02-19-2009, 13:12 | #1 (permalink) |
Junior Member Join Date: Aug 2008
Member: 849127 Status: Offline Sonork: fonedoctor Thanks Meter: 1 | Need Help!!! W890 crashed a2_TA_Open_err:000A I need help if possible. Was unlocking W890i and in middle of process my pc crashed for no good reason.So i turned it on flashed the phone with R1FA035_APP_SW_1200_9164_GENERIC_AK_REDBROWNBLUE_C ID52_49_DB3150.software file and phone been done.but i cant turn on the phone any more ANY SOLUTION???? Please help.... |
02-19-2009, 13:49 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: E G Y P T Age: 48
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | 1. go to a2 tab 2. select correct model, that is important. 3. go to settings tab. 4. mark "use signed mode" , "use alternative security bypass", "unlock after flash" 5. go back to a2 tab 6. set desired domain ("retail" is best choice) 7. if you want to flash phone, add neccessary firmwares to firmware area and select correct custpack 8. if you selected firmwares, press flash, otherwise press unlock. 9. follow program instructions 10. your phone is repaired and unlocked (and flashed) if still the same write good gdfs file then unlock again |
The Following User Says Thank You to mohamed75 For This Useful Post: |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
pc driver crash need help | jackyivan | SETool2 | 0 | 03-29-2010 20:43 |
Need help for w890 | mani_satcell | Sony Ericsson Hardware Repair | 2 | 07-03-2009 06:29 |
need help with china XDS XPRESS MUSIC W890 | sahil00150 | Infinity-Box | 2 | 08-11-2008 23:19 |
Need Help! Crashed Motorola C975 with Wrong Flash File! | handynutzer | Motorola P2k | 0 | 07-14-2006 20:19 |
