02-24-2011, 20:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: on the earth
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | please help z610 i wanted unlock it but i have made wrong way and now i have this message how can i flash it again RUNNING v 1.09/UNI USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 FLASH ID: 897E OTP LOCKED:1 CID:49 PAF:1 IMEI:35283601521170 CERT:RED ACTIVE CID:49 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 7 secs. setool3 may be the GDFS dead how can i restore it i thank you |
02-24-2011, 20:22 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Surely (almost) the restore file is not present so flash the main (settings: signed mode), the phone should be ok make the restore file run the executor in the phone(games folder), (don't worry) unlock again (setting only: altbypass ) follow setool directives |
The Following User Says Thank You to :Aishur: For This Useful Post: |
02-24-2011, 20:31 | #4 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | post the unlocking log %setool%\logs or search in that folder for the file with this text 35283601521170 |
02-24-2011, 20:39 | #5 (permalink) |
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:35283601521170 ACTIVE CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E No situable fsloader found, exiting Unlock FAILED Elapsed: 39 secs. |
02-24-2011, 20:54 | #7 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | I checked the support cid49/51/52 files are removed, so use the reset procedure and use this erom setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw to convert it to cid53 after full flash with cid53 firmware (signed mode - customize phone after flash) suggested firmware R1KH001_1250546_GENERIC_MY.ssw R1KH001_FS_EUROPE_2_MY_RED_CID53.SOFTWARE or post your log, we will upload cid49 firmware (main) |
02-24-2011, 20:58 | #8 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | go to empty board and repair tab settings uncheck all add to firmware area setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw fpress lash see the firmware suggestion in the previous post and make a full flash phone should be working and UNLOCKED |
02-24-2011, 21:43 | #9 (permalink) |
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | i have select setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw and flash then full fasl with firmware R1KH001_1250546_GENERIC_MY.ssw R1KH001_FS_EUROPE_2_MY_RED_CID53.SOFTWARE then i got logo PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 OTP LOCKED:1 CID:49 PAF:1 IMEI:35283601521170 CERT:RED ACTIVE CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "D:\SE\setool 3\flash\201020\z610\R1KH001_1250546_GENERIC_MY.ssw " CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 12 secs. |
02-25-2011, 14:24 | #12 (permalink) | ||
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Quote:
The SET is CID 49 Quote:
The FILES is CID53 thats why you got ERROR DO RESET PROCEDURE AGAIN,,, FLASH GDFS@EROMS On EMPTY FILL REPAIR TAB w/this EROMS(DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw) Then FLASH AGAIN MAIN@FS w/CID53 FILES and SIGNMODE@CUSTOMIZED on SETTINGS DONE Br,. Rhyan777 | ||
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
