05-25-2010, 11:33 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 310423 Status: Offline Thanks Meter: 18 | p1 unlocking problem RUNNING v 1.01/UNI CARD SERIAL 00....... PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM14, SLAVE on COM42 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:3570,,,,,,,,,, CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED TRYING TO RESET PDA PHONE... SEARCHING FOR PHONE, "STOP" TO ABORT it cant instal the drivers so pls help me |
05-25-2010, 12:51 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
select USB as interface. that is REQUIRED. select phone model settings - check ONLY "signed mode (using server)", "do full unlock instead of usercode reset", fill your login details. back to original tab, press unlock, "GREEN BUTTON" | |
The Following User Says Thank You to roney_nexus For This Useful Post: |
05-25-2010, 13:51 | #5 (permalink) | |
Member: 310423 Status: Offline Thanks Meter: 18 | Quote:
sir thanks for your reply but i gives me this PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:3570,,,,,,,,,, CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED TRYING TO RESET PDA PHONE... SEARCHING FOR PHONE, "STOP" TO ABORT | |
05-26-2010, 07:18 | #6 (permalink) |
No Life Poster Join Date: Oct 2008 Location: BIH,Bratunac
Member: 888715 Status: Offline Thanks Meter: 109 | according to faq, you need to switch phone to modem mode before attempt to unlock it. now you have 2 options 1. restore backup, insert valid simcard,switch phone to modem mode 2. flash phone, then power it on, wait until language change dialog appear, power off phone after 1 or 2 - repeat unlock procedure. |
05-26-2010, 07:28 | #7 (permalink) | |
Banned Join Date: Nov 2009 Location: Lima, Perú
Member: 1159099 Status: Offline Thanks Meter: 6,371 | Quote:
B.R. Pablo | |
The Following User Says Thank You to xcachorrox For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
