Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 04-12-2010, 08:44   #1 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
P1i gdfs params failed
PLS ANYONE SHARE GDFS FILE INSSW FORMAT FOR P1i AS THE FONE SHOWS GDFS ERROR WHEN IDENTIFY.ITS URGENT PLS
SAJIDMIRZA
Old 04-12-2010, 08:58   #2 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
Post here your identify log then i will try thx....
Old 04-12-2010, 09:04   #3 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
RUNNING v 1.01/UNI
CARD SERIAL 001*****
USBFLASH DRIVER VERSION 02.02.00.05
CFG:000000000000
PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
detected MASTER on COM5, SLAVE on COM12
PDA EROM VERSION: CXC162122 R1D01
NEW SECURITY (RESPIN) PHONE
ChipID:7100,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0053
Speed:115200
FLASH ID: 2010
OTP: LOCKED:1 CID:52 PAF:1 IMEI:35703301245620 CERT:RED
FLASH CID:53 COLOR:RED
setGDFS_params failed
failed to setup GDFS
Elapsed: 24 secs.
Old 04-12-2010, 09:59   #4 (permalink)
Member: 288504
Thanks Meter: 2,266
i think that phone has state of unfinished reset operation.
write gdfs on emptyboard tab
write correct erom on emptyboard tab
retry flashing after that
Old 04-12-2010, 10:39   #5 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
i understood the problem but i dont have gdfs file bro,if u have the file pls upload it in ssw format
thanx for response
sajidmirza
Old 04-12-2010, 11:45   #6 (permalink)
Member: 288504
Thanks Meter: 2,266
plz read this thread:
DB2001_P1_GDFS_IN_SSW_FORMAT.
Old 04-12-2010, 15:36   #7 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
I HAVE DONE PROCESS AS U TOLD BUT ITS NOW GETTING THIS ERROR
SIGNED MODE (USING SERVER)
CFG:100000000000
PHONE STATE: "DEVELOPER"
FLASH CID: 0049
Speed:115200
OTP: LOCKED:1 CID:52 PAF:1 IMEI:35703301245620 CERT:BROWN
LDR:060529 0823 LIECXC1325712_DB2000_PRODUCTION_R1A002
writing "D:\SETOOL\FLASH FILES\P1i\DB2001_P1_GDFS_IN_SSW_FORMAT.ssw"
CURRENT FLASH FILE CID:49
SSW uses full hash, hash len is: 160
Will flash 8 blocks...
Setting up GDFS...
OTP WRITE NOT EXECUTED
WRITING CLEAR SIMLOCK UNITS...
ALL UNLOCK/LOCK CODES SET TO "85470156"
SIGNING...
Elapsed: 87 secs.
CFG:100000000000
writing "C:\Documents and Settings\User\Desktop\SE\v1.01\eroms\pda_ccpu_conv ert_red53_signed_brown49.zip"
Processing package
package not contains ISP files
package not contains ACPU files.
fetched MASTER on COM5, SLAVE on COM12
FLASH CID: 0049
Speed:115200
Processing CCPU files
PROCESSING: pda_ccpu_convert_red53_BROWN_CID49_DB2001.software
SSW uses full hash, hash len is: 20
Will flash 1 blocks...
no update files in package
Elapsed: 37 secs.
CFG:100000000000
writing "D:\SETOOL\FLASH FILES\P1i\P1i_MR3_ARABIC1__R9K009_R1D_R6G04_R6G02_ .zip"
Processing package
Processing ISP files
ISP SOFTWARE VERSION: 2.38
Flashing:
2_38_CXC162176_isp_EN_MO_Camera_Firmware.ispsoftwa re
Processing ACPU files
PROCESSING: Core OS
FILE FLASHED OK
PROCESSING: ROFS1
FILE FLASHED OK
PROCESSING: ROFS1 Extension
FILE FLASHED OK
PROCESSING: ROFS2
FILE FLASHED OK
PROCESSING: USERDATA
FILE FLASHED OK
FLASH CID: 0053
Speed:115200
LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003
FLASH ID: 2010
PROCESSING: R5A02_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re
CURRENT FLASH FILE CID:53
packet not acknowledged (01)
subblock 01B NAK, [20720000/00010000]
Break.
Elapsed: 431 secs.
Old 04-12-2010, 17:23   #8 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
try with a full charged battrie
Old 04-12-2010, 17:41   #9 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
ok i will try again
sajidmirza
Old 04-12-2010, 18:09   #10 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
i have tried with fully charged battery but it stops at a particular stage .
sajidmirza
Old 04-12-2010, 23:39   #11 (permalink)
Member: 288504
Thanks Meter: 2,266
charge battery fully,repeat.
if still same, check phone hardware.
Old 07-19-2010, 10:43   #12 (permalink)
Member: 1287416
Same problem here.
Thats the report:
19:42:39| XS++ v3.1 (Darwin) Ready !
19:43:11| Executing SEMC Smartphone Operations!
19:43:11| Please hold boot key ('@' or 'C') and connect device...
19:43:28| Master Port detected: COM3
19:43:28| Slave Port detected: COM4
19:43:28| Opening Port!
19:43:28| INIT MASTER...OK!
19:43:28| PHONE INFO SAMPLED...OK!
19:43:29| EPOC APPLET HEADER SENT...OK!
19:43:29| APPLET BODY SENT...OK!
19:43:29| SHUTTING DOWN MASTER...OK!
19:43:30| Baseband ID: 7100
19:43:30| Protocol Version: 3.1
19:43:30| NEW SECURITY PHONE DETECTED! SWITCHING...
19:43:31| Speed set to 460800
19:43:31|
19:43:31| Sending db2000_cid03_prodid_p3b.bin...
19:43:33| Applet ID: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B
19:43:33| This is a PRODUCTION_ID loader
19:43:33| Activating GDFS...
19:43:33| Cannot open GDFS
19:43:33| Warning: IMEI name does not match GDFS name (IMEI:P1 GDFS:n/a)
19:43:33| ...using IMEI name
19:43:33|
19:43:33| Profiling EPOC smartphone...
19:43:33| Platform: DB2001
19:43:33| OTP CID: 52
19:43:33| EROM CID: 53
19:43:33| EROM Color: Red
19:43:33| IMEI: 35703301xxxxxx
19:43:33| Phone ID: P1
19:43:33| Part Number: n/a
19:43:33| Phone smartphone version: R1C01
19:43:33| Phone software version: э/
19:43:33| Processing Unit:  я—]Чыv
19:43:33| Organizer:
19:43:33| CDA:
19:43:33| Ready for operation!
19:44:10|
19:44:10| Parsing package contents...
19:44:10| CCPU (BABE) file: CCPU_Signaling_SW_CXC162037_R9H004_RED53.software
19:44:10| CCPU (BABE) file: CCPU_Signaling_SW_R9H004R_RED53.software
19:44:24|
19:44:24| SMARTPHONE WILL BE FLASHED IN 1 PHASE!
19:44:24|
19:44:24| [---------- PHASE 2 ----------]
19:44:24|
19:44:24| Sending db2001_cid53red_flash_r1a003.bin...
19:44:26| Applet ID: 060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003
19:44:26| This is a FLASH loader
19:44:26| Flashing CCPU_Signaling_SW_CXC162037_R9H004_RED53.software
19:44:26| Header type: BABE
19:44:26| 107 flashblocks
19:47:35| Finishing flash
19:47:37| Done flashing
19:47:37| Flashing CCPU_Signaling_SW_R9H004R_RED53.software
19:47:37| Header type: BABE
19:47:37| 8 flashblocks
19:48:01| Failed sending flashblock 3. Returnvalue 0x1
19:48:01| Finishing flash
Action journal
13:47:38  Identify
13:47:38  Shows detailed information about the connected phone.
13:47:38  Operating system: Microsoft Windows 7 Ultimate Edition (build 7600), 32-bit
13:47:39  Application version: 0.07.2279 (beta)
13:47:39 . The action name is 'Identification'
13:47:39  Selected phone type: P1
13:47:39  Selected connection method: USB EROM
13:47:39 i Instructions
13:47:39 i 1. Make sure the phone battery is charged to at least 50%.
13:47:39 i 2. Switch off the phone!
13:47:39 i 3. Remove the phone battery and wait at least 5 seconds before reinserting it!
13:47:39 i 4. Press and hold the button C, then connect the cable to the phone!
13:47:39 . The action started waiting for the user
13:48:33 . The action finished waiting for the user
13:48:33  Connecting via Sony Ericsson Port (COM14, COM13)...
13:48:33  Device driver version: 4.40.6.0
13:48:34  Boot mode: EROM
13:48:34  ACPU EROM version: CXC162122 R1D01
13:48:34  Sending loader...
13:48:35  Waiting for loader response...
13:48:35  Connecting to the baseband CPU...
13:48:37  Entering baseband CPU service mode...
13:48:37  Detected chipset: DB2001 '7100
13:48:37  Boot mode: ROM
13:48:37  Sending loader...
13:48:37  Flash chip manufacturer: Intel®
13:48:38  Flash chip ID: 8964
13:48:38  IMEI: 357033xxxxxxxx
13:48:38  OTP CID: 52
13:48:38  OTP area status: Locked
13:48:38  Product type: Retail
13:48:38  Effective CID: 53
13:48:38  Effective color: Red
13:48:38  Initializing GDFS access...
13:48:38 e Error: GDFS configuration not found.
13:48:38  Turning off the phone...
13:48:38 i Please disconnect battery and cable from the phone!
13:48:39 s Successfully done.
13:48:39 . The action entered shutdown phase
13:48:39 . The action reported success
Additional details
32 C1 BD 1A D3 51 2F 16 91 22 DD AE 65 08 29 CE
F9 24 1B DB B3 80 81 88 9F E5 73 3E 35 F8 2F D9
67 B8 9B 06 E3 9E 31 F6 CF 08 C7 EF 0D 3E
Old 07-24-2010, 14:45   #13 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 96
Elapsed: 24 secs.
i get this error after reset operation
after flash all ok
and flash version
P1i_R6G05_MR3_GENERIC_SE_CDA162024_92_R6A.zip
thanks to all
Old 02-05-2011, 15:20   #14 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
i have same problem ..but i have p1i prototype
any way to successful flash it?
Old 02-05-2011, 15:36   #15 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
Originally Posted by roney_nexus View Post
check link plz .. file missing
3330 v 412 fail with dfs 211 denn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-19-2001 22:06
In wintesla 3310, what does cobba parrarel failed means brittnee Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-18-2001 16:05
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-12-2001 15:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.32383 seconds with 9 queries
