Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 06-23-2010, 06:48   #1 (permalink)
Member: 90701
Thanks Meter: 134
P1i HDR block not accepted,error: 02
Hi, I was trying to flash sony ericson P1i but after take the whole flash showing the this msg: HDR block not accepted,error: 02
Here is the logs:
RUNNING v 1.08/UNI
CARD SERIAL 0005XXXX
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100000000000
writing "D:\setool2g\Flash file\SE\P1\P1i_MR3_WORLD1__R9K009_R1D_R6G04_R6G02_ .zip"
Processing package
detected MASTER on COM197, SLAVE on COM198
PDA EROM VERSION: CXC162122 R1C01
Processing ISP files
ISP SOFTWARE VERSION: 2.38
Flashing:
2_38_CXC162176_isp_EN_MO_Camera_Firmware.ispsoftwa re
Processing ACPU files
PROCESSING: Core OS
FILE FLASHED OK
PROCESSING: ROFS1
FILE FLASHED OK
PROCESSING: ROFS1 Extension
FILE FLASHED OK
PROCESSING: ROFS2
FILE FLASHED OK
PROCESSING: USERDATA
FILE FLASHED OK
PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
fetched MASTER on COM197, SLAVE on COM198
NEW SECURITY (RESPIN) PHONE
ChipID:7100,EMP protocol:0301
PHONE STATE: "DEVELOPER"
FLASH CID: 0049
Speed:921600
OTP LOCKED:1 CID:52 PAF:1 IMEI:3570330XXXXXXX CERT:BROWN
LDR:060529 0823 LIECXC1325712_DB2000_PRODUCTION_R1A002
Processing CCPU files
PROCESSING: R5A02_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re
CURRENT FLASH FILE CID:53
SSW uses full hash, hash len is: 160
Can any one help me please?
Thnks
Old 06-23-2010, 07:13   #2 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 86
Hello
use fully charged battery.
Old 06-23-2010, 08:56   #3 (permalink)
Member: 90701
Thanks Meter: 134
Originally Posted by mazmaz1 View Post
Hello
Hi, Thnks for the answer, well yes I used fully charged battery. But same thing
Old 06-23-2010, 11:07   #4 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
You can DO Reset Procedure.
Old 06-24-2010, 13:38   #5 (permalink)
Member: 90701
Thanks Meter: 134
Hi, Can you please explain the reset procedure?
Old 06-24-2010, 14:29   #6 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Thanks Meter: 2,266
I Think If still problem by flashing you can rehot or change ic flash...i ever try and success for this case....
The Following User Says Thank You to roney_nexus For This Useful Post:
Old 06-29-2010, 03:41   #7 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 86
Hello
yes it may be hardware prob.
first use good flash files then rehot flash chip(installed on cpu) and work carefully on it.
please post work's result.
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Nokia 5110 Blocked Goodfox Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 09-18-1999 13:27
Page generated in 0.18355 seconds with 9 queries
