05-30-2010, 11:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | .::P990i what"s problem help::. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM31, SLAVE on COM32 PDA EROM VERSION: CXC162060 R2D01 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 FLASH ID: 8964 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300630487 CERT:BROWN FLASH CID:49 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 19 secs. I think its gdfs problem, so i am try to recover it press recovery buttons, recover successfully but when i write eroms file (v1.01\eroms\ACPU\P990.zip) this folder, show write error Show Logs: writing "C:\Documents and Settings\Faysal\Desktop\v1.01\eroms\ACPU\p990.zip" Processing package C:\Documents and Settings\Faysal\Desktop\v1.01\eroms\ACPU\p990.zip detected MASTER on COM31, SLAVE on COM32 PDA EROM VERSION: CXC162060 R2D01 package not contains ISP files Processing ACPU files PROCESSING: Mini Boot FILE FLASHED OK PROCESSING: Core Loader FILE FLASHED OK PROCESSING: Extended ROM FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM31, SLAVE on COM32 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300630487 CERT:BROWN ldr_on_ldr hdr no ack (10) Break. Elapsed: 38 secs. Can any one tell me this problem solution????? |
05-30-2010, 12:30 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | from setool official forum FAQ: POSSIBLE PROBLEMS DB200X+NEXPERIA damaged SCRC (imei mismatch), damaged seczone, damaged gdfs 1. go to emptyboard tab 2. select model 3. on settings, check "signed mode", fill login details 4. press reset, connect phone 5. if gdfs structure okay, skip that step, otherwise add to firmware are gdfs in ssw format: one of DB2001_G700_GDFS_IN_SSW_FORMAT.SSW DB2001_M600_GDFS_IN_SSW_FORMAT.ssw DB2001_P1_GDFS_IN_SSW_FORMAT.ssw DB2001_P990_GDFS_IN_SSW_FORMAT.ssw 6. add to firmware area correct EROM for m600,w950,p990: pda_ccpu_convert_red49_BROWN_CID49_DB2001.software for w960,p1da_ccpu_convert_red53_BROWN_CID49_DB2001.so ftware 7. press flash 8. reflash phone on usual PDA tab if needed. phone could not boot using dcu60, erom version timeout error,etc acpu erom damaged, to restore it 1. select correct PDA model 2. find corresponding EROM in dist\eroms\, add it to firmware area 3. select correct com/ufs port 4. press recovery 5. connect turned off phone 6. reflash phone via USB with normal firmware |
05-30-2010, 14:21 | #3 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | 1. I select emptyboard tab 2. select model p990 3. press recovery 4. success fully recover phone, 5. here is recover log SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM31, SLAVE on COM32 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 RESET:070703 1102 NPACXC125880_DB2000_CERTRESETLOADER_P4D FLASH ID: 8964 GOT SEED:64280D3A2180A97C0570ED99 P96 AUTH PASSED OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300630487 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 76 secs. 6. But i can not write gdfs this phone. here is my procidure: I. select emptyboard tab 2. select model p990 3. unmark/mark on settings "signed mode" 3. select gdfs file in this foldre (v1.01\gdfs_in_ssw_format\db2000) 4. file name DB2001_P990_GDFS_IN_SSW_FORMAT.ssw here is this log: CFG:000000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM31, SLAVE on COM32 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300630487 CERT:BROWN ldr_on_ldr hdr no ack (10) Elapsed: 30 secs. whats problem? why i can not write gdfs file, my phone cid is 49 brown, how can i change my phone cid to red 49, my phone information log: CFG:000000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM31, SLAVE on COM32 PDA EROM VERSION: CXC162060 R2D01 NEW SECURITY (RESPIN) PHONE ChipID:7100,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0049 Speed:921600 FLASH ID: 8964 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35959300630487 CERT:BROWN FLASH CID:49 COLOR:BROWN setGDFS_params failed failed to setup GDFS Elapsed: 22 secs. sir help me please? Last edited by brokendreem; 05-30-2010 at 14:27. |
05-30-2010, 19:42 | #4 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | you try to write this file? pda_ccpu_convert_red49_BROWN_CID49_DB2001.software |
The Following User Says Thank You to voltran2008 For This Useful Post: |
05-31-2010, 10:58 | #8 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | brother i am trying write this 2 EROM file, full charged battery, but same problem? 1. pda_ccpu_convert_red49_BROWN_CID49_DB2001.software 2. pda_ccpu_convert_red49_signed_brown49.zip I upload 1 picture, <script src='http://img16.imageshack.us/shareable/?i=99354656.jpg&p=tl' type='text/javascript'></script><noscript></noscript> whats problem tell me please? |
06-05-2010, 13:07 | #11 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | 1. select correct PDA model 2. find corresponding EROM in dist\eroms\, add it to firmware area 3. select correct com/ufs port 4. press recovery 5. connect turned off phone 6. reflash phone via USB with normal firmware you need to flash erom first to convert phone to RED |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
