Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 08-15-2011, 17:56   #1 (permalink)
Member: 1298112
Sonork: 100.1626550
Thanks Meter: 34
please help me unlock my X10i
itry to unlock x10I i have alwys this error
WARMING UP ...
GETTING ROOT ACCESS ...
can't get ROOT rights
Unlock FAILED
Elapsed: 124 secs.
i instal adb driver from pc companion from sonyericsson
i dsactiveted the firwell an antivirus but still same error
pleeeeease help me
Old 08-15-2011, 18:02   #2 (permalink)
skytelecom's Avatar
Member: 1074229
Sonork: 100.1605299
Thanks Meter: 62
WARMING UP ...
Unlock FAILED
Elapsed: 124 secs.
pleeeeease help me
update ur phone firmware / try another pc
Old 08-16-2011, 03:07   #3 (permalink)
Member: 1298112
Sonork: 100.1626550
Thanks Meter: 34
mr skytelecom i update the firmwire 2 time and same error
Old 08-16-2011, 03:29   #4 (permalink)
Member: 1597873
Thanks Meter: 168
reinstall ADB driver, or use other pc then unlock again.
driver conflict!!
wbr,
setool_helper
Old 08-16-2011, 03:42   #5 (permalink)
Member: 307373
Sonork: paypal.me/div859
Thanks Meter: 582
WARMING UP ...
Unlock FAILED
Elapsed: 124 secs.
pleeeeease help me
instal the correct driver uploaded here for you
http://www.4shared.com/file/nb76omT4/semc_hsusb_device.html
good look.
Br,
div_859
Old 08-16-2011, 04:44   #6 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 114
@ourgh: GETTING ROOT ACCESS ...
Your SE X10i, is root or no? Please, root your phone, and try unlock.
How root, go link:
[Tutorial] Rooting the X10 and removing apps - xda-developers
BR,
cod3r
Old 05-16-2020, 13:41   #7 (permalink)
Member: 2406539
Thanks Meter: 41
trying to unlock xperia X10i with setool but showing error, please help..
RUNNING v 1.1436/01.15/UNI
CARD SERIAL 00184482
USBFLASH DRIVER VERSION 03.02.00.00
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110010000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
\\.\EPIUSB1
\\?\USB#VID_0FCE&amp;PID_ADDE#5&amp;1c975dd7&amp;0 &amp;3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
RUNNING S1_EROM VER "R8A013"
EROM_AID : 0001
LOADER_AID : 0001
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
[ llcomm: 00010000,00080000 ]
DEVICE ID: 9CA68DA9116B87A38D6BED62408D637AB441A527
FLASH ID: "002C/00B3"
LOADER VERSION: R4A024
PHONE IMEI : 359419031*****
Checking for signature ...
signature found, skipping calculation
REMOVE SIM CARD FROM PHONE
FULLY POWER ON PHONE
ENABLE "USB DEBUGGING" IN PHONE:
MENU,SETTINGS,APPLICATIONS,DEVELOPMENT
INSTALL ADB DRIVERS IF NEEDED
MAKE SURE PHONE HAVE ANDROID 2.x FIRMWARE
WARMING UP ...
Access violation at address 0055E647 in module 'Setool2g.exe'. Read of address 00000000
Unlock FAILED
Elapsed: 54 seconds
Old 05-24-2020, 21:13   #8 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 835
CFG:110010000000
\\.\EPIUSB1
EROM_AID : 0001
LOADER_AID : 0001
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
WARMING UP ...
Unlock FAILED
Elapsed: 54 seconds
Here is procedure.
1.
make sure you have firmware with android 2.x, NOT 1.6.
flash required firmware, if needed.
2.
power on phone without sim card, go to menu->settings->applications->development, enable "usb debugging"
connect phone to PC, install drivers from setool2 distr ( drivers\ADB_Drivers)
hint:
i suggest to import DisableADBNumbering.reg (DisableADBNumbering.zip) , however that is not required.
3.
select proper phone model.
select USB as interface
on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset
press unlock
when prompted, detach phone, turn it on fully, connect it again.
( or you can leave phone on cable, then power it on manually )
when program tells "warming up...", manually power on phone fully, cause it will automatically enter charging mode.
after you see "GETTING ROOT ACCESS ..." DO NOT TOUCH PHONE until procedure complete.
DO NOT DETACH PHONE FROM CABLE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE.
DO NOT REMOVE BATTERY FROM PHONE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE.
SUCH KILLED PHONES CAN BE REPAIRED WITH RESURRECTION CABLES.
possible problems:
you getting "err: 00000005","err: 00000002" during process.
solution:
disable antivirus, especially if you using "koshmarsky antivirus", i recommend Doctor Web
do NOT run setool2 from restricted accounts.
do NOT run setool2 from read-only media.
problem:
it can happen ( very unlikely, though ) that ADB server will not recognize phone after reboot
solution:
IF phone not detecting automatically and on status bar you can see "waiting for phone...", again - only in that case - disconnect phone from usb and connect it again, procedure should continue.
if not, well, repeat from start.
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 11-23-2017 07:11
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 13:52
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 18:04
Page generated in 0.23446 seconds with 8 queries
