 Writing GDFS var 0000/0032/0008 Writing GDFS var 0000/0033/0008 Writing GDFS var 0000/0034/0008 Writing GDFS var 0000/0035/0008 Writing GDFS var 0000/0036/0008 Writing GDFS var 0000/0037/0008 Writing GDFS var 0000/0038/0008 Writing GDFS var 0000/0039/0008 Writing GDFS var 0000/003A/0008 Writing GDFS var 0000/003B/0008 Writing GDFS var 0000/003C/0008 Writing GDFS var 0000/003D/0008 Writing GDFS var 0000/005A/0001 Writing GDFS var 0000/005B/0001 Writing GDFS var 0000/005C/000A Writing GDFS var 0000/005D/0002 Writing GDFS var 0000/005E/0006 Writing GDFS var 0000/005F/0002 Writing GDFS var 0000/0060/0002 Writing GDFS var 0000/0061/0002 Writing GDFS var 0000/0062/0002 Writing GDFS var 0000/0063/0001 Writing GDFS var 0000/0064/0001 Writing GDFS var 0000/0065/0014 Writing GDFS var 0000/00B5/0001 Writing GDFS var 0000/00BE/0001 Writing GDFS var 0000/011A/0004 Writing GDFS var 0000/0127/0001 Writing GDFS var 0000/0128/0001 Writing GDFS var 0000/017C/0002 Writing GDFS var 0000/017D/0002 Writing GDFS var 0000/017E/0002 Writing GDFS var 0000/017F/0002 Writing GDFS var 0000/0180/0002 Writing GDFS var 0000/0181/0002 Writing GDFS var 0000/0182/0002 Writing GDFS var 0000/0183/0002 Writing GDFS var 0000/0184/0002 Writing GDFS var 0000/0185/0002 Writing GDFS var 0000/0186/0002 Writing GDFS var 0000/0187/0002 Writing GDFS var 0000/0188/0002 Writing GDFS var 0000/0189/0002 Writing GDFS var 0000/018A/0002 Writing GDFS var 0000/018B/0002 Writing GDFS var 0000/018C/0002 Writing GDFS var 0000/018D/0002 Writing GDFS var 0000/018E/0002 Writing GDFS var 0000/018F/0002 Writing GDFS var 0000/0190/0002 Writing GDFS var 0000/0191/0002 Writing GDFS var 0000/0192/0002 Writing GDFS var 0000/0193/0002 Writing GDFS var 0000/0194/0002 Writing GDFS var 0000/0195/0002 Writing GDFS var 0000/0196/0002 Writing GDFS var 0000/0197/0002 Writing GDFS var 0000/0198/0004 Writing GDFS var 0000/0199/0004 Writing GDFS var 0000/019A/0004 Writing GDFS var 0000/019B/0040 Writing GDFS var 0000/019C/0002 Writing GDFS var 0000/019D/0002 Writing GDFS var 0000/019E/0002 Writing GDFS var 0000/019F/0002 Writing GDFS var 0000/01A0/0002 Writing GDFS var 0000/01A1/0002 Writing GDFS var 0000/01A2/0002 Writing GDFS var 0000/01A3/0002 Writing GDFS var 0000/01A4/0002 Writing GDFS var 0000/01A5/0002 Writing GDFS var 0000/01A6/0002 Writing GDFS var 0000/01A7/0002 Writing GDFS var 0000/01A8/0002 Writing GDFS var 0000/01A9/0002 Writing GDFS var 0000/01AA/0002 Writing GDFS var 0000/01AB/0002 Writing GDFS var 0000/01AC/0002 Writing GDFS var 0000/01AD/0002 Writing GDFS var 0000/01AE/0002 Writing GDFS var 0000/01AF/0002 Writing GDFS var 0000/01B0/0002 Writing GDFS var 0000/01B1/0002 Writing GDFS var 0000/01B2/0002 Writing GDFS var 0000/01B3/0002 Writing GDFS var 0000/01B4/0002 Writing GDFS var 0000/01B5/0002 Writing GDFS var 0000/01B6/0002 Writing GDFS var 0000/01B7/0002 Writing GDFS var 0000/01B8/0001 Writing GDFS var 0000/01B9/0002 Writing GDFS var 0000/01BA/0008 Writing GDFS var 0000/01BB/0002 Writing GDFS var 0000/01BC/0002 Writing GDFS var 0000/01BD/0002 Writing GDFS var 0000/01BE/0002 Writing GDFS var 0000/01BF/0002 Writing GDFS var 0000/01C0/0002 Writing GDFS var 0000/01C1/0002 Writing GDFS var 0000/01C2/0002 Writing GDFS var 0000/01C3/0002 Writing GDFS var 0000/01C4/0002 Writing GDFS var 0000/01C5/0002 Writing GDFS var 0000/01C6/0002 Writing GDFS var 0000/01C7/0002 Writing GDFS var 0000/01C8/0002 Writing GDFS var 0000/01C9/0002 Writing GDFS var 0000/01CA/0002 Writing GDFS var 0000/01CB/0002 Writing GDFS var 0000/01CC/0002 Writing GDFS var 0000/01CD/0002 Writing GDFS var 0000/01CE/0002 Writing GDFS var 0000/01CF/0002 Writing GDFS var 0000/01D0/0002 Writing GDFS var 0000/01D1/0002 Writing GDFS var 0000/01D2/0002 Writing GDFS var 0000/01D3/0002 Writing GDFS var 0000/01D4/0002 Writing GDFS var 0000/01D5/0002 Writing GDFS var 0000/01D6/0002 Writing GDFS var 0000/01D7/0002 Writing GDFS var 0000/01D8/0002 Writing GDFS var 0000/01D9/0002 Writing GDFS var 0000/01DA/0002 Writing GDFS var 0000/01DB/0002 Writing GDFS var 0000/01DC/0002 Writing GDFS var 0000/01DD/0002 Writing GDFS var 0000/01DE/0002 Writing GDFS var 0000/01DF/0002 Writing GDFS var 0000/01E0/0002 Writing GDFS var 0000/01E1/0002 Writing GDFS var 0000/01E2/0002 Writing GDFS var 0000/01E3/0002 Writing GDFS var 0000/01E4/0002 Writing GDFS var 0000/01E5/0002 Writing GDFS var 0000/01E6/0002 Writing GDFS var 0000/01E7/0002 Writing GDFS var 0000/01E8/0002 Writing GDFS var 0000/01E9/0002 Writing GDFS var 0000/01EA/0002 Writing GDFS var 0000/01EB/0002 Writing GDFS var 0000/01EC/0002 Writing GDFS var 0000/01ED/0002 Writing GDFS var 0000/01EE/0002 Writing GDFS var 0000/01EF/0002 Writing GDFS var 0000/01F0/0002 Writing GDFS var 0000/01F1/0002 Writing GDFS var 0000/01F2/0002 Writing GDFS var 0000/01F3/0002 Writing GDFS var 0000/01F4/0002 Writing GDFS var 0000/01F5/0002 Writing GDFS var 0000/01F6/0002 Writing GDFS var 0000/0208/0001 Writing GDFS var 0000/031E/0005 Writing GDFS var 0000/031F/0006 Writing GDFS var 0000/0320/0001 Writing GDFS var 0000/0323/0010 Writing GDFS var 0000/0324/0018 Writing GDFS var 0000/0325/0001 Writing GDFS var 0000/03E8/01D8 Writing GDFS var 0000/03E9/0010 Writing GDFS var 0000/03EA/001E Writing GDFS var 0000/03EB/0010 Writing GDFS var 0000/03EC/0004 Writing GDFS var 0000/03ED/0001 Writing GDFS var 0000/03EE/0001 Writing GDFS var 0000/03EF/0050 Writing GDFS var 0000/03F0/0078 Writing GDFS var 0000/03F1/0001 Writing GDFS var 0000/03F2/0004 Elapsed: 745 secs. |
10-05-2011, 06:04 | #2 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | i also try to flash without signmode butr no luck see log [CODE] RUNNING v 1.1108/01.10/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_RC.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 763 blocks ... ssw file accepted SIGNING ... Elapsed: 597 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... [A2_fout_ssw] can't get ACK subblock (00520000/00010000) NAK Elapsed: 41 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted SIGNING ... Processing script "D:\setool\M5650\m5650xija1.gdfs" ... Writing ACC GDFS var 0000/0002/0004 Writing ACC GDFS var 0000/0003/0004 Writing ACC GDFS var 0000/0004/0001 Writing ACC GDFS var 0000/0006/0006 Writing ACC GDFS var 0000/0007/0001 Writing ACC GDFS var 0000/0008/0001 Writing ACC GDFS var 0000/0009/0028 Writing ACC GDFS var 0000/000A/0028 Writing ACC GDFS var 0000/000E/000C Writing ACC GDFS var 0000/000F/0002 Writing ACC GDFS var 0000/0027/0008 Writing ACC GDFS var 0000/0028/0008 Writing ACC GDFS var 0000/0029/0008 Writing ACC GDFS var 0000/002A/0008 Writing ACC GDFS var 0000/002B/0008 Writing ACC GDFS var 0000/002C/0008 Writing ACC GDFS var 0000/002D/0008 Writing ACC GDFS var 0000/002E/0008 Writing ACC GDFS var 0000/002F/0008 Writing ACC GDFS var 0000/0030/0008 Writing ACC GDFS var 0000/0031/0008 Writing ACC GDFS var 0000/0032/0008 Writing ACC GDFS var 0000/0033/0008 Writing ACC GDFS var 0000/0034/0008 Writing ACC GDFS var 0000/0035/0008 Writing ACC GDFS var 0000/0036/0008 Writing ACC GDFS var 0000/0050/0001 Writing ACC GDFS var 0000/0051/0001 Writing ACC GDFS var 0000/0052/000A Writing ACC GDFS var 0000/0053/0002 Writing ACC GDFS var 0000/0054/0006 Writing ACC GDFS var 0000/0055/0002 Writing ACC GDFS var 0000/0056/0002 Writing ACC GDFS var 0000/0057/0002 Writing ACC GDFS var 0000/0058/0002 Writing ACC GDFS var 0000/0059/0001 Writing ACC GDFS var 0000/005A/0001 Writing ACC GDFS var 0000/005B/0001 Writing ACC GDFS var 0000/005C/0001 Writing ACC GDFS var 0000/005D/0001 Writing ACC GDFS var 0000/005E/0001 Writing ACC GDFS var 0000/005F/0001 Writing ACC GDFS var 0000/0060/0001 Writing ACC GDFS var 0000/0062/0001 Writing ACC GDFS var 0000/0063/0001 Writing ACC GDFS var 0000/0065/0001 Writing ACC GDFS var 0000/0066/0014 Writing ACC GDFS var 0000/00A2/0001 Writing ACC GDFS var 0000/00A4/0002 Writing ACC GDFS var 0000/00A5/0006 Writing ACC GDFS var 0000/00A6/0001 Writing ACC GDFS var 0000/00A7/0064 Writing ACC GDFS var 0000/00A8/00F8 Writing ACC GDFS var 0000/00A9/0001 Writing ACC GDFS var 0000/00AA/0400 Writing ACC GDFS var 0000/00AB/0280 Writing ACC GDFS var 0000/00AC/0080 Writing ACC GDFS var 0000/00AD/0040 Writing ACC GDFS var 0000/00AE/0006 Writing ACC GDFS var 0000/00AF/0001 Writing ACC GDFS var 0000/00B0/0004 Writing ACC GDFS var 0000/00B1/0002 Writing ACC GDFS var 0000/00B2/0100 Writing ACC GDFS var 0000/00B3/0200 Writing ACC GDFS var 0000/00B4/0001 Writing ACC GDFS var 0000/00B5/0001 Writing ACC GDFS var 0000/00B6/0001 Writing ACC GDFS var 0000/00B7/0002 Writing ACC GDFS var 0000/00B8/0006 Writing ACC GDFS var 0000/00B9/0006 Writing ACC GDFS var 0000/00BA/0006 Writing ACC GDFS var 0000/00EE/0001 Writing ACC GDFS var 0000/0118/0014 Writing ACC GDFS var 0000/0119/0002 Writing ACC GDFS var 0000/011A/0002 Writing ACC GDFS var 0000/011B/0002 Writing ACC GDFS var 0000/011C/0002 Writing ACC GDFS var 0000/0122/0001 Writing ACC GDFS var 0000/0123/0031 Writing ACC GDFS var 0000/0124/0001 Writing ACC GDFS var 0000/0125/0001 Writing ACC GDFS var 0000/0126/0003 Writing ACC GDFS var 0000/0127/0009 Writing ACC GDFS var 0000/0128/0001 Writing ACC GDFS var 0000/0129/0001 Writing ACC GDFS var 0000/012A/0001 Writing ACC GDFS var 0000/012B/0001 Writing ACC GDFS var 0000/012C/0001 Writing ACC GDFS var 0000/012D/0003 Writing ACC GDFS var 0000/012E/0003 Writing ACC GDFS var 0000/012F/0004 Writing ACC GDFS var 0000/0130/0004 Writing ACC GDFS var 0000/0131/0004 Writing ACC GDFS var 0000/0132/0004 Writing ACC GDFS var 0000/0133/0008 Writing ACC GDFS var 0000/0134/0005 Writing ACC GDFS var 0000/0135/0001 Writing ACC GDFS var 0000/0136/0001 Writing ACC GDFS var 0000/0137/0001 Writing ACC GDFS var 0000/0138/0061 Writing ACC GDFS var 0000/0139/0001 Writing ACC GDFS var 0000/013A/0001 Writing ACC GDFS var 0000/013B/0001 Writing ACC GDFS var 0000/013C/0001 Writing ACC GDFS var 0000/013D/0001 Writing ACC GDFS var 0000/013E/0001 Writing ACC GDFS var 0000/013F/0001 Writing ACC GDFS var 0000/0140/0001 Writing ACC GDFS var 0000/0141/0001 Writing ACC GDFS var 0000/0142/0001 Writing ACC GDFS var 0000/0143/0001 Writing ACC GDFS var 0000/0144/0001 Writing ACC GDFS var 0000/0145/0001 Writing ACC GDFS var 0000/0146/0001 Writing ACC GDFS var 0000/0147/0001 Writing ACC GDFS var 0000/0148/0001 Writing ACC GDFS var 0000/0149/0001 Writing ACC GDFS var 0000/014A/003D Writing ACC GDFS var 0000/014B/0001 Writing ACC GDFS var 0000/014C/0001 Writing ACC GDFS var 0000/014D/0001 Writing ACC GDFS var 0000/014E/0001 Writing ACC GDFS var 0000/014F/0001 Writing ACC GDFS var 0000/0150/0001 Writing ACC GDFS var 0000/0151/0001 Writing ACC GDFS var 0000/0152/0007 Writing ACC GDFS var 0000/0153/0001 Writing ACC GDFS var 0000/0154/003D Writing ACC GDFS var 0000/0155/0001 Writing ACC GDFS var 0000/0156/0001 Writing ACC GDFS var 0000/0157/0001 Writing ACC GDFS var 0000/0158/0001 Writing ACC GDFS var 0000/0159/0001 Writing ACC GDFS var 0000/015A/0001 Writing ACC GDFS var 0000/015B/0001 Writing ACC GDFS var 0000/015C/0001 Writing ACC GDFS var 0000/015D/0001 Writing ACC GDFS var 0000/015E/0001 Writing ACC GDFS var 0000/015F/0001 Writing ACC GDFS var 0000/0160/0001 Writing ACC GDFS var 0000/0161/0001 Writing ACC GDFS var 0000/0162/0001 Writing ACC GDFS var 0000/0163/0001 Writing ACC GDFS var 0000/0164/0001 Writing ACC GDFS var 0000/0165/0001 Writing ACC GDFS var 0000/0166/0001 Writing ACC GDFS var 0000/0167/0001 Writing ACC GDFS var 0000/016A/000A Writing ACC GDFS var 0000/016B/0001 Writing ACC GDFS var 0000/016C/000F Writing ACC GDFS var 0000/0186/000A Writing ACC GDFS var 0000/0187/0002 Writing ACC GDFS var 0000/0188/001E Writing ACC GDFS var 0000/0189/0002 Writing ACC GDFS var 0000/018A/0002 Writing ACC GDFS var 0000/018B/0002 Writing ACC GDFS var 0000/018C/0002 Writing ACC GDFS var 0000/018D/0002 Writing ACC GDFS var 0000/018E/0002 Writing ACC GDFS var 0000/018F/0001 Writing ACC GDFS var 0000/0190/0001 Writing ACC GDFS var 0000/0191/0001 Writing ACC GDFS var 0000/0192/0001 Writing ACC GDFS var 0000/0193/0001 Writing ACC GDFS var 0000/0194/0004 Writing ACC GDFS var 0000/0195/0004 Writing ACC GDFS var 0000/0196/0004 Writing ACC GDFS var 0000/0197/0004 Writing ACC GDFS var 0000/0198/0004 Writing ACC GDFS var 0000/0199/0001 Writing ACC GDFS var 0000/019A/0001 Writing ACC GDFS var 0000/019B/0004 Writing ACC GDFS var 0000/019C/000A Writing ACC GDFS var 0000/019D/0001 Writing ACC GDFS var 0000/019F/0001 Writing ACC GDFS var 0000/01A1/0004 Writing ACC GDFS var 0000/01A2/0001 Writing ACC GDFS var 0000/01A3/0001 Writing ACC GDFS var 0000/01A4/0001 Writing ACC GDFS var 0000/01A5/0001 Writing ACC GDFS var 0000/01A6/0001 Writing ACC GDFS var 0000/01A7/0001 Writing ACC GDFS var 0000/01A8/0002 Writing ACC GDFS var 0000/01A9/0001 Writing ACC GDFS var 0000/01AA/0001 Writing ACC GDFS var 0000/01AB/0001 Writing ACC GDFS var 0000/01C2/0001 Writing ACC GDFS var 0000/01C3/0002 Writing ACC GDFS var 0000/01C4/0002 Writing ACC GDFS var 0000/01C5/0002 Writing ACC GDFS var 0000/01C6/0002 Writing ACC GDFS var 0000/01C7/0002 Writing ACC GDFS var 0000/01C8/0002 Writing ACC GDFS var 0000/01C9/0002 Writing ACC GDFS var 0000/01CA/0002 Writing ACC GDFS var 0000/01CB/0002 Writing ACC GDFS var 0000/01CC/0002 Writing ACC GDFS var 0000/01CD/0002 Writing ACC GDFS var 0000/01CE/0002 Writing ACC GDFS var 0000/01CF/0002 Writing ACC GDFS var 0000/01D0/0002 Writing ACC GDFS var 0000/01D1/0002 Writing ACC GDFS var 0000/01D2/0002 Writing ACC GDFS var 0000/01D3/0002 Writing ACC GDFS var 0000/01D4/0002 Writing ACC GDFS var 0000/01D5/0002 Writing ACC GDFS var 0000/01D6/0002 Writing ACC GDFS var 0000/01D7/0002 Writing ACC GDFS var 0000/01D8/0002 Writing ACC GDFS var 0000/01D9/0002 Writing ACC GDFS var 0000/01DA/0002 Writing ACC GDFS var 0000/01DB/0002 Writing ACC GDFS var 0000/01DC/0002 Writing ACC GDFS var 0000/01DD/0002 Writing ACC GDFS var 0000/01DE/0002 Writing ACC GDFS var 0000/01DF/0002 Writing ACC GDFS var 0000/01E0/0002 Writing ACC GDFS var 0000/01E1/0002 Writing ACC GDFS var 0000/01E2/0002 Writing ACC GDFS var 0000/01E3/0002 Writing ACC GDFS var 0000/01E4/0002 Writing ACC GDFS var 0000/01E5/0002 Writing ACC GDFS var 0000/01E6/0002 Writing ACC GDFS var 0000/01E7/0002 Writing ACC GDFS var 0000/01E8/0002 Writing ACC GDFS var 0000/01E9/0002 Writing ACC GDFS var 0000/01EA/0002 Writing ACC GDFS var 0000/01EB/0002 Writing ACC GDFS var 0000/01EC/0002 Writing ACC GDFS var 0000/01ED/0002 Writing ACC GDFS var 0000/01EE/0002 Writing ACC GDFS var 0000/01EF/0002 Writing ACC GDFS var 0000/01F0/0002 Writing ACC GDFS var 0000/01F1/0002 Writing ACC GDFS var 0000/01F2/0002 Writing ACC GDFS var 0000/01F3/0002 Writing ACC GDFS var 0000/01F4/0002 Writing ACC GDFS var 0000/01F5/0002 Writing ACC GDFS var 0000/01F6/0002 Writing ACC GDFS var 0000/01F7/0002 Writing ACC GDFS var 0000/01F8/0002 Writing ACC GDFS var 0000/01F9/0002 Writing ACC GDFS var 0000/01FA/0002 Writing ACC GDFS var 0000/01FB/0002 Writing ACC GDFS var 0000/01FC/0002 Writing ACC GDFS var 0000/01FD/0002 Writing ACC GDFS var 0000/01FE/0002 Writing ACC GDFS var 0000/01FF/0002 Writing ACC GDFS var 0000/0200/0002 Writing ACC GDFS var 0000/0201/0002 Writing ACC GDFS var 0000/0202/0002 Writing ACC GDFS var 0000/0203/0002 Writing ACC GDFS var 0000/0204/0002 Writing ACC GDFS var 0000/0205/0002 Writing ACC GDFS var 0000/0206/0002 Writing ACC GDFS var 0000/0207/0002 Writing ACC GDFS var 0000/0208/0002 Writing ACC GDFS var 0000/0209/0002 Writing ACC GDFS var 0000/020A/0002 Writing ACC GDFS var 0000/020B/0002 Writing ACC GDFS var 0000/020C/0002 Writing ACC GDFS var 0000/020D/0002 Writing ACC GDFS var 0000/020E/0002 Writing ACC GDFS var 0000/020F/0002 Writing ACC GDFS var 0000/0210/0002 Writing ACC GDFS var 0000/0211/0002 Writing ACC GDFS var 0000/0212/0002 Writing ACC GDFS var 0000/0213/0002 Writing ACC GDFS var 0000/0214/0002 Writing ACC GDFS var 0000/0215/0002 Writing ACC GDFS var 0000/0216/0002 Writing ACC GDFS var 0000/0217/0002 Writing ACC GDFS var 0000/0218/0002 Writing ACC GDFS var 0000/0219/0002 Writing ACC GDFS var 0000/021A/0002 Writing ACC GDFS var 0000/021B/0002 Writing ACC GDFS var 0000/021C/0002 Writing ACC GDFS var 0000/021D/0002 Writing ACC GDFS var 0000/021E/0002 Writing ACC GDFS var 0000/021F/0002 Writing ACC GDFS var 0000/0220/0002 Writing ACC GDFS var 0000/0221/0002 Writing ACC GDFS var 0000/0222/0002 Writing ACC GDFS var 0000/0223/0002 Writing ACC GDFS var 0000/0224/0002 Writing ACC GDFS var 0000/0225/0002 Writing ACC GDFS var 0000/0226/0002 Writing ACC GDFS var 0000/0227/0002 Writing ACC GDFS var 0000/0228/0002 Writing ACC GDFS var 0000/0229/0002 Writing ACC GDFS var 0000/022A/0002 Writing ACC GDFS var 0000/022B/0002 Writing ACC GDFS var 0000/022C/0002 Writing ACC GDFS var 0000/022D/0002 Writing ACC GDFS var 0000/022E/0002 Writing ACC GDFS var 0000/022F/0002 Writing ACC GDFS var 0000/0230/0002 Writing ACC GDFS var 0000/0231/0002 Writing ACC GDFS var 0000/0232/0002 Writing ACC GDFS var 0000/0233/0002 Writing ACC GDFS var 0000/0234/0002 Writing ACC GDFS var 0000/0235/0002 Writing ACC GDFS var 0000/0236/0002 Writing ACC GDFS var 0000/0237/0002 Writing ACC GDFS var 0000/0238/0002 Writing ACC GDFS var 0000/0239/0002 Writing ACC GDFS var 0000/023A/0002 Writing ACC GDFS var 0000/023B/0002 Writing ACC GDFS var 0000/023C/0002 Writing ACC GDFS var 0000/023D/0002 Writing ACC GDFS var 0000/023E/0002 Writing ACC GDFS var 0000/023F/0002 Writing ACC GDFS var 0000/0240/0002 Writing ACC GDFS var 0000/0241/0002 Writing ACC GDFS var 0000/0242/0002 Writing ACC GDFS var 0000/0243/0002 Writing ACC GDFS var 0000/0244/0002 Writing ACC GDFS var 0000/0245/0002 Writing ACC GDFS var 0000/0246/0002 Writing ACC GDFS var 0000/0247/0002 Writing ACC GDFS var 0000/0248/0002 Writing ACC GDFS var 0000/0249/0002 Writing ACC GDFS var 0000/024A/0002 Writing ACC GDFS var 0000/024B/0004 Writing ACC GDFS var 0000/024C/0004 Writing ACC GDFS var 0000/024D/0004 Writing ACC GDFS var 0000/024E/0004 Writing ACC GDFS var 0000/024F/0004 Writing ACC GDFS var 0000/0250/0004 Writing ACC GDFS var 0000/0251/0004 Writing ACC GDFS var 0000/0252/0004 Writing ACC GDFS var 0000/0253/0002 Writing ACC GDFS var 0000/0256/0004 Writing ACC GDFS var 0000/0257/0004 Writing ACC GDFS var 0000/0258/0004 Writing ACC GDFS var 0000/0259/0004 Writing ACC GDFS var 0000/025A/0004 Writing ACC GDFS var 0000/025B/0004 Writing ACC GDFS var 0000/025C/0004 Writing ACC GDFS var 0000/025D/0004 Writing ACC GDFS var 0000/025E/0002 Writing ACC GDFS var 0000/025F/0001 Writing ACC GDFS var 0000/0261/000B Writing ACC GDFS var 0000/0262/0016 Writing ACC GDFS var 0000/0263/0002 Writing ACC GDFS var 0000/0264/0002 Writing ACC GDFS var 0000/0265/0002 Writing ACC GDFS var 0000/0266/0002 Writing ACC GDFS var 0000/028A/0002 Writing ACC GDFS var 0000/028B/0001 Writing ACC GDFS var 0000/028F/0044 Writing ACC GDFS var 0000/0290/0004 Writing ACC GDFS var 0000/0291/0001 Writing ACC GDFS var 0000/0292/0001 Writing ACC GDFS var 0000/0293/000F Writing ACC GDFS var 0000/0294/0002 Writing ACC GDFS var 0000/0295/0001 Writing ACC GDFS var 0000/0296/0001 Writing ACC GDFS var 0000/0297/0001 Writing ACC GDFS var 0000/0298/0001 Writing ACC GDFS var 0000/0299/0001 Writing ACC GDFS var 0000/029A/0001 Writing ACC GDFS var 0000/029B/0001 Writing ACC GDFS var 0000/029C/000A Writing ACC GDFS var 0000/029D/000A Writing ACC GDFS var 0000/029E/0001 Writing ACC GDFS var 0000/029F/0001 Writing ACC GDFS var 0000/02A0/0010 Writing ACC GDFS var 0000/02A1/0010 Writing ACC GDFS var 0000/02A2/0010 Writing ACC GDFS var 0000/02A3/0010 Writing ACC GDFS var 0000/02A4/0001 Writing ACC GDFS var 0000/02A5/0001 Writing ACC GDFS var 0000/02A6/0002 Writing ACC GDFS var 0000/02A7/0002 Writing ACC GDFS var 0000/02A8/0002 Writing ACC GDFS var 0000/02A9/0001 Writing ACC GDFS var 0000/02AA/0001 Writing ACC GDFS var 0000/02AB/0002 Writing ACC GDFS var 0000/02AC/0002 Writing ACC GDFS var 0000/02AD/0001 Writing ACC GDFS var 0000/02AE/0001 Writing ACC GDFS var 0000/02AF/0003 Writing ACC GDFS var 0000/02B0/0003 Writing ACC GDFS var 0000/02B1/0003 Writing ACC GDFS var 0000/02B2/0003 Writing ACC GDFS var 0000/02B3/0003 Writing ACC GDFS var 0000/02B4/0003 Writing ACC GDFS var 0000/02B5/0003 Writing ACC GDFS var 0000/02B6/0003 Writing ACC GDFS var 0000/02B7/0003 Writing ACC GDFS var 0000/02B8/0003 Writing ACC GDFS var 0000/02B9/0003 Writing ACC GDFS var 0000/02BA/0003 Writing ACC GDFS var 0000/02BB/0003 Writing ACC GDFS var 0000/02BC/0003 Writing ACC GDFS var 0000/02BD/0003 Writing ACC GDFS var 0000/02BE/0003 Writing ACC GDFS var 0000/02BF/0003 Writing ACC GDFS var 0000/02C0/0003 Writing ACC GDFS var 0000/02C1/0003 Writing ACC GDFS var 0000/02C2/0003 Writing ACC GDFS var 0000/02C3/0003 Writing ACC GDFS var 0000/02C4/0003 Writing ACC GDFS var 0000/02C5/0003 Writing ACC GDFS var 0000/02C6/0003 Writing ACC GDFS var 0000/02C7/0003 Writing ACC GDFS var 0000/02C8/0003 Writing ACC GDFS var 0000/02C9/0003 Writing ACC GDFS var 0000/02CA/0003 Writing ACC GDFS var 0000/02CB/0003 Writing ACC GDFS var 0000/02CC/0003 Writing ACC GDFS var 0000/02CD/0001 Writing ACC GDFS var 0000/02DA/0001 Writing ACC GDFS var 0000/02DB/0003 Writing ACC GDFS var 0000/02DC/0003 Writing ACC GDFS var 0000/02DD/0003 Writing ACC GDFS var 0000/02DE/0003 Writing ACC GDFS var 0000/02DF/0001 Writing ACC GDFS var 0000/02E0/0002 Writing ACC GDFS var 0000/02E1/0002 Writing ACC GDFS var 0000/02E2/0002 Writing ACC GDFS var 0000/02E3/0002 Writing ACC GDFS var 0000/02E4/0002 Writing ACC GDFS var 0000/02E5/0002 Writing ACC GDFS var 0000/02E6/0002 Writing ACC GDFS var 0000/02E7/0002 Writing ACC GDFS var 0000/02E8/0002 Writing ACC GDFS var 0000/02E9/0001 Writing ACC GDFS var 0000/02EA/0001 Writing ACC GDFS var 0000/02EB/0001 Writing ACC GDFS var 0000/02EC/0001 Writing ACC GDFS var 0000/02ED/0001 Writing ACC GDFS var 0000/02EE/0001 Writing ACC GDFS var 0000/02EF/0001 Writing ACC GDFS var 0000/02F0/0001 Writing ACC GDFS var 0000/02F1/0001 Writing ACC GDFS var 0000/02F2/0002 Writing ACC GDFS var 0000/02F6/0001 Writing ACC GDFS var 0000/02F7/0001 Writing ACC GDFS var 0000/02F8/0001 Writing ACC GDFS var 0000/02F9/0001 Writing ACC GDFS var 0000/02FA/0001 Writing ACC GDFS var 0000/02FB/0001 Writing ACC GDFS var 0000/02FC/0001 Writing ACC GDFS var 0000/02FD/0001 Writing ACC GDFS var 0000/02FE/0001 Writing ACC GDFS var 0000/02FF/0001 Writing ACC GDFS var 0000/0300/0001 Writing ACC GDFS var 0000/0301/0054 Writing ACC GDFS var 0000/0302/0054 Writing ACC GDFS var 0000/0303/0054 Writing ACC GDFS var 0000/0304/0054 Writing ACC GDFS var 0000/0305/0054 Writing ACC GDFS var 0000/0306/0054 Writing ACC GDFS var 0000/0307/0054 Writing ACC GDFS var 0000/0308/0054 Writing ACC GDFS var 0000/0309/0054 Writing ACC GDFS var 0000/030A/0054 Writing ACC GDFS var 0000/030B/0054 Writing ACC GDFS var 0000/030C/0002 Writing ACC GDFS var 0000/030D/0002 Writing ACC GDFS var 0000/030E/0002 Writing ACC GDFS var 0000/030F/0002 Writing ACC GDFS var 0000/0310/0006 Writing ACC GDFS var 0000/0311/000A Writing ACC GDFS var 0000/0312/000A Writing ACC GDFS var 0000/0313/000A Writing ACC GDFS var 0000/0314/000A Writing ACC GDFS var 0000/0315/0100 Writing ACC GDFS var 0000/0316/0100 Writing ACC GDFS var 0000/0317/0100 Writing ACC GDFS var 0000/0318/0018 Writing ACC GDFS var 0000/0319/0018 Writing ACC GDFS var 0000/031A/0018 Writing ACC GDFS var 0000/031B/0018 Writing ACC GDFS var 0000/031C/0020 Writing ACC GDFS var 0000/031D/001A Writing ACC GDFS var 0000/031E/0002 Writing ACC GDFS var 0000/031F/0200 Writing ACC GDFS var 0000/0320/0004 Writing ACC GDFS var 0000/0321/0006 Writing ACC GDFS var 0000/0322/0008 Writing ACC GDFS var 0000/0323/0040 Writing ACC GDFS var 0000/0324/001A Writing ACC GDFS var 0000/0325/001A Writing ACC GDFS var 0000/0326/001A Writing ACC GDFS var 0000/0327/0020 Writing ACC GDFS var 0000/0328/0020 Writing ACC GDFS var 0000/0329/0020 Writing ACC GDFS var 0000/032A/04C0 Writing ACC GDFS var 0000/032B/04C0 Writing ACC GDFS var 0000/032C/04C0 Writing ACC GDFS var 0000/032D/04C0 Writing ACC GDFS var 0000/032E/04C0 Writing ACC GDFS var 0000/032F/04C0 Writing ACC GDFS var 0000/0330/04C0 Writing ACC GDFS var 0000/0331/04C0 Writing ACC GDFS var 0000/0332/04C0 Writing ACC GDFS var 0000/0333/04C0 Writing ACC GDFS var 0000/0334/04C0 Writing ACC GDFS var 0000/0335/04C0 Writing ACC GDFS var 0000/0336/04C0 Writing ACC GDFS var 0000/0337/04C0 Writing ACC GDFS var 0000/0338/04C0 Writing ACC GDFS var 0000/0339/04C0 Writing ACC GDFS var 0000/033A/04C0 Writing ACC GDFS var 0000/033B/04C0 Writing ACC GDFS var 0000/033C/04C0 Writing ACC GDFS var 0000/033D/04C0 Writing ACC GDFS var 0000/033E/04C0 Writing ACC GDFS var 0000/033F/04C0 Writing ACC GDFS var 0000/0340/04C0 Writing ACC GDFS var 0000/0341/04C0 Writing ACC GDFS var 0000/0342/04C0 Writing ACC GDFS var 0000/0343/04C0 Writing ACC GDFS var 0000/0344/04C0 Writing ACC GDFS var 0000/0345/04C0 Writing ACC GDFS var 0000/0346/04C0 Writing ACC GDFS var 0000/0347/04C0 Writing ACC GDFS var 0000/0348/04C0 Writing ACC GDFS var 0000/0349/04C0 Writing ACC GDFS var 0000/034A/04C0 Writing ACC GDFS var 0000/034B/04C0 Writing ACC GDFS var 0000/034C/04C0 Writing ACC GDFS var 0000/034D/04C0 Writing ACC GDFS var 0000/034E/04C0 Writing ACC GDFS var 0000/034F/04C0 Writing ACC GDFS var 0000/0350/04C0 Writing ACC GDFS var 0000/0351/04C0 Writing ACC GDFS var 0000/0352/04C0 Writing ACC GDFS var 0000/0353/04C0 Writing ACC GDFS var 0000/0354/04C0 Writing ACC GDFS var 0000/0355/04C0 Writing ACC GDFS var 0000/0356/04C0 Writing ACC GDFS var 0000/0357/04C0 Writing ACC GDFS var 0000/0358/04C0 Writing ACC GDFS var 0000/0359/04C0 Writing ACC GDFS var 0000/035A/04C0 Writing ACC GDFS var 0000/035B/04C0 Writing ACC GDFS var 0000/035C/04C0 Writing ACC GDFS var 0000/035D/04C0 Writing ACC GDFS var 0000/035E/04C0 Writing ACC GDFS var 0000/035F/04C0 Writing ACC GDFS var 0000/0360/04C0 Writing ACC GDFS var 0000/0361/04C0 Writing ACC GDFS var 0000/0362/04C0 Writing ACC GDFS var 0000/0363/04C0 Writing ACC GDFS var 0000/0364/04C0 Writing ACC GDFS var 0000/0365/04C0 Writing ACC GDFS var 0000/0366/04C0 Writing ACC GDFS var 0000/0367/04C0 Writing ACC GDFS var 0000/0368/04C0 Writing ACC GDFS var 0000/0369/04C0 Writing ACC GDFS var 0000/036A/04C0 Writing ACC GDFS var 0000/036B/04C0 Writing ACC GDFS var 0000/036C/04C0 Writing ACC GDFS var 0000/036D/04C0 Writing ACC GDFS var 0000/036E/04C0 Writing ACC GDFS var 0000/036F/04C0 Writing ACC GDFS var 0000/0370/04C0 Writing ACC GDFS var 0000/0371/04C0 Writing ACC GDFS var 0000/0372/04C0 Writing ACC GDFS var 0000/0373/04C0 Writing ACC GDFS var 0000/0374/04C0 Writing ACC GDFS var 0000/0375/00AE Writing ACC GDFS var 0000/0376/0020 Writing ACC GDFS var 0000/0377/0258 Writing ACC GDFS var 0000/0378/0002 Writing ACC GDFS var 0000/0379/0002 Writing ACC GDFS var 0000/037A/0002 Writing ACC GDFS var 0000/037B/0002 Writing ACC GDFS var 0000/037C/0010 Writing ACC GDFS var 0000/037D/0010 Writing ACC GDFS var 0000/037E/0010 Writing ACC GDFS var 0000/037F/0010 Writing ACC GDFS var 0000/0380/0018 Writing ACC GDFS var 0000/0381/0004 Writing ACC GDFS var 0000/0382/0004 Writing ACC GDFS var 0000/0383/0004 Writing ACC GDFS var 0000/0384/0004 Writing ACC GDFS var 0000/0385/0014 Writing ACC GDFS var 0000/0386/0014 Writing ACC GDFS var 0000/0387/001A Writing ACC GDFS var 0000/0388/0002 Writing ACC GDFS var 0000/0389/0110 Writing ACC GDFS var 0000/038A/0014 Writing ACC GDFS var 0000/038B/0030 Writing ACC GDFS var 0000/038C/0005 Writing ACC GDFS var 0000/038D/0004 Writing ACC GDFS var 0000/038E/0008 Writing ACC GDFS var 0000/038F/0008 Writing ACC GDFS var 0000/0390/0008 Writing ACC GDFS var 0000/0391/0008 Writing ACC GDFS var 0000/0392/0010 Writing ACC GDFS var 0000/0393/001A Writing ACC GDFS var 0000/0394/001A Writing ACC GDFS var 0000/0395/001A Writing ACC GDFS var 0000/0396/001A Writing ACC GDFS var 0000/0397/0010 Writing ACC GDFS var 0000/0398/0010 Writing ACC GDFS var 0000/0399/0010 Writing ACC GDFS var 0000/039A/0040 Writing ACC GDFS var 0000/039B/0001 Writing ACC GDFS var 0000/039C/0001 Writing ACC GDFS var 0000/039D/0001 Writing ACC GDFS var 0000/039E/0001 Writing ACC GDFS var 0000/039F/0002 Writing ACC GDFS var 0000/03A0/0001 Writing ACC GDFS var 0000/03A1/0004 Writing ACC GDFS var 0000/03A2/0004 Writing ACC GDFS var 0000/03A3/0004 Writing ACC GDFS var 0000/03A4/0001 Writing ACC GDFS var 0000/03A5/0001 Writing ACC GDFS var 0000/03A6/0001 Writing ACC GDFS var 0000/03A7/0004 Writing ACC GDFS var 0000/03B1/002A Writing ACC GDFS var 0000/03B2/0008 Writing ACC GDFS var 0000/03B3/0008 Writing ACC GDFS var 0000/03B4/0001 Writing ACC GDFS var 0000/03B5/0001 Writing ACC GDFS var 0000/03B6/0001 Writing ACC GDFS var 0000/03B7/0001 Writing ACC GDFS var 0000/03B8/0001 Writing ACC GDFS var 0000/03B9/0001 Writing ACC GDFS var 0000/03BA/0001 Writing ACC GDFS var 0000/03BB/0001 Writing ACC GDFS var 0000/03BC/0001 Writing ACC GDFS var 0000/03BD/0001 Writing ACC GDFS var 0000/03BE/0001 Writing ACC GDFS var 0000/03BF/0001 Writing ACC GDFS var 0000/03C0/0001 Writing ACC GDFS var 0000/03C1/0001 Writing ACC GDFS var 0000/03C2/0001 Writing ACC GDFS var 0000/03C3/0001 Writing ACC GDFS var 0000/03C4/0016 Writing ACC GDFS var 0000/03C5/0016 Writing ACC GDFS var 0000/03C6/0016 Writing ACC GDFS var 0000/03C7/0016 Writing ACC GDFS var 0000/03C8/0001 Writing ACC GDFS var 0000/03C9/0001 Writing ACC GDFS var 0000/03CA/0001 Writing ACC GDFS var 0000/03CB/0001 Writing ACC GDFS var 0000/03CC/0001 Writing ACC GDFS var 0000/03CD/0001 Writing ACC GDFS var 0000/03CE/0001 Writing ACC GDFS var 0000/03CF/0001 Writing ACC GDFS var 0000/03D4/04C0 Writing ACC GDFS var 0000/03DD/0100 Writing ACC GDFS var 0000/03DE/0002 Writing ACC GDFS var 0000/03E3/0001 Writing ACC GDFS var 0000/03E4/0001 Writing ACC GDFS var 0000/03E5/0001 Writing ACC GDFS var 0000/03E6/0001 Writing ACC GDFS var 0000/03E7/0001 Writing ACC GDFS var 0000/03EC/0004 Writing ACC GDFS var 0000/03FF/0004 Writing ACC GDFS var 0000/0400/0004 Writing ACC GDFS var 0000/0402/0001 Writing ACC GDFS var 0000/0403/001A Writing ACC GDFS var 0000/0404/001A Writing ACC GDFS var 0000/0405/001A Writing ACC GDFS var 0000/0407/0001 Writing ACC GDFS var 0000/0408/0001 Writing ACC GDFS var 0000/0409/0001 Writing ACC GDFS var 0000/040A/0001 Writing ACC GDFS var 0000/040B/0001 Writing ACC GDFS var 0000/040C/0001 Writing ACC GDFS var 0000/040D/0001 Writing ACC GDFS var 0000/040E/0001 Writing ACC GDFS var 0000/040F/0001 Writing ACC GDFS var 0000/0410/0001 Writing ACC GDFS var 0000/0411/0001 Writing ACC GDFS var 0000/0412/0001 Writing ACC GDFS var 0000/0413/0001 Writing ACC GDFS var 0000/0414/0001 Writing ACC GDFS var 0000/0415/0001 Writing ACC GDFS var 0000/0416/0001 Writing ACC GDFS var 0000/0417/0001 Writing ACC GDFS var 0000/0418/0001 Writing ACC GDFS var 0000/0419/0001 Writing ACC GDFS var 0000/041A/0001 Writing ACC GDFS var 0000/041B/0001 Writing ACC GDFS var 0000/041C/0001 Writing ACC GDFS var 0000/041D/0001 Writing ACC GDFS var 0000/041E/0001 Writing ACC GDFS var 0000/041F/0001 Writing ACC GDFS var 0000/0420/0001 Writing ACC GDFS var 0000/0421/0001 Writing ACC GDFS var 0000/0422/0001 Writing ACC GDFS var 0000/0423/0001 Writing ACC GDFS var 0000/0424/0001 Writing ACC GDFS var 0000/0425/0001 Writing ACC GDFS var 0000/0426/0001 Writing ACC GDFS var 0000/0427/0001 Writing ACC GDFS var 0000/0428/0001 Writing ACC GDFS var 0000/0429/0001 Writing ACC GDFS var 0000/042A/0001 Writing ACC GDFS var 0000/042B/000E Writing ACC GDFS var 0000/042C/000E Writing ACC GDFS var 0000/042D/000E Writing ACC GDFS var 0000/042E/000E Writing ACC GDFS var 0000/042F/0060 Writing ACC GDFS var 0000/0430/0060 Writing ACC GDFS var 0000/0431/0060 Writing ACC GDFS var 0000/0432/0060 Writing ACC GDFS var 0000/0433/0018 Writing ACC GDFS var 0000/0434/0018 Writing ACC GDFS var 0000/0435/0018 Writing ACC GDFS var 0000/0436/0018 Writing ACC GDFS var 0000/0437/0014 Writing ACC GDFS var 0000/0438/0002 Writing ACC GDFS var 0000/0439/0001 Writing ACC GDFS var 0000/043A/0001 Writing ACC GDFS var 0000/043B/0001 Writing ACC GDFS var 0000/043C/0001 Writing ACC GDFS var 0000/043D/0001 Writing ACC GDFS var 0000/043E/0001 Writing ACC GDFS var 0000/043F/0001 Writing ACC GDFS var 0000/0440/0001 Writing ACC GDFS var 0000/0441/0001 Writing ACC GDFS var 0000/0442/0001 Writing ACC GDFS var 0000/0443/0001 Writing ACC GDFS var 0000/0444/0001 Writing ACC GDFS var 0000/0445/0007 Writing ACC GDFS var 0000/0446/0007 Writing ACC GDFS var 0000/0447/0007 Writing ACC GDFS var 0000/0448/0007 Writing ACC GDFS var 0000/0449/0001 Writing ACC GDFS var 0000/044A/0003 Writing ACC GDFS var 0000/044B/0003 Writing ACC GDFS var 0000/044C/0003 Writing ACC GDFS var 0000/044D/0003 Writing ACC GDFS var 0000/0454/0020 Writing ACC GDFS var 0000/0455/0001 Writing ACC GDFS var 0000/0456/0001 Writing ACC GDFS var 0000/0457/0001 Writing ACC GDFS var 0000/0458/0001 Writing ACC GDFS var 0000/0459/0001 Writing ACC GDFS var 0000/045A/0001 Writing ACC GDFS var 0000/045B/0001 Writing ACC GDFS var 0000/045C/0001 Writing ACC GDFS var 0000/045D/0001 Writing ACC GDFS var 0000/045E/0001 Writing ACC GDFS var 0000/045F/0001 Writing ACC GDFS var 0000/0460/0001 Writing ACC GDFS var 0000/04CE/0200 Writing ACC GDFS var 0000/04CF/0200 Writing ACC GDFS var 0000/04D0/03DE Writing ACC GDFS var 0000/04D1/03DE Writing ACC GDFS var 0000/04D2/03DE Writing ACC GDFS var 0000/04D3/03DE Writing ACC GDFS var 0000/04D4/03DE Writing ACC GDFS var 0000/04D5/03DE Writing ACC GDFS var 0000/04D6/03DE Writing ACC GDFS var 0000/04D7/03DE Writing ACC GDFS var 0000/04D8/0006 Writing ACC GDFS var 0000/04D9/0006 Writing ACC GDFS var 0000/04DA/0006 Writing ACC GDFS var 0000/04DB/0006 Writing ACC GDFS var 0000/04DC/0004 Writing ACC GDFS var 0000/04DD/0004 Writing ACC GDFS var 0000/04DE/0004 Writing ACC GDFS var 0000/04DF/0004 Writing ACC GDFS var 0000/04E0/001E Writing ACC GDFS var 0000/04E1/001E Writing ACC GDFS var 0000/04E2/001E Writing ACC GDFS var 0000/04E3/001E Writing ACC GDFS var 0000/04E4/0001 Writing ACC GDFS var 0000/04E5/0001 Writing ACC GDFS var 0000/04E6/0001 Writing ACC GDFS var 0000/04E7/0001 Writing ACC GDFS var 0000/04E8/0001 Writing ACC GDFS var 0000/04E9/0001 Writing ACC GDFS var 0000/04EA/0001 Writing ACC GDFS var 0000/04EB/0001 Writing ACC GDFS var 0000/04EC/0001 Writing ACC GDFS var 0000/04ED/0001 Writing ACC GDFS var 0000/04EE/0001 Writing ACC GDFS var 0000/04F1/0001 Writing ACC GDFS var 0000/04F2/0001 Writing ACC GDFS var 0000/04F3/0001 Writing ACC GDFS var 0000/04F4/0001 Writing ACC GDFS var 0000/04F5/0001 Writing ACC GDFS var 0000/04F6/0001 Writing ACC GDFS var 0000/04F7/0001 Writing ACC GDFS var 0000/04F8/0001 Writing ACC GDFS var 0000/04F9/0001 Writing ACC GDFS var 0000/04FA/0001 Writing ACC GDFS var 0000/04FB/0001 Writing ACC GDFS var 0000/04FC/0001 Writing ACC GDFS var 0000/04FD/0001 Writing ACC GDFS var 0000/04FE/0001 Writing ACC GDFS var 0000/04FF/0001 Writing ACC GDFS var 0000/0501/0001 Writing ACC GDFS var 0000/0502/0001 Writing ACC GDFS var 0000/0503/0001 Writing ACC GDFS var 0000/0504/0005 Writing ACC GDFS var 0000/0505/0005 Writing ACC GDFS var 0000/0506/0005 Writing ACC GDFS var 0000/0507/0005 Writing ACC GDFS var 0000/0509/0001 Writing ACC GDFS var 0000/050A/0001 Writing ACC GDFS var 0000/050B/0001 Writing ACC GDFS var 0000/050C/0001 Writing ACC GDFS var 0000/050D/0001 Writing ACC GDFS var 0000/050E/000F Writing ACC GDFS var 0000/050F/000F Writing ACC GDFS var 0000/0510/000F Writing ACC GDFS var 0000/0511/000F Writing ACC GDFS var 0000/0512/000F Writing ACC GDFS var 0000/0513/000F Writing ACC GDFS var 0000/0514/000F Writing ACC GDFS var 0000/0515/000F Writing ACC GDFS var 0000/0516/000F Writing ACC GDFS var 0000/0517/000F Writing ACC GDFS var 0000/0518/000F Writing ACC GDFS var 0000/0519/000F Writing ACC GDFS var 0000/051A/000F Writing ACC GDFS var 0000/051B/000F Writing ACC GDFS var 0000/051C/000F Writing ACC GDFS var 0000/051D/000F Writing ACC GDFS var 0000/051E/0020 Writing ACC GDFS var 0000/051F/0020 Writing ACC GDFS var 0000/0520/0020 Writing ACC GDFS var 0000/0521/0020 Writing ACC GDFS var 0000/0522/0020 Writing ACC GDFS var 0000/0523/0020 Writing ACC GDFS var 0000/0524/0020 Writing ACC GDFS var 0000/0525/0020 Writing ACC GDFS var 0000/0526/0004 Writing ACC GDFS var 0000/0527/0004 Writing ACC GDFS var 0000/0528/0004 Writing ACC GDFS var 0000/0529/0004 Writing ACC GDFS var 0000/052A/0002 Writing ACC GDFS var 0000/052B/0002 Writing ACC GDFS var 0000/052C/0002 Writing ACC GDFS var 0000/052D/0001 Writing ACC GDFS var 0000/052E/0001 Writing ACC GDFS var 0000/052F/0001 Writing ACC GDFS var 0000/0530/0001 Writing ACC GDFS var 0000/0531/0001 Writing ACC GDFS var 0000/0532/0001 Writing ACC GDFS var 0000/0575/0001 Writing ACC GDFS var 0000/0576/0020 Writing ACC GDFS var 0000/0577/0020 Writing ACC GDFS var 0000/0578/0020 Writing ACC GDFS var 0000/0579/0020 Writing ACC GDFS var 0000/057A/0008 Writing ACC GDFS var 0000/057B/0008 Writing ACC GDFS var 0000/057C/0008 Writing ACC GDFS var 0000/057D/0008 Writing ACC GDFS var 0000/057E/0020 Writing ACC GDFS var 0000/057F/0020 Writing ACC GDFS var 0000/0580/0020 Writing ACC GDFS var 0000/0581/0020 Writing ACC GDFS var 0000/0582/0008 Writing ACC GDFS var 0000/0583/0008 Writing ACC GDFS var 0000/0584/0008 Writing ACC GDFS var 0000/0585/0008 Writing ACC GDFS var 0000/0586/0060 Writing ACC GDFS var 0000/0587/0060 Writing ACC GDFS var 0000/0588/0060 Writing ACC GDFS var 0000/0589/0060 Writing ACC GDFS var 0000/058A/0008 Writing ACC GDFS var 0000/058B/0008 Writing ACC GDFS var 0000/058C/0008 Writing ACC GDFS var 0000/058D/0008 Writing ACC GDFS var 0000/058E/0060 Writing ACC GDFS var 0000/058F/0060 Writing ACC GDFS var 0000/0590/0060 Writing ACC GDFS var 0000/0591/0060 Writing ACC GDFS var 0000/0592/0008 Writing ACC GDFS var 0000/0593/0008 Writing ACC GDFS var 0000/0594/0008 Writing ACC GDFS var 0000/0595/0008 Writing ACC GDFS var 0000/0596/0060 Writing ACC GDFS var 0000/0597/0060 Writing ACC GDFS var 0000/0598/0060 Writing ACC GDFS var 0000/0599/0060 Writing ACC GDFS var 0000/059A/0008 Writing ACC GDFS var 0000/059B/0008 Writing ACC GDFS var 0000/059C/0008 Writing ACC GDFS var 0000/059D/0008 Writing ACC GDFS var 0000/059E/0060 Writing ACC GDFS var 0000/059F/0060 Writing ACC GDFS var 0000/05A0/0060 Writing ACC GDFS var 0000/05A1/0060 Writing ACC GDFS var 0000/05A2/0008 Writing ACC GDFS var 0000/05A3/0008 Writing ACC GDFS var 0000/05A4/0008 Writing ACC GDFS var 0000/05A5/0008 Writing ACC GDFS var 0000/05B4/0001 Writing ACC GDFS var 0000/05CB/0008 Writing ACC GDFS var 0000/05CC/0008 Writing ACC GDFS var 0000/05CD/0008 Writing ACC GDFS var 0000/05CE/0008 Writing ACC GDFS var 0000/05CF/0001 Writing ACC GDFS var 0000/05D0/0001 Writing ACC GDFS var 0000/05D1/0001 Writing ACC GDFS var 0000/05D2/0001 Writing ACC GDFS var 0000/05D3/0001 Writing ACC GDFS var 0000/05D4/0001 Writing ACC GDFS var 0000/05D5/0001 Writing ACC GDFS var 0000/05D6/0008 Writing ACC GDFS var 0000/05DF/0001 Writing ACC GDFS var 0000/05E0/0001 Writing ACC GDFS var 0000/05E1/0001 Writing ACC GDFS var 0000/05E2/0001 Writing ACC GDFS var 0000/05E3/001E Writing ACC GDFS var 0000/05E4/001E Writing ACC GDFS var 0000/05E5/001E Writing ACC GDFS var 0000/05E6/001E Writing ACC GDFS var 0000/05E7/0002 Writing ACC GDFS var 0000/05E8/0002 Writing ACC GDFS var 0000/05E9/0002 Writing ACC GDFS var 0000/05EB/0001 Writing ACC GDFS var 0000/05EC/0002 Writing ACC GDFS var 0000/05ED/0002 Writing ACC GDFS var 0000/05EE/0002 Writing ACC GDFS var 0000/05EF/0002 Writing ACC GDFS var 0000/05F0/0002 Writing ACC GDFS var 0000/05F1/0002 Writing ACC GDFS var 0000/05F2/0002 Writing ACC GDFS var 0000/05F3/0002 Writing ACC GDFS var 0000/05F4/0002 Writing ACC GDFS var 0000/05F8/0001 Writing ACC GDFS var 0000/05F9/0001 Writing ACC GDFS var 0000/05FA/0001 Writing ACC GDFS var 0000/05FB/0001 Writing ACC GDFS var 0000/061E/0008 Writing ACC GDFS var 0000/061F/0008 Writing ACC GDFS var 0000/0620/0008 Writing ACC GDFS var 0000/0621/0008 Writing ACC GDFS var 0000/0622/0001 Writing ACC GDFS var 0000/0623/0001 Writing ACC GDFS var 0000/0624/0001 Writing ACC GDFS var 0000/0625/0001 Writing ACC GDFS var 0000/0626/0001 Writing ACC GDFS var 0000/0627/0001 Writing ACC GDFS var 0000/0628/0001 Writing ACC GDFS var 0000/0629/0001 Writing ACC GDFS var 0000/062A/0001 Writing ACC GDFS var 0000/062B/0005 Writing ACC GDFS var 0000/062C/0005 Writing ACC GDFS var 0000/062D/0005 Writing ACC GDFS var 0000/062E/0005 Writing ACC GDFS var 0000/062F/000F Writing ACC GDFS var 0000/0630/000F Writing ACC GDFS var 0000/0631/000F Writing ACC GDFS var 0000/0632/000F Writing ACC GDFS var 0000/0633/000F Writing ACC GDFS var 0000/0634/000F Writing ACC GDFS var 0000/0635/000F Writing ACC GDFS var 0000/0636/000F Writing ACC GDFS var 0000/0637/0001 Writing ACC GDFS var 0000/0638/0001 Writing ACC GDFS var 0000/0639/0001 Writing ACC GDFS var 0000/063A/0001 Writing ACC GDFS var 0000/063B/0003 Writing ACC GDFS var 0000/063C/0003 Writing ACC GDFS var 0000/063D/0003 Writing ACC GDFS var 0000/063E/0003 Writing ACC GDFS var 0000/063F/0006 Writing ACC GDFS var 0000/0640/0006 Writing ACC GDFS var 0000/0641/0006 Writing ACC GDFS var 0000/0642/0006 Writing ACC GDFS var 0000/0643/0004 Writing ACC GDFS var 0000/0644/0004 Writing ACC GDFS var 0000/0645/0004 Writing ACC GDFS var 0000/0646/0004 Writing ACC GDFS var 0000/0647/0002 Writing ACC GDFS var 0000/0648/0002 Writing ACC GDFS var 0000/0649/0002 Writing ACC GDFS var 0000/064A/0002 Writing ACC GDFS var 0000/064B/0004 Writing ACC GDFS var 0000/064C/0004 Writing ACC GDFS var 0000/064D/0004 Writing ACC GDFS var 0000/064E/0004 Writing ACC GDFS var 0000/064F/0001 Writing ACC GDFS var 0000/0650/0001 Writing ACC GDFS var 0000/0651/0001 Writing ACC GDFS var 0000/0652/0001 Writing ACC GDFS var 0000/0653/0001 Writing ACC GDFS var 0000/0654/0001 Writing ACC GDFS var 0000/0655/0001 Writing ACC GDFS var 0000/0656/0024 Writing ACC GDFS var 0000/0657/0024 Writing ACC GDFS var 0000/0658/0024 Writing ACC GDFS var 0000/0659/0024 Writing ACC GDFS var 0000/065A/0024 Writing ACC GDFS var 0000/065B/0024 Writing ACC GDFS var 0000/065C/0024 Writing ACC GDFS var 0000/065D/0024 Writing ACC GDFS var 0000/065E/0024 Writing ACC GDFS var 0000/065F/0024 Writing ACC GDFS var 0000/0660/0024 Writing ACC GDFS var 0000/0661/0024 Writing ACC GDFS var 0000/0662/0024 Writing ACC GDFS var 0000/0663/0024 Writing ACC GDFS var 0000/0664/0024 Writing ACC GDFS var 0000/0665/0024 Writing ACC GDFS var 0000/0666/000C Writing ACC GDFS var 0000/0667/000C Writing ACC GDFS var 0000/0668/000C Writing ACC GDFS var 0000/0669/000C Writing ACC GDFS var 0000/066A/000C Writing ACC GDFS var 0000/066B/000C Writing ACC GDFS var 0000/066C/000C Writing ACC GDFS var 0000/066D/000C Writing ACC GDFS var 0000/066E/0001 Writing ACC GDFS var 0000/066F/0001 Writing ACC GDFS var 0000/0670/0001 Writing ACC GDFS var 0000/0671/0001 Writing ACC GDFS var 0000/0672/0001 Writing ACC GDFS var 0000/0673/0002 Writing ACC GDFS var 0000/0674/0016 Writing ACC GDFS var 0000/0675/0001 Writing ACC GDFS var 0000/0678/0001 Writing ACC GDFS var 0000/0679/0001 Writing ACC GDFS var 0000/067A/0001 Writing ACC GDFS var 0000/067B/0001 Writing ACC GDFS var 0000/067C/0001 Writing ACC GDFS var 0000/067D/0001 Writing ACC GDFS var 0000/067E/0007 Writing ACC GDFS var 0000/067F/0007 Writing ACC GDFS var 0000/0680/0007 Writing ACC GDFS var 0000/0681/0007 Writing ACC GDFS var 0000/0682/0004 Writing ACC GDFS var 0000/0683/0004 Writing ACC GDFS var 0000/0684/0004 Writing ACC GDFS var 0000/0685/0004 Writing ACC GDFS var 0000/0686/0004 Writing ACC GDFS var 0000/0687/0004 Writing ACC GDFS var 0000/0688/0004 Writing ACC GDFS var 0000/0689/0004 Writing ACC GDFS var 0000/068A/0004 Writing ACC GDFS var 0000/068B/0004 Writing ACC GDFS var 0000/068C/0004 Writing ACC GDFS var 0000/068D/0004 Writing ACC GDFS var 0000/068E/0004 Writing ACC GDFS var 0000/068F/0004 Writing ACC GDFS var 0000/0690/0004 Writing ACC GDFS var 0000/0691/0004 Writing ACC GDFS var 0000/0692/0004 Writing ACC GDFS var 0000/0693/0004 Writing ACC GDFS var 0000/0694/0004 Writing ACC GDFS var 0000/0695/0004 Writing ACC GDFS var 0000/0696/0004 Writing ACC GDFS var 0000/0697/0004 Writing ACC GDFS var 0000/0698/0004 Writing ACC GDFS var 0000/0699/0004 Writing ACC GDFS var 0000/0702/0001 Writing ACC GDFS var 0000/0703/0001 Writing ACC GDFS var 0000/0704/0001 Writing ACC GDFS var 0000/0705/0001 Writing ACC GDFS var 0000/0708/0001 Writing ACC GDFS var 0000/0709/0001 Writing ACC GDFS var 0000/070B/0002 Writing ACC GDFS var 0000/070C/0001 Writing ACC GDFS var 0000/070D/0001 Writing ACC GDFS var 0000/070E/0030 Writing ACC GDFS var 0000/070F/0001 Writing ACC GDFS var 0000/0710/0001 Writing ACC GDFS var 0000/0711/0001 Writing ACC GDFS var 0000/0712/0001 Writing ACC GDFS var 0000/0713/0001 Writing ACC GDFS var 0000/0736/0001 Writing ACC GDFS var 0000/0737/0001 Writing ACC GDFS var 0000/0738/0001 Writing ACC GDFS var 0000/0739/0001 Writing ACC GDFS var 0000/073A/0001 Writing ACC GDFS var 0000/073E/0001 Writing ACC GDFS var 0000/073F/0001 Writing ACC GDFS var 0000/0746/0001 Writing ACC GDFS var 0000/0747/0001 Writing ACC GDFS var 0000/0748/0001 Writing ACC GDFS var 0000/0749/0001 Writing ACC GDFS var 0000/074E/0001 Writing ACC GDFS var 0000/074F/0001 Writing ACC GDFS var 0000/0750/0001 Writing ACC GDFS var 0000/0751/0001 Writing ACC GDFS var 0000/0762/04C0 Writing ACC GDFS var 0000/0763/04C0 Writing ACC GDFS var 0000/0764/04C0 Writing ACC GDFS var 0000/0765/04C0 Writing ACC GDFS var 0000/0766/04C0 Writing ACC GDFS var 0000/0767/04C0 Writing ACC GDFS var 0000/0768/04C0 Writing ACC GDFS var 0000/0769/04C0 Writing ACC GDFS var 0000/076A/04C0 Writing ACC GDFS var 0000/076B/04C0 Writing ACC GDFS var 0000/076C/04C0 Writing ACC GDFS var 0000/076D/04C0 Writing ACC GDFS var 0000/076E/04C0 Writing ACC GDFS var 0000/076F/04C0 Writing ACC GDFS var 0000/0770/04C0 Writing ACC GDFS var 0000/0771/04C0 Writing ACC GDFS var 0000/0772/04C0 Writing ACC GDFS var 0000/0773/04C0 Writing ACC GDFS var 0000/0774/04C0 Writing ACC GDFS var 0000/0775/04C0 Writing ACC GDFS var 0000/0776/04C0 Writing ACC GDFS var 0000/0777/04C0 Writing ACC GDFS var 0000/0778/04C0 Writing ACC GDFS var 0000/0779/04C0 Writing ACC GDFS var 0000/0784/0002 Writing ACC GDFS var 0000/0785/0002 Writing ACC GDFS var 0000/0786/0002 Writing ACC GDFS var 0000/0787/0002 Writing ACC GDFS var 0000/0788/000D Writing ACC GDFS var 0000/0789/000D Writing ACC GDFS var 0000/078A/000D Writing ACC GDFS var 0000/078B/000D Writing ACC GDFS var 0000/078C/000D Writing ACC GDFS var 0000/078D/000D Writing ACC GDFS var 0000/078E/000D Writing ACC GDFS var 0000/078F/000D Writing ACC GDFS var 0000/0790/001A Writing ACC GDFS var 0000/0791/001A Writing ACC GDFS var 0000/0792/001A Writing ACC GDFS var 0000/0793/001A Writing ACC GDFS var 0000/0794/001A Writing ACC GDFS var 0000/0795/001A Writing ACC GDFS var 0000/0796/001A Writing ACC GDFS var 0000/0797/001A Writing ACC GDFS var 0000/0817/0002 Writing ACC GDFS var 0000/0818/0002 Writing ACC GDFS var 0000/0819/0002 Writing ACC GDFS var 0000/0832/0005 Writing ACC GDFS var 0000/0833/0006 Writing ACC GDFS var 0000/0834/0001 Writing ACC GDFS var 0000/0930/0001 Writing ACC GDFS var 0000/0931/0001 Writing ACC GDFS var 0000/0932/0001 Writing ACC GDFS var 0000/0933/0001 Writing ACC GDFS var 0000/0934/0400 Writing ACC GDFS var 0000/0935/0258 Writing ACC GDFS var 0000/0936/0001 Writing ACC GDFS var 0000/0937/0001 Writing ACC GDFS var 0000/0938/0001 Writing GDFS var 0000/0002/0004 Writing GDFS var 0000/0003/0004 Writing GDFS var 0000/0004/0001 Writing GDFS var 0000/0005/0044 Writing GDFS var 0000/0006/0044 Writing GDFS var 0000/0007/0001 Writing GDFS var 0000/0008/0012 Writing GDFS var 0000/0009/0028 Writing GDFS var 0000/000A/0028 Writing GDFS var 0000/000D/0001 Writing GDFS var 0000/000E/000C Writing GDFS var 0000/000F/0002 Writing GDFS var 0000/0010/0001 Writing GDFS var 0000/001B/0026 Writing GDFS var 0000/001F/000E Writing GDFS var 0000/0020/0018 Writing GDFS var 0000/0021/0001 Writing GDFS var 0000/0022/0001 Writing GDFS var 0000/0023/0018 Writing GDFS var 0000/0024/0044 Writing GDFS var 0000/0025/0044 Writing GDFS var 0000/0026/0022 Writing GDFS var 0000/0027/0002 Writing GDFS var 0000/0028/0002 Writing GDFS var 0000/0029/0002 Writing GDFS var 0000/002A/0002 Writing GDFS var 0000/002B/0002 Writing GDFS var 0000/002C/0002 Writing GDFS var 0000/002D/0002 Writing GDFS var 0000/002E/0008 Writing GDFS var 0000/002F/0008 Writing GDFS var 0000/0030/0008 Writing GDFS var 0000/0031/0008 Writing GDFS var 0000/0032/0008 Writing GDFS var 0000/0033/0008 Writing GDFS var 0000/0034/0008 Writing GDFS var 0000/0035/0008 Writing GDFS var 0000/0036/0008 Writing GDFS var 0000/0037/0008 Writing GDFS var 0000/0038/0008 Writing GDFS var 0000/0039/0008 Writing GDFS var 0000/003A/0008 Writing GDFS var 0000/003B/0008 Writing GDFS var 0000/003C/0008 Writing GDFS var 0000/003D/0008 Writing GDFS var 0000/005A/0001 Writing GDFS var 0000/005B/0001 Writing GDFS var 0000/005C/000A Writing GDFS var 0000/005D/0002 Writing GDFS var 0000/005E/0006 Writing GDFS var 0000/005F/0002 Writing GDFS var 0000/0060/0002 Writing GDFS var 0000/0061/0002 Writing GDFS var 0000/0062/0002 Writing GDFS var 0000/0063/0001 Writing GDFS var 0000/0064/0001 Writing GDFS var 0000/0065/0014 Writing GDFS var 0000/00B5/0001 Writing GDFS var 0000/00BE/0001 Writing GDFS var 0000/011A/0004 Writing GDFS var 0000/0127/0001 Writing GDFS var 0000/0128/0001 Writing GDFS var 0000/017C/0002 Writing GDFS var 0000/017D/0002 Writing GDFS var 0000/017E/0002 Writing GDFS var 0000/017F/0002 Writing GDFS var 0000/0180/0002 Writing GDFS var 0000/0181/0002 Writing GDFS var 0000/0182/0002 Writing GDFS var 0000/0183/0002 Writing GDFS var 0000/0184/0002 Writing GDFS var 0000/0185/0002 Writing GDFS var 0000/0186/0002 Writing GDFS var 0000/0187/0002 Writing GDFS var 0000/0188/0002 Writing GDFS var 0000/0189/0002 Writing GDFS var 0000/018A/0002 Writing GDFS var 0000/018B/0002 Writing GDFS var 0000/018C/0002 Writing GDFS var 0000/018D/0002 Writing GDFS var 0000/018E/0002 Writing GDFS var 0000/018F/0002 Writing GDFS var 0000/0190/0002 Writing GDFS var 0000/0191/0002 Writing GDFS var 0000/0192/0002 Writing GDFS var 0000/0193/0002 Writing GDFS var 0000/0194/0002 Writing GDFS var 0000/0195/0002 Writing GDFS var 0000/0196/0002 Writing GDFS var 0000/0197/0002 Writing GDFS var 0000/0198/0004 Writing GDFS var 0000/0199/0004 Writing GDFS var 0000/019A/0004 Writing GDFS var 0000/019B/0040 Writing GDFS var 0000/019C/0002 Writing GDFS var 0000/019D/0002 Writing GDFS var 0000/019E/0002 Writing GDFS var 0000/019F/0002 Writing GDFS var 0000/01A0/0002 Writing GDFS var 0000/01A1/0002 Writing GDFS var 0000/01A2/0002 Writing GDFS var 0000/01A3/0002 Writing GDFS var 0000/01A4/0002 Writing GDFS var 0000/01A5/0002 Writing GDFS var 0000/01A6/0002 Writing GDFS var 0000/01A7/0002 Writing GDFS var 0000/01A8/0002 Writing GDFS var 0000/01A9/0002 Writing GDFS var 0000/01AA/0002 Writing GDFS var 0000/01AB/0002 Writing GDFS var 0000/01AC/0002 Writing GDFS var 0000/01AD/0002 Writing GDFS var 0000/01AE/0002 Writing GDFS var 0000/01AF/0002 Writing GDFS var 0000/01B0/0002 Writing GDFS var 0000/01B1/0002 Writing GDFS var 0000/01B2/0002 Writing GDFS var 0000/01B3/0002 Writing GDFS var 0000/01B4/0002 Writing GDFS var 0000/01B5/0002 Writing GDFS var 0000/01B6/0002 Writing GDFS var 0000/01B7/0002 Writing GDFS var 0000/01B8/0001 Writing GDFS var 0000/01B9/0002 Writing GDFS var 0000/01BA/0008 Writing GDFS var 0000/01BB/0002 Writing GDFS var 0000/01BC/0002 Writing GDFS var 0000/01BD/0002 Writing GDFS var 0000/01BE/0002 Writing GDFS var 0000/01BF/0002 Writing GDFS var 0000/01C0/0002 Writing GDFS var 0000/01C1/0002 Writing GDFS var 0000/01C2/0002 Writing GDFS var 0000/01C3/0002 Writing GDFS var 0000/01C4/0002 Writing GDFS var 0000/01C5/0002 Writing GDFS var 0000/01C6/0002 Writing GDFS var 0000/01C7/0002 Writing GDFS var 0000/01C8/0002 Writing GDFS var 0000/01C9/0002 Writing GDFS var 0000/01CA/0002 Writing GDFS var 0000/01CB/0002 Writing GDFS var 0000/01CC/0002 Writing GDFS var 0000/01CD/0002 Writing GDFS var 0000/01CE/0002 Writing GDFS var 0000/01CF/0002 Writing GDFS var 0000/01D0/0002 Writing GDFS var 0000/01D1/0002 Writing GDFS var 0000/01D2/0002 Writing GDFS var 0000/01D3/0002 Writing GDFS var 0000/01D4/0002 Writing GDFS var 0000/01D5/0002 Writing GDFS var 0000/01D6/0002 Writing GDFS var 0000/01D7/0002 Writing GDFS var 0000/01D8/0002 Writing GDFS var 0000/01D9/0002 Writing GDFS var 0000/01DA/0002 Writing GDFS var 0000/01DB/0002 Writing GDFS var 0000/01DC/0002 Writing GDFS var 0000/01DD/0002 Writing GDFS var 0000/01DE/0002 Writing GDFS var 0000/01DF/0002 Writing GDFS var 0000/01E0/0002 Writing GDFS var 0000/01E1/0002 Writing GDFS var 0000/01E2/0002 Writing GDFS var 0000/01E3/0002 Writing GDFS var 0000/01E4/0002 Writing GDFS var 0000/01E5/0002 Writing GDFS var 0000/01E6/0002 Writing GDFS var 0000/01E7/0002 Writing GDFS var 0000/01E8/0002 Writing GDFS var 0000/01E9/0002 Writing GDFS var 0000/01EA/0002 Writing GDFS var 0000/01EB/0002 Writing GDFS var 0000/01EC/0002 Writing GDFS var 0000/01ED/0002 Writing GDFS var 0000/01EE/0002 Writing GDFS var 0000/01EF/0002 Writing GDFS var 0000/01F0/0002 Writing GDFS var 0000/01F1/0002 Writing GDFS var 0000/01F2/0002 Writing GDFS var 0000/01F3/0002 Writing GDFS var 0000/01F4/0002 Writing GDFS var 0000/01F5/0002 Writing GDFS var 0000/01F6/0002 Writing GDFS var 0000/0208/0001 Writing GDFS var 0000/031E/0005 Writing GDFS var 0000/031F/0006 Writing GDFS var 0000/0320/0001 Writing GDFS var 0000/0323/0010 Writing GDFS var 0000/0324/0018 Writing GDFS var 0000/0325/0001 Writing GDFS var 0000/03E8/01D8 Writing GDFS var 0000/03E9/0010 Writing GDFS var 0000/03EA/001E Writing GDFS var 0000/03EB/0010 Writing GDFS var 0000/03EC/0004 Writing GDFS var 0000/03ED/0001 Writing GDFS var 0000/03EE/0001 Writing GDFS var 0000/03EF/0050 Writing GDFS var 0000/03F0/0078 Writing GDFS var 0000/03F1/0001 Writing GDFS var 0000/03F2/0004 Elapsed: 745 secs. CFG:000000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703073639] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703073639 CERT:BROWN LDR:100311 1255 MATCXC1723918_E9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_R2B LDR CAPS:SYSTEM FLASH SIGNATURE LDR:100311 1257 MATCXC1723919_1E9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_R2B LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\setool\M5650\M5650XIJA1_MAIN.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 565 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted writing "D:\setool\M5650\M5650XIJA1_FFS.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 26 Will flash 1034 blocks ... ssw file accepted SIGNING ... Processing script "D:\setool\M5650\m5650xija1.gdfs" ... Writing ACC GDFS var 0000/0002/0004 Writing ACC GDFS var 0000/0003/0004 Writing ACC GDFS var 0000/0004/0001 Writing ACC GDFS var 0000/0006/0006 Writing ACC GDFS var 0000/0007/0001 Writing ACC GDFS var 0000/0008/0001 Writing ACC GDFS var 0000/0009/0028 Writing ACC GDFS var 0000/000A/0028 Writing ACC GDFS var 0000/000E/000C Writing ACC GDFS var 0000/000F/0002 Writing ACC GDFS var 0000/0027/0008 Writing ACC GDFS var 0000/0028/0008 Writing ACC GDFS var 0000/0029/0008 Writing ACC GDFS var 0000/002A/0008 Writing ACC GDFS var 0000/002B/0008 Writing ACC GDFS var 0000/002C/0008 Writing ACC GDFS var 0000/002D/0008 Writing ACC GDFS var 0000/002E/0008 Writing ACC GDFS var 0000/002F/0008 Writing ACC GDFS var 0000/0030/0008 Writing ACC GDFS var 0000/0031/0008 Writing ACC GDFS var 0000/0032/0008 Writing ACC GDFS var 0000/0033/0008 Writing ACC GDFS var 0000/0034/0008 Writing ACC GDFS var 0000/0035/0008 Writing ACC GDFS var 0000/0036/0008 Writing ACC GDFS var 0000/0050/0001 Writing ACC GDFS var 0000/0051/0001 Writing ACC GDFS var 0000/0052/000A Writing ACC GDFS var 0000/0053/0002 Writing ACC GDFS var 0000/0054/0006 Writing ACC GDFS var 0000/0055/0002 Writing ACC GDFS var 0000/0056/0002 Writing ACC GDFS var 0000/0057/0002 Writing ACC GDFS var 0000/0058/0002 Writing ACC GDFS var 0000/0059/0001 Writing ACC GDFS var 0000/005A/0001 Writing ACC GDFS var 0000/005B/0001 Writing ACC GDFS var 0000/005C/0001 Writing ACC GDFS var 0000/005D/0001 Writing ACC GDFS var 0000/005E/0001 Writing ACC GDFS var 0000/005F/0001 Writing ACC GDFS var 0000/0060/0001 Writing ACC GDFS var 0000/0062/0001 Writing ACC GDFS var 0000/0063/0001 Writing ACC GDFS var 0000/0065/0001 Writing ACC GDFS var 0000/0066/0014 Writing ACC GDFS var 0000/00A2/0001 Writing ACC GDFS var 0000/00A4/0002 Writing ACC GDFS var 0000/00A5/0006 Writing ACC GDFS var 0000/00A6/0001 Writing ACC GDFS var 0000/00A7/0064 Writing ACC GDFS var 0000/00A8/00F8 Writing ACC GDFS var 0000/00A9/0001 Writing ACC GDFS var 0000/00AA/0400 Writing ACC GDFS var 0000/00AB/0280 Writing ACC GDFS var 0000/00AC/0080 Writing ACC GDFS var 0000/00AD/0040 Writing ACC GDFS var 0000/00AE/0006 Writing ACC GDFS var 0000/00AF/0001 Writing ACC GDFS var 0000/00B0/0004 Writing ACC GDFS var 0000/00B1/0002 Writing ACC GDFS var 0000/00B2/0100 Writing ACC GDFS var 0000/00B3/0200 Writing ACC GDFS var 0000/00B4/0001 Writing ACC GDFS var 0000/00B5/0001 Writing ACC GDFS var 0000/00B6/0001 Writing ACC GDFS var 0000/00B7/0002 Writing ACC GDFS var 0000/00B8/0006 Writing ACC GDFS var 0000/00B9/0006 Writing ACC GDFS var 0000/00BA/0006 Writing ACC GDFS var 0000/00EE/0001 Writing ACC GDFS var 0000/0118/0014 Writing ACC GDFS var 0000/0119/0002 Writing ACC GDFS var 0000/011A/0002 Writing ACC GDFS var 0000/011B/0002 Writing ACC GDFS var 0000/011C/0002 Writing ACC GDFS var 0000/0122/0001 Writing ACC GDFS var 0000/0123/0031 Writing ACC GDFS var 0000/0124/0001 Writing ACC GDFS var 0000/0125/0001 Writing ACC GDFS var 0000/0126/0003 Writing ACC GDFS var 0000/0127/0009 Writing ACC GDFS var 0000/0128/0001 Writing ACC GDFS var 0000/0129/0001 Writing ACC GDFS var 0000/012A/0001 Writing ACC GDFS var 0000/012B/0001 Writing ACC GDFS var 0000/012C/0001 Writing ACC GDFS var 0000/012D/0003 Writing ACC GDFS var 0000/012E/0003 Writing ACC GDFS var 0000/012F/0004 Writing ACC GDFS var 0000/0130/0004 Writing ACC GDFS var 0000/0131/0004 Writing ACC GDFS var 0000/0132/0004 Writing ACC GDFS var 0000/0133/0008 Writing ACC GDFS var 0000/0134/0005 Writing ACC GDFS var 0000/0135/0001 Writing ACC GDFS var 0000/0136/0001 Writing ACC GDFS var 0000/0137/0001 Writing ACC GDFS var 0000/0138/0061 Writing ACC GDFS var 0000/0139/0001 Writing ACC GDFS var 0000/013A/0001 Writing ACC GDFS var 0000/013B/0001 Writing ACC GDFS var 0000/013C/0001 Writing ACC GDFS var 0000/013D/0001 Writing ACC GDFS var 0000/013E/0001 Writing ACC GDFS var 0000/013F/0001 Writing ACC GDFS var 0000/0140/0001 Writing ACC GDFS var 0000/0141/0001 Writing ACC GDFS var 0000/0142/0001 Writing ACC GDFS var 0000/0143/0001 Writing ACC GDFS var 0000/0144/0001 Writing ACC GDFS var 0000/0145/0001 Writing ACC GDFS var 0000/0146/0001 Writing ACC GDFS var 0000/0147/0001 Writing ACC GDFS var 0000/0148/0001 Writing ACC GDFS var 0000/0149/0001 Writing ACC GDFS var 0000/014A/003D Writing ACC GDFS var 0000/014B/0001 Writing ACC GDFS var 0000/014C/0001 Writing ACC GDFS var 0000/014D/0001 Writing ACC GDFS var 0000/014E/0001 Writing ACC GDFS var 0000/014F/0001 Writing ACC GDFS var 0000/0150/0001 Writing ACC GDFS var 0000/0151/0001 Writing ACC GDFS var 0000/0152/0007 Writing ACC GDFS var 0000/0153/0001 Writing ACC GDFS var 0000/0154/003D Writing ACC GDFS var 0000/0155/0001 Writing ACC GDFS var 0000/0156/0001 Writing ACC GDFS var 0000/0157/0001 Writing ACC GDFS var 0000/0158/0001 Writing ACC GDFS var 0000/0159/0001 Writing ACC GDFS var 0000/015A/0001 Writing ACC GDFS var 0000/015B/0001 Writing ACC GDFS var 0000/015C/0001 Writing ACC GDFS var 0000/015D/0001 Writing ACC GDFS var 0000/015E/0001 Writing ACC GDFS var 0000/015F/0001 Writing ACC GDFS var 0000/0160/0001 Writing ACC GDFS var 0000/0161/0001 Writing ACC GDFS var 0000/0162/0001 Writing ACC GDFS var 0000/0163/0001 Writing ACC GDFS var 0000/0164/0001 Writing ACC GDFS var 0000/0165/0001 Writing ACC GDFS var 0000/0166/0001 Writing ACC GDFS var 0000/0167/0001 Writing ACC GDFS var 0000/016A/000A Writing ACC GDFS var 0000/016B/0001 Writing ACC GDFS var 0000/016C/000F Writing ACC GDFS var 0000/0186/000A Writing ACC GDFS var 0000/0187/0002 Writing ACC GDFS var 0000/0188/001E Writing ACC GDFS var 0000/0189/0002 Writing ACC GDFS var 0000/018A/0002 Writing ACC GDFS var 0000/018B/0002 Writing ACC GDFS var 0000/018C/0002 Writing ACC GDFS var 0000/018D/0002 Writing ACC GDFS var 0000/018E/0002 Writing ACC GDFS var 0000/018F/0001 Writing ACC GDFS var 0000/0190/0001 Writing ACC GDFS var 0000/0191/0001 Writing ACC GDFS var 0000/0192/0001 Writing ACC GDFS var 0000/0193/0001 Writing ACC GDFS var 0000/0194/0004 Writing ACC GDFS var 0000/0195/0004 Writing ACC GDFS var 0000/0196/0004 Writing ACC GDFS var 0000/0197/0004 Writing ACC GDFS var 0000/0198/0004 Writing ACC GDFS var 0000/0199/0001 Writing ACC GDFS var 0000/019A/0001 Writing ACC GDFS var 0000/019B/0004 Writing ACC GDFS var 0000/019C/000A Writing ACC GDFS var 0000/019D/0001 Writing ACC GDFS var 0000/019F/0001 Writing ACC GDFS var 0000/01A1/0004 Writing ACC GDFS var 0000/01A2/0001 Writing ACC GDFS var 0000/01A3/0001 Writing ACC GDFS var 0000/01A4/0001 Writing ACC GDFS var 0000/01A5/0001 Writing ACC GDFS var 0000/01A6/0001 Writing ACC GDFS var 0000/01A7/0001 Writing ACC GDFS var 0000/01A8/0002 Writing ACC GDFS var 0000/01A9/0001 Writing ACC GDFS var 0000/01AA/0001 Writing ACC GDFS var 0000/01AB/0001 Writing ACC GDFS var 0000/01C2/0001 Writing ACC GDFS var 0000/01C3/0002 Writing ACC GDFS var 0000/01C4/0002 Writing ACC GDFS var 0000/01C5/0002 Writing ACC GDFS var 0000/01C6/0002 Writing ACC GDFS var 0000/01C7/0002 Writing ACC GDFS var 0000/01C8/0002 Writing ACC GDFS var 0000/01C9/0002 Writing ACC GDFS var 0000/01CA/0002 Writing ACC GDFS var 0000/01CB/0002 Writing ACC GDFS var 0000/01CC/0002 Writing ACC GDFS var 0000/01CD/0002 Writing ACC GDFS var 0000/01CE/0002 Writing ACC GDFS var 0000/01CF/0002 Writing ACC GDFS var 0000/01D0/0002 Writing ACC GDFS var 0000/01D1/0002 Writing ACC GDFS var 0000/01D2/0002 Writing ACC GDFS var 0000/01D3/0002 Writing ACC GDFS var 0000/01D4/0002 Writing ACC GDFS var 0000/01D5/0002 Writing ACC GDFS var 0000/01D6/0002 Writing ACC GDFS var 0000/01D7/0002 Writing ACC GDFS var 0000/01D8/0002 Writing ACC GDFS var 0000/01D9/0002 Writing ACC GDFS var 0000/01DA/0002 Writing ACC GDFS var 0000/01DB/0002 Writing ACC GDFS var 0000/01DC/0002 Writing ACC GDFS var 0000/01DD/0002 Writing ACC GDFS var 0000/01DE/0002 Writing ACC GDFS var 0000/01DF/0002 Writing ACC GDFS var 0000/01E0/0002 Writing ACC GDFS var 0000/01E1/0002 Writing ACC GDFS var 0000/01E2/0002 Writing ACC GDFS var 0000/01E3/0002 Writing ACC GDFS var 0000/01E4/0002 Writing ACC GDFS var 0000/01E5/0002 Writing ACC GDFS var 0000/01E6/0002 Writing ACC GDFS var 0000/01E7/0002 Writing ACC GDFS var 0000/01E8/0002 Writing ACC GDFS var 0000/01E9/0002 Writing ACC GDFS var 0000/01EA/0002 Writing ACC GDFS var 0000/01EB/0002 Writing ACC GDFS var 0000/01EC/0002 Writing ACC GDFS var 0000/01ED/0002 Writing ACC GDFS var 0000/01EE/0002 Writing ACC GDFS var 0000/01EF/0002 Writing ACC GDFS var 0000/01F0/0002 Writing ACC GDFS var 0000/01F1/0002 Writing ACC GDFS var 0000/01F2/0002 Writing ACC GDFS var 0000/01F3/0002 Writing ACC GDFS var 0000/01F4/0002 Writing ACC GDFS var 0000/01F5/0002 Writing ACC GDFS var 0000/01F6/0002 Writing ACC GDFS var 0000/01F7/0002 Writing ACC GDFS var 0000/01F8/0002 Writing ACC GDFS var 0000/01F9/0002 Writing ACC GDFS var 0000/01FA/0002 Writing ACC GDFS var 0000/01FB/0002 Writing ACC GDFS var 0000/01FC/0002 Writing ACC GDFS var 0000/01FD/0002 Writing ACC GDFS var 0000/01FE/0002 Writing ACC GDFS var 0000/01FF/0002 Writing ACC GDFS var 0000/0200/0002 Writing ACC GDFS var 0000/0201/0002 Writing ACC GDFS var 0000/0202/0002 Writing ACC GDFS var 0000/0203/0002 Writing ACC GDFS var 0000/0204/0002 Writing ACC GDFS var 0000/0205/0002 Writing ACC GDFS var 0000/0206/0002 Writing ACC GDFS var 0000/0207/0002 Writing ACC GDFS var 0000/0208/0002 Writing ACC GDFS var 0000/0209/0002 Writing ACC GDFS var 0000/020A/0002 Writing ACC GDFS var 0000/020B/0002 Writing ACC GDFS var 0000/020C/0002 Writing ACC GDFS var 0000/020D/0002 Writing ACC GDFS var 0000/020E/0002 Writing ACC GDFS var 0000/020F/0002 Writing ACC GDFS var 0000/0210/0002 Writing ACC GDFS var 0000/0211/0002 Writing ACC GDFS var 0000/0212/0002 Writing ACC GDFS var 0000/0213/0002 Writing ACC GDFS var 0000/0214/0002 Writing ACC GDFS var 0000/0215/0002 Writing ACC GDFS var 0000/0216/0002 Writing ACC GDFS var 0000/0217/0002 Writing ACC GDFS var 0000/0218/0002 Writing ACC GDFS var 0000/0219/0002 Writing ACC GDFS var 0000/021A/0002 Writing ACC GDFS var 0000/021B/0002 Writing ACC GDFS var 0000/021C/0002 Writing ACC GDFS var 0000/021D/0002 Writing ACC GDFS var 0000/021E/0002 Writing ACC GDFS var 0000/021F/0002 Writing ACC GDFS var 0000/0220/0002 Writing ACC GDFS var 0000/0221/0002 Writing ACC GDFS var 0000/0222/0002 Writing ACC GDFS var 0000/0223/0002 Writing ACC GDFS var 0000/0224/0002 Writing ACC GDFS var 0000/0225/0002 Writing ACC GDFS var 0000/0226/0002 Writing ACC GDFS var 0000/0227/0002 Writing ACC GDFS var 0000/0228/0002 Writing ACC GDFS var 0000/0229/0002 Writing ACC GDFS var 0000/022A/0002 Writing ACC GDFS var 0000/022B/0002 Writing ACC GDFS var 0000/022C/0002 Writing ACC GDFS var 0000/022D/0002 Writing ACC GDFS var 0000/022E/0002 Writing ACC GDFS var 0000/022F/0002 Writing ACC GDFS var 0000/0230/0002 Writing ACC GDFS var 0000/0231/0002 Writing ACC GDFS var 0000/0232/0002 Writing ACC GDFS var 0000/0233/0002 Writing ACC GDFS var 0000/0234/0002 Writing ACC GDFS var 0000/0235/0002 Writing ACC GDFS var 0000/0236/0002 Writing ACC GDFS var 0000/0237/0002 Writing ACC GDFS var 0000/0238/0002 Writing ACC GDFS var 0000/0239/0002 Writing ACC GDFS var 0000/023A/0002 Writing ACC GDFS var 0000/023B/0002 Writing ACC GDFS var 0000/023C/0002 Writing ACC GDFS var 0000/023D/0002 Writing ACC GDFS var 0000/023E/0002 Writing ACC GDFS var 0000/023F/0002 Writing ACC GDFS var 0000/0240/0002 Writing ACC GDFS var 0000/0241/0002 Writing ACC GDFS var 0000/0242/0002 Writing ACC GDFS var 0000/0243/0002 Writing ACC GDFS var 0000/0244/0002 Writing ACC GDFS var 0000/0245/0002 Writing ACC GDFS var 0000/0246/0002 Writing ACC GDFS var 0000/0247/0002 Writing ACC GDFS var 0000/0248/0002 Writing ACC GDFS var 0000/0249/0002 Writing ACC GDFS var 0000/024A/0002 Writing ACC GDFS var 0000/024B/0004 Writing ACC GDFS var 0000/024C/0004 Writing ACC GDFS var 0000/024D/0004 Writing ACC GDFS var 0000/024E/0004 Writing ACC GDFS var 0000/024F/0004 Writing ACC GDFS var 0000/0250/0004 Writing ACC GDFS var 0000/0251/0004 Writing ACC GDFS var 0000/0252/0004 Writing ACC GDFS var 0000/0253/0002 Writing ACC GDFS var 0000/0256/0004 Writing ACC GDFS var 0000/0257/0004 Writing ACC GDFS var 0000/0258/0004 Writing ACC GDFS var 0000/0259/0004 Writing ACC GDFS var 0000/025A/0004 Writing ACC GDFS var 0000/025B/0004 Writing ACC GDFS var 0000/025C/0004 Writing ACC GDFS var 0000/025D/0004 Writing ACC GDFS var 0000/025E/0002 Writing ACC GDFS var 0000/025F/0001 Writing ACC GDFS var 0000/0261/000B Writing ACC GDFS var 0000/0262/0016 Writing ACC GDFS var 0000/0263/0002 Writing ACC GDFS var 0000/0264/0002 Writing ACC GDFS var 0000/0265/0002 Writing ACC GDFS var 0000/0266/0002 Writing ACC GDFS var 0000/028A/0002 Writing ACC GDFS var 0000/028B/0001 Writing ACC GDFS var 0000/028F/0044 Writing ACC GDFS var 0000/0290/0004 Writing ACC GDFS var 0000/0291/0001 Writing ACC GDFS var 0000/0292/0001 Writing ACC GDFS var 0000/0293/000F Writing ACC GDFS var 0000/0294/0002 |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
