Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2008
Member: 686903 Status: Online Thanks: 6
| p990i flash problem please setool team how can i flash p990i i mean which files i should fill id someone can send me the correct way how to flash it please thanks in advance |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 28
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks: 258
| FLASHING OF A1-BASED PDA PHONES download needed firmware package. add it to firmware area on PDA tab. DO NOT UNZIP PACKAGE, JUST ADD IT AS IS. on settings,check "signed mode" press flash note, if phone have BROWN domain, you must FIRST flash conversion packs: Code: for m600,w950,p990: for brown cid 36: pda_ccpu_convert_red49_signed_brown36.zip for brown cid 49: pda_ccpu_convert_red49_signed_brown49.zip for w960,p1: for brown cid 49: pda_ccpu_convert_red53_signed_brown49.zip |
| The Following User Says Thank You to roney_nexus For This Useful Post: |
| | #3 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2010 Location: san andres bukid malate maynil
Member: 1271193 Status: Offline Sonork: 46625f6be23fcb794745a520 Thanks: 2
| boss ihave p990i prolem is dead unit it is not connect to setool plz give me the solution plz reply |
| | #4 (permalink) |
| boss ihave p990i problem is dead unit i will try to program the setool but it is not connct to the setool how to sulv this plz reply me boss'''''' |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: IRAN(land of heros) Age: 33
Member: 115172 Status: Offline Thanks: 114
| How do you try to connect it? Use following combinations and try with fully charged battery: 1. Press @ and connect USB 2.Press C and connect USB 3.Press 2+5 and connect USB If not working or if you can't hear sound of a device showing new device connected then check phone hardware,first go to USB connector usually it makes the connection problm. |
| | #7 (permalink) |
| RUNNING v 1.01/UNI CARD SERIAL 00013715 PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C SIGNED MODE (USING SERVER) CFG:100100000000 writing "C:\softwares\Setool\SE FILES\p990\P990i_Generic_World1_R9G007_R6D23_R6D23 .zip" Processing package C:\softwares\Setool\SE FILES\p990\P990i_Generic_World1_R9G007_R6D23_R6D23 .zip detected MASTER on COM152, SLAVE on COM153 PDA EROM VERSION: CXC162060 R2D01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM152, SLAVE on COM153 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300991703 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 2010 Processing CCPU files PROCESSING: R6A04_CXC162087_CCPU_fs_HE_Red_CID49_Respin.softwa re CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9G007_CXC162037_CCPU_HE_LL_NI_Red_CID49_Respin.so ftware CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 2140 Will flash 107 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R2A01_P990_CCPU_GDFS_Update.gdfs Writing GDFS var 0000/057E/0022 Writing GDFS var 0000/00A6/0005 Writing GDFS var 0000/0052/0014 PROCESSING: R6D23_CDA162007_1_CCPU_HE_NoSIMLock_Generic_World1 .gdfs Writing GDFS var 0002/079E/0065 Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0006 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 Elapsed: 1377 secs. SIGNED MODE (USING SERVER) CFG:100100000000 writing "C:\softwares\Setool\SE FILES\p990\R4A09_CDA162007_1_ACPU_HE_Generic_World 1.zip" Processing package C:\softwares\Setool\SE FILES\p990\R4A09_CDA162007_1_ACPU_HE_Generic_World 1.zip detected MASTER on COM152, SLAVE on COM153 PDA EROM VERSION: CXC162060 R2D01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM152, SLAVE on COM153 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300991703 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID: 2010 Processing CCPU files PROCESSING: R4A01_CXC162087_CCPU_fs_HE_Red_CID49_Respin.softwa re CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9EA001_CXC162037_CCPU_HE_LL_NI_Red_CID49_Respin.s oftware CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: 633_91_R10A03_CDA162007_1_CCPU_HE_NoSIMLock_Generi c_World1.gdfs Writing GDFS var 0002/079E/0066 Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0006 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 Elapsed: 1289 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-16-1999 00:44 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
