03-28-2010, 07:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Dubai
Member: 45561 Status: Offline Thanks Meter: 59 | THIS PHONE IS K810i BUT IF FLASH IT K700i SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35799401477843 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1KG001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KG001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100100000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35799401477843 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\SE files\flash\k810i 52 R8BF003_CXC1250811_SM_RED_CID52(2).software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\SE files\flash\k810i 52 R8BF003_FS_S_E_EUROPE_SM_RED_CID52(2).software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 531 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35799401477843 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1KG001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KG001 Language Package: EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 14 secs. |
03-28-2010, 08:44 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | u can solve ur problem with GDFS repairhttp://forum.gsmhosting.com/vbb/f473...unlock-822592/ |
03-29-2010, 08:03 | #7 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | Quote:
1...recover 2...write gdfs bin format 3....write erprom.... use lateste version exe of Setool.....free Last edited by haji rahim; 03-29-2010 at 08:11. | |
03-30-2010, 08:36 | #12 (permalink) |
Freak Poster Join Date: Jun 2005 Location: http://www.paybox.me/r/mourad1 Age: 47
Member: 155016 Status: Offline Thanks Meter: 130 | I guess ,it's pretty easy to solve as a problem If reset mode didn't work out for you then it must be a problem within I/O devices related to MCU , basically , like LCD module, Camera Module, USB/Serial switch..and so on ! And mostly was LCD module Faulty , so just try changing it for it has worked many times for me. B.R |
The Following User Says Thank You to Mourad120 For This Useful Post: |
04-08-2010, 21:08 | #13 (permalink) | |
Member: 45561 Status: Offline Thanks Meter: 59 | Quote:
LG CG180 after flash...This Phone is Hacked !!! | bob42200 | VygisToolbox | 1 | 08-12-2009 19:52 |
Writing error - phone is locked but log is missing - is the refound possible? | siewa26 | BB5 Box by D.K. | 2 | 03-29-2009 01:14 |
please i have 3220 its ok but i flashed it with new flash file the box cant enter CN | gsm4libya | Twisterflasher | 0 | 11-17-2005 14:54 |
2600 not charging when phone is off but charging when phone is on | codec_romania | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 08-11-2005 09:31 |
Make money by searching google...normally I think this stuff is stupid but it worked! | jordanj77 | Off Topic Zone | 0 | 04-22-2005 06:04 |
