Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2004 Age: 31
Member: 71363 Status: Offline Thanks: 15
| MK16 pro 10 credits i try to unlock MK16 i checked 1+2+5 dont ask me test point and phone unlocked with 10 credits ![]() RUNNING v 1.1289/01.15/UNI CARD SERIAL 00084051 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 short credits consumption list : S1 v1 06 credits S1 v2 10 credits S1 OPEN 03 credits S1 OPEN AID 004 09 credits A1 phones 03 credits A2 phones, CSCA way 03 credits CID81 A2 phones, FLASHMODE activation way 06 credits S1 v2 alternative bypass unlock/repair 01 credits S1 v2 alternative bypass standalone activation 20 credits W100,W150 codes 01 credits S1 servers online from 08:00am till 08:00pm (GMT+8) You CAN NOT unlock next phones without S1 servers: u1/u5/u8 aid 004, F305,J132,K330,R300,R306,S302,S312,T250,T280,T303, W205,W302, W395,Z250,Z320 phones with damaged security zone, F305,J132,K330,R300,R306,S302,S312,T250,T280,T303, W205,W302, W395,Z250,Z320 aid 004, w100,w150 full unlock, ck13,ck15,lt26,wt13, lt26, lt22,st25,mt27. current updater version: 0.95 current setool2 version: 1.1289 bad username/password. CARD COUNTERS: FLASH 54, UNLOCK 160 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:101010000000 bad username/password. CARD COUNTERS: FLASH 54, UNLOCK 160 Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:101010000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 54, UNLOCK 160 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:101010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Unlock FAILED Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:101010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:101010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R9B031" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 18927736F8DA4D23F8CEFE4A9A038486F21DF09D FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI : 01279000067589 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1216] Unlock DONE Elapsed: 23 secs. SIGNED MODE (USING SERVER) CFG:101010000000 SERVER CREDITS LEFT/USED: 0/30 CARD COUNTERS: FLASH 54, UNLOCK 161 Elapsed: 2 secs. |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010 Age: 3
Member: 1315677 Status: Offline Thanks: 308
| i try to unlock MK16 i checked 1+2+5 but you had selected 1+3+5 CFG:101010000000 it could be 10 logs wasted but you are lucky your phone maybe have new security >=12w14 (EROM: 1241-3656 R9B031) Nothing is lost Last edited by :Aishur:; 06-27-2012 at 20:59. |
| The Following User Says Thank You to :Aishur: For This Useful Post: |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 48
Member: 296918 Status: Offline Thanks: 186
| MK16a unlocked MK16a PRO unlocked sucsesfully check: 1 signed mode 2 enable alternative security bypass 5 perform full unlock instead of user code reset testpoint to ground "DON`T USE BATTERY" Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: 16F0CF0675AC87FDBCFF51294946AEC88477E517 FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 01279000xxxxxx Checking for signature ... WRITING SEMCBOOT ... Unlock DONE Elapsed: 61 secs. Code: SE_MK16_TP.jpg B.R. |
| | #4 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: Kisangani, CONGO D R
Member: 211318 Status: Offline Thanks: 101
| what can i do about this phone RUNNING S1_EROM VER "R9B031" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 603F2C2BFFCD9C13C7AF4853AE7F1A7B3DA7CADE FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI : 0127900011xxxxx SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 704, UNLOCK 140 Elapsed: 4 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 67 secs. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks: 4
| Read this post: HOW TO WORK WITH SEMC PDA PHONES - Page 2 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 04-06-2012 16:22 |
| new 5.28 unlocker by PRO!!! | Satanael | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 07-20-2000 17:18 |
| 6150 v5.10 | maxim | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 12-06-1999 08:58 |
| 6150 v5.10 solution | Senior | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 11-01-1999 07:40 |
| Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 06-25-1999 08:21 |
