11-17-2013, 15:10 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 41
Member: 389660 Status: Offline Thanks Meter: 60 | got locked st21,st21i2,st23,st26,c1504,c1505,c1604,c1605 ? we can help you... 1. grab v1.1401 from official rapidshare link 2. select proper phone model 3. check signed mode + altbypass + do full unlock 4. press unlock and follow program instructions we tested only st21,st26,c1605 phones. other phones must work too as they are same, the only problem could be in root procedure. to prevent problems, in second step, when setool2 ask you to power on phone, disconnect cable from phone, power on phone FULLY, wait at least 30 seconds to allow sluggish android fully start up, then enable USB debugging and only then connect phone. if root procedure will fail ( hang on "Please wait ...." for long time or abort with error ) please press "stop" button and repeat procedure. it it will fail again, please fill complain with identify output , flash phone with different firmware version and retry. notice : - phone will NOT have network until procedure will complete - you CAN root phone with any other tool BEFORE attempt to process it with setool2 - pretty please remove any resident antiviruses, malware monitors, spy programs,debuggers and so on before operation. for VERY limited testing time, 1 credit required for one phone unlock. processed phone CAN be flashed with any other 3rd-party tools, which using original sony loaders. processed phone CAN be flashed with SEUS processed phone CAN NOT be FOTA upgraded processed phone WILL have UNLOCKED fastboot ( unlocked bootloader ) you CAN NOT flash or fix octopus-processed phones using this setool2 version. setool2 will refuse to process such phones. you should wait, until they get my proper patches and integrate it into their software with security units rebuild. finally, until i'll have reliable way to fix such phones without need to have live phone, i'll not enable IMEI change. in šāʾAllāh , your phone will not be killed and will be unlocked. original thread : SETooL Official Support Forum |
