please help me unlock my X10i itry to unlock x10I i have alwys this error WARMING UP ... GETTING ROOT ACCESS ... can't get ROOT rights Unlock FAILED Elapsed: 124 secs. i instal adb driver from pc companion from sonyericsson i dsactiveted the firwell an antivirus but still same error pleeeeease help me |
mr skytelecom i update the firmwire 2 time and same error |
reinstall ADB driver, or use other pc then unlock again. driver conflict!! wbr, setool_helper |
http://www.4shared.com/file/nb76omT4/semc_hsusb_device.html good look. Br, div_859 |
@ourgh: GETTING ROOT ACCESS ... Your SE X10i, is root or no? Please, root your phone, and try unlock. How root, go link: [Tutorial] Rooting the X10 and removing apps - xda-developers BR, cod3r |
trying to unlock xperia X10i with setool but showing error, please help.. RUNNING v 1.1436/01.15/UNI CARD SERIAL 00184482 USBFLASH DRIVER VERSION 03.02.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... \\.\EPIUSB1 \\?\USB#VID_0FCE&PID_ADDE#5&1c975dd7&0 &3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} RUNNING S1_EROM VER "R8A013" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 [ llcomm: 00010000,00080000 ] DEVICE ID: 9CA68DA9116B87A38D6BED62408D637AB441A527 FLASH ID: "002C/00B3" LOADER VERSION: R4A024 PHONE IMEI : 359419031***** Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAVE ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... Access violation at address 0055E647 in module 'Setool2g.exe'. Read of address 00000000 Unlock FAILED Elapsed: 54 seconds |
1. make sure you have firmware with android 2.x, NOT 1.6. flash required firmware, if needed. 2. power on phone without sim card, go to menu->settings->applications->development, enable "usb debugging" connect phone to PC, install drivers from setool2 distr ( drivers\ADB_Drivers) hint: i suggest to import DisableADBNumbering.reg (DisableADBNumbering.zip) , however that is not required. 3. select proper phone model. select USB as interface on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset press unlock when prompted, detach phone, turn it on fully, connect it again. ( or you can leave phone on cable, then power it on manually ) when program tells "warming up...", manually power on phone fully, cause it will automatically enter charging mode. after you see "GETTING ROOT ACCESS ..." DO NOT TOUCH PHONE until procedure complete. DO NOT DETACH PHONE FROM CABLE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE. DO NOT REMOVE BATTERY FROM PHONE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE. SUCH KILLED PHONES CAN BE REPAIRED WITH RESURRECTION CABLES. possible problems: you getting "err: 00000005","err: 00000002" during process. solution: disable antivirus, especially if you using "koshmarsky antivirus", i recommend Doctor Web do NOT run setool2 from restricted accounts. do NOT run setool2 from read-only media. problem: it can happen ( very unlikely, though ) that ADB server will not recognize phone after reboot solution: IF phone not detecting automatically and on status bar you can see "waiting for phone...", again - only in that case - disconnect phone from usb and connect it again, procedure should continue. if not, well, repeat from start. ------------------------------- ------------------------------ |
