05-12-2007, 11:13 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: gods on country(kerala)
Member: 31906 Status: Offline Thanks Meter: 101 | Please Explane How To Unlocking Db2020 In Setool v0[1].91380080 |
05-12-2007, 11:34 | #3 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306903 Status: Offline Thanks Meter: 19 | Here u Go ! follow there step and doin these step the internet has to be connected. 1. Select Model from the Sony Ericsson TAB 2. Then click on Settings Tab and Check on: 1. Use server for CSCA Unlock/Flash 2. Enable Alternative Security Bypass 3. Do Full unlock instead of Reset User Code 3. And then enter your user name and password and Supplied IP in related boxes. 4. Then Click On Sony Ericsson tab and Click on the Unlock/repair button 5. As soon as it says SERVER Enabled then Press and Hold C button of the Phone and insert the USB cable in phone and as soon as it picks up release the button and see the processing. Tht's it. Do this and reply post Thnx ALi |
05-12-2007, 12:20 | #5 (permalink) | |
Member: 31906 Status: Offline Thanks Meter: 101 | Quote:
THANKS...............................V MUCH | |
05-18-2007, 07:49 | #10 (permalink) |
Junior Member Join Date: Nov 2004
Member: 90630 Status: Offline Thanks Meter: 2 | 1. Use the DCU-60 USB cable 2. Select USB from the Interface drop down 3. Check the firmware version using the identify button. Look in the rest folder to see if a restoration file for this firmware version exists. 3. Upgrade EROM Make sure you have UNCHECKED the option ENABLE ALTERNATIVE SECURITY BYPASS and then press RECOVERY. 3. On the SonyEricsson Tab select the model from drop down list 4. On the Settings Tab make sure the following are checked: USE SERVER FOR CSCA UNLOCK/FLASH ENABLE ALTERNATIVE SECURITY BYPASS 5. Also ensure the account details are populated with the correct information. - Username - Password - Server IP 6. Go to Sony-Ericsson Tab: Press UNLOCK/Repair 7. Connect phone to USB Cable while holding down the “C” button. Release the button once phone detected |
05-18-2007, 09:14 | #12 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | mr k610. lol if u have no rest file dwnload the NEW REST unpack them. and if it still is not there flash ur fone all wil b ok. |
05-19-2007, 00:14 | #13 (permalink) |
Member: 306903 Status: Offline Thanks Meter: 19 | Yh simplest way is just flash the fone with appropriate flash files. ur fone will be alive again. and if u need more help abt ur problem then post the log here straightaway. then i can tell u the exact thingy. WBR, ALi |
05-19-2007, 07:45 | #14 (permalink) |
Member: 320134 Status: Offline Thanks Meter: 25 | v0.91380079/UNI Card serial:00005143 Loaded 51 flash descriptors SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701346445 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Flash ID check:2019 Flash props sent ok bypassing DB2020 security... server step1 error:10054 unlock failed, that is fatal Elapsed:20 secs. plz help me its urgent |
05-19-2007, 07:49 | #15 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
for arabic furious users here pdf explan how to unlock LG-C1100 | fonec | FuriouS II | 3 | 02-18-2018 15:27 |
how to unlock db2020 with this v0.914029 ?? | ServiceTEL | SETool2 | 2 | 05-13-2008 17:35 |
How To Unlock Db2020 With Setool | smkazim | Sony Ericsson | 3 | 05-24-2007 01:53 |
Please Explane How To Unlock K510 whit Semc | Tilka | Sony Ericsson | 0 | 05-23-2007 09:29 |
please explane how to flash cdma in ufs,jaf of griffin | CHAPRAN | Nokia CDMA | 1 | 05-05-2006 11:30 |
