04-28-2012, 18:09 | #2 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Unknown
Member: 929782 Status: Offline Sonork: 100.1641069 Thanks Meter: 617 | how to unlock j108 phone without s1 signature server to be online ? how to unlock j108 phone without s1 signature server to be online ? a: you need to have setool2 v1.1285 or higher. you need to have test sim card ( with mnc/mcc 00101 ) in phone. you need to have memory card in phone. you need to have valid username/password with at least 3 credits. phone should be in working state. procedure is complicated and definitely NOT for beginners. 1. flash any R7EA011 firmware into phone. fully power on phone, wait until phone setup will be completed. this is absolute requirement. 2. run setool2, check that valid username/password entered, then go to "j108 bypass" tab. press "upload executor package" insert test sim card, memory card, connect powered off phone while holding "C" button after initial procedure, disconnect phone , power on it, wait until setup complete and power off phone again. 3. press "upload executor extractor" insert test sim card, memory card, connect powered off phone while holding "C" button after initial procedure, disconnect phone , power on it, wait until setup complete set usb connection in phone options to "file transfer" and copy from memory card "other\executor.b" to setool2\backup\%imei% . setool2 will open that folder for you in minimized state, check taskbar. ( if your system recognize phone as MTP device, you can copy file without setting USB connection to "file transfer" ) power off phone. 4. press "unlock phone" insert test sim card, memory card, connect powered off phone while holding "C" button after initial procedure, disconnect phone , power on it, set usb connection in phone options to "other OS" install phone MODEM drivers, if required ( dist\drivers\Modem_Drivers ) wait, until setool2 finish procedure. after setool2 finish procedure, do not disconnect phone from cable, do not remove phone battery, until phone powers on by itself. otherwise you need to restore secunits backup and repeat step 3 from beginning. this is not patch unlock, phone unlock is permanent |
The Following User Says Thank You to ..::SH@RIF®™::.. For This Useful Post: |
06-12-2012, 12:54 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
customer again returm back set me . on screen show again insert corret sim card i do same process again & again but still same problem & also i reflash again two times but no progress plz help fast . thanxx | |
06-12-2012, 16:41 | #4 (permalink) | |
important ! delete executor from games ! cause once user will run executor, phone will enter "5-locks" state ... the only way to fix it - restore secunits backup and run unlock procedure again, from step 3 , no more credits required | |
01-12-2013, 13:08 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | thats not issue , where is the option to delete , ifound under game no option to delete all r mentioning- important ! delete executor from games ! cause once user will run executor, phone will enter "5-locks" state no one tells how to deliete |
01-13-2013, 13:19 | #11 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | press "C" on "executor" entry, when browsing "games" menu master reset will help too, definitely, phone reflashing will do job too, but from my side delete executor much faster |
The Following User Says Thank You to the_laser For This Useful Post: |
SL45 blue L.e.d install SUCCESS!!!!!! opened phone :):) | bluelights | x1x to x45/x50 | 4 | 10-01-2001 21:04 |
Can someone success on A3x repair phone? | nok | x1x to x45/x50 | 0 | 08-14-2001 23:44 |
STILL NO Success in disabling the PHONE CODE in C28 v61 | ed2k_7 | x1x to x45/x50 | 1 | 07-31-2001 17:34 |
SUCCESS in Repairing 3310 Contact Service (Double-blink) using NFREE by ViperBJK | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 07-08-2001 16:00 |
s35 successfully killed.... | landy | x1x to x45/x50 | 0 | 06-24-2001 12:50 |
