Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-10-2012, 10:32   #1 (permalink)
Member: 1655929
Sonork: arafay67
Need Help LT15i
im following the procedure for unlocking but when i attach testpoint press ready then attach usb cable there is no response just showing press and hold c button
then when i disconnect comes like this
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110010000000
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
llbug:[\\?\USB#Vid_05c6&Pid_9008#5&21c1c54a&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "The system cannot find the file specified"
FAILED TO SETUP PHONE
Unlock FAILED
Elapsed: 44 secs.
Old 06-10-2012, 10:35   #2 (permalink)
Malik Unlocking's Avatar
Member: 1728148
Sonork: 100.1612010
check this Sony Ericsson Lt15 unlocking procedure here
Old 06-10-2012, 10:38   #3 (permalink)
Member: 1655929
Sonork: arafay67
m following this also but still same
Old 06-10-2012, 11:31   #4 (permalink)
Ta@of!k's Avatar
Member: 1754434
Sonork: 100.1603928
CFG:110010000000
ATTACH TESTPOINT
Unlock FAILED
Elapsed: 44 secs.
Here is procedure.
1.
prepare for testpoint operation.
check testpoint location for your phone model in dist/v1.1287/docs
open testpoint for access
get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc.
2.
select proper phone model.
on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset
fill login/password and check if account valid.(if you dont have activation qualcomm-based semc phone)
press unlock
when prompted, execute steps in EXACT order:
remove cable from phone
remove battery from phone
attach testpoint
press "ready"
insert cable to phone, HOLDING TESTPOINT
install drivers from dist/v1.1287/drivers/USBFlash_driver/
when prompted detach testpoint
press "ready"
phone will now be unlocked
Asangsm team
Old 06-10-2012, 11:33   #5 (permalink)
Ta@of!k's Avatar
Member: 1754434
Sonork: 100.1603928
you have driver problem Please install drivers from dist/v1.1287/drivers/USBFlash_driver/
Asangsm team
Old 06-10-2012, 12:05   #6 (permalink)
Member: 1655929
Sonork: arafay67
its still the same finally i have to disconnect usb then shows this error before that press and hold back button
Old 06-10-2012, 12:15   #7 (permalink)
Member: 1655929
Sonork: arafay67
now i m stuck dont know what to anyone can guide me ?? im following the same procedure
Old 06-10-2012, 12:39   #8 (permalink)
Ta@of!k's Avatar
Member: 1754434
Sonork: 100.1603928
no need pressing and holding anything
just do this :
attach testpoint
press "ready"
press "ready"
Asangsm team
Old 06-10-2012, 13:28   #9 (permalink)
Member: 1655929
Sonork: arafay67
i did everything in the same way just now i change testpont cable as well but same thing
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.32695 seconds with 11 queries
