03-27-2009, 19:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: canuaght place palika bazaar
Member: 647773 Status: Offline Sonork: 100.1611571 Thanks Meter: 65 | p1i flashing problem |
03-28-2009, 12:53 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Berkane to netherland Age: 48
Member: 58969 Status: Offline Thanks Meter: 56 | 1-Tick SIGNED MODE (USING SERVER) 2-Press and hold @ 3-Press flash 4-Connect usb to the phone 26-3-2009 16:51:07 SIGNED MODE (USING SERVER) 26-3-2009 16:51:07 writing "C:\Documents and Settings\ikke\Bureaublad\khalid\P1i_R6G05_MR3_GENE RIC_SE_CDA162024_92_R6A.zip" 26-3-2009 16:51:07 Processing package 26-3-2009 16:51:07 C:\Documents and Settings\ikke\Bureaublad\khalid\P1i_R6G05_MR3_GENE RIC_SE_CDA162024_92_R6A.zip 26-3-2009 16:51:07 26-3-2009 16:51:17 detected MASTER on COM189, SLAVE on COM190 26-3-2009 16:51:17 PDA EROM VERSION: CXC162122 R1C01 26-3-2009 16:51:17 Processing ISP files 26-3-2009 16:51:19 ISP SOFTWARE VERSION: 2.38 26-3-2009 16:51:21 Flashing: 26-3-2009 16:51:21 2_38_CXC162176_isp_EN_MO_Camera_Firmware.ispsoftwa re 26-3-2009 16:51:31 Processing ACPU files 26-3-2009 16:51:32 PROCESSING: Core OS 26-3-2009 16:51:53 FILE FLASHED OK 26-3-2009 16:51:53 PROCESSING: ROFS1 26-3-2009 16:54:11 FILE FLASHED OK 26-3-2009 16:54:11 PROCESSING: ROFS1 Extension 26-3-2009 16:55:53 FILE FLASHED OK 26-3-2009 16:55:53 PROCESSING: ROFS2 26-3-2009 16:56:50 FILE FLASHED OK 26-3-2009 16:56:50 PROCESSING: USERDATA 26-3-2009 16:59:20 FILE FLASHED OK 26-3-2009 16:59:20 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! 26-3-2009 16:59:21 fetched MASTER on COM189, SLAVE on COM190 26-3-2009 16:59:21 Open COM port OK 26-3-2009 16:59:23 ChipID:7100,EMP protocol:0301 26-3-2009 16:59:23 NEW SECURITY (MARITA RESPIN) PHONE 26-3-2009 16:59:23 26-3-2009 16:59:23 PHONE STATE: "RETAIL" 26-3-2009 16:59:23 FLASH CID: 0053 26-3-2009 16:59:23 Speed:921600 26-3-2009 16:59:24 OTP: LOCKED:1 CID:52 PAF:1 IMEI:3570330152xxx3 CERT:RED 26-3-2009 16:59:25 LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 26-3-2009 16:59:25 Flash ID check:2010 26-3-2009 16:59:25 Flash props sent ok 26-3-2009 16:59:25 Processing CCPU files 26-3-2009 16:59:25 PROCESSING: R5A02_CXC162175_CCPU_FS_EN_RED_CID53_RESPIN.softwa re 26-3-2009 16:59:26 CURRENT FLASH FILE CID:53 26-3-2009 16:59:26 SSW uses full hash, hash len is:160 26-3-2009 16:59:26 Will flash 8 blocks... 26-3-2009 16:59:37 SSW loading returns:0 26-3-2009 16:59:37 PROCESSING: R9K009_CXC162037_CCPU_HE_LL_NI_RED_CID53_RESPIN.so ftware 26-3-2009 16:59:40 CURRENT FLASH FILE CID:53 26-3-2009 16:59:40 SSW uses full hash, hash len is:2120 26-3-2009 16:59:40 Will flash 106 blocks... 26-3-2009 17:01:41 SSW loading returns:0 26-3-2009 17:01:42 Processing update files 26-3-2009 17:01:53 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E 26-3-2009 17:01:53 loader startup: executed 26-3-2009 17:01:53 loader GDFS startup: executed 26-3-2009 17:01:53 loader unlock: executed 26-3-2009 17:01:53 Writing GDFS var 0000/0094/0001 26-3-2009 17:02:14 Success 26-3-2009 17:02:14 Writing GDFS var 0002/06D6/0001 26-3-2009 17:02:14 Success 26-3-2009 17:02:14 Writing GDFS var 0002/06D4/0004 26-3-2009 17:02:14 Success 26-3-2009 17:02:14 Writing GDFS var 0002/06D3/000F 26-3-2009 17:02:14 Success 26-3-2009 17:02:14 Writing GDFS var 0000/0094/0001 26-3-2009 17:02:14 Success 26-3-2009 17:02:14 Writing GDFS var 0002/079E/0052 26-3-2009 17:02:14 Success 26-3-2009 17:02:15 Elapsed: 668 secs. |
p1i flashing problem | cejer | Sony Ericsson | 3 | 05-04-2010 09:03 |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
P1i Flashing Problem. | Qaisar Mahmood | SETool2 | 1 | 01-11-2009 22:13 |
sony ericsson p1i connection problem | gbada | SETool2 | 2 | 08-01-2008 14:11 |
P1i connection problem | curtisbcm | Cruiser Suite | 4 | 07-15-2008 17:31 |
