perfectly flashing G700 BY SETOOL v0.915020/UNI CARD SERIAL: ********* Loaded 51 flash descriptors Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 23 secs. Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 229 secs. Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 42 secs. PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM264, SLAVE on COM265 llbug: port 264 open error: "The system cannot find the file specified" master can't be inited smartphone setup failed Elapsed: 6 secs. PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM264, SLAVE on COM265 llbug: port 264 open error: "The system cannot find the file specified" master can't be inited smartphone setup failed Elapsed: 8 secs. PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! CAN'T DETECT SMARTPHONE smartphone setup failed PROCEDURE WAS STOPPED BY USER Elapsed: 10 secs. PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM20, SLAVE on COM21 PDA EROM VERSION: 1202-0237 R1A01 Open COM port OK ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Flash ID check:2010 Flash props sent ok OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702017455 CERT:RED FLASH CID:53 COLOR:RED phone model: G700 part number: FAD-3022018-BV Phone part version: 1203-6566 R9L004 organizer part version: 1202-7347 R6H815 CDA part version: 1207-5362 R5A CCPU part version: 1203-6568 R5B03 USERCODE:0000 Elapsed: 14 secs. SIGNED MODE (USING SERVER). writing C:\Documents and Settings\MobileDoctor`s\Desktop\g700 bg\g.zip Processing package C:\Documents and Settings\MobileDoctor`s\Desktop\g700 bg\g.zip detected MASTER on COM20, SLAVE on COM21 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM20, SLAVE on COM21 Open COM port OK ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702017455 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 Flash ID check:2010 Flash props sent ok Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:160 Will flash 8 blocks... SSW loading returns:0 PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:2120 Will flash 106 blocks... SSW loading returns:0 Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader startup: executed loader GDFS startup: executed loader unlock: executed Writing GDFS var 0002/06D6/0001 Success Writing GDFS var 0002/06D4/0005 Success Writing GDFS var 0002/06D3/000F Success Writing GDFS var 0000/0094/0001 Success Elapsed: 381 secs. HIER NEED USB DRIVERS http://rapidshare.com/files/16752575...ivers.rar.html |
Nice Info Mate, still the Best PDA Flasher Box. |
congratulations !!!! rally nice info..................big thanks............. |
100% working :cool::cool::cool: deal SETOOL |
g700 usb driver pls thaks n advance |
can you share the files that youve been used........am waiting |
pls upload the g900 usb driver here www.4shared.com thanks |
use ZIP file, no exstrac file.. |
How to flashing the G900 by SETOOL2..pls...the phone can't detect by pc.pls help..:( |
and i have same problem cannot flash g900 show me this error: 2/25/2009 12:47:10 detected MASTER on COM231, SLAVE on COM231 2/25/2009 12:47:10 llbug: port 231 open error: "Access is denied" 2/25/2009 12:47:10 slave can't be inited 2/25/2009 12:47:10 smartphone setup failed 2/25/2009 12:47:10 Break. 2/25/2009 12:47:10 Elapsed: 34 secs. i think something is wrong with my port's how to correct , how to solve this........... |
2 Attachment(s) Quote:
Here you go ... BR Max_B |
@ delchoni Man, can You give me flash files with bulgarian for G700 or tell me what file to download from support area, please! Thanks in advance! |
