11-27-2008, 08:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | sonyericsson tm506 unlock done CARD SERIAL: xxxxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602201386 CERT:RED LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 DEVICE KEY:938F01A2FD077E084D61BA1D27DEEB5F LDR:2008-07-23 11:57 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A065 LDR:2008-07-23 11:57 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A065 GOT SEED:1E5129BF3480046B25A02A31 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602201386 CERT:BROWN LDR:2008-07-23 11:59 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 65 LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "20831584" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock DONE Elapsed: 62 secs. tm506 unlock done |
The Following 21 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
11-28-2008, 17:46 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | v0.915020/UNI CARD SERIAL: 00010990 Loaded 51 flash descriptors ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302235394 CERT:RED LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 Model:TM506 MAPP CXC article: R3CA033 prg12033655_TMOUS_BL MAPP CXC version: R3CA033 Language Package:TMO-US CDA article: 1207-2630 CDA version: R28A Default article: 1203-3659 Default version: R3CA033 PROVIDER: 000-00 Network LOCKED Elapsed: 100 secs. ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302235394 CERT:RED LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA USERCODE RESET TO "0000" phone detached Elapsed: 15 secs. ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302235394 CERT:RED LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 Model:TM506 MAPP CXC article: R3CA033 prg12033655_TMOUS_BL MAPP CXC version: R3CA033 Language Package:TMO-US CDA article: 1207-2630 CDA version: R28A Default article: 1203-3659 Default version: R3CA033 PROVIDER: 000-00 Network LOCKED Elapsed: 12 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302235394 CERT:RED LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 DEVICE KEY:F2C645FCD9F7AFB287057420FE884A19 (1) LDR:2008-07-23 11:57 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A065 LDR:2008-07-23 11:57 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A065 GOT SEED:7F7A5C723480777225207839 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302235394 CERT:BROWN LDR:2008-07-23 11:59 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 65 LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "31765571" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock DONE Elapsed: 54 secs. successfully unlock |
The Following 12 Users Say Thank You to amanvir For This Useful Post: |
12-10-2008, 15:33 | #5 (permalink) |
Freak Poster Join Date: Mar 2005 Location: GsmFather.Com Age: 54
Member: 124069 Status: Offline Thanks Meter: 59 | world no 1 se tool tm 506 se tool 1000% unlock don Last edited by aftab70; 12-10-2008 at 15:43. |
The Following 4 Users Say Thank You to aftab70 For This Useful Post: |
12-17-2008, 19:54 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | I did mine by selecting w910 as model and preloader security bypass and all well done. Regards |
The Following 3 Users Say Thank You to .:==di@bila==:. For This Useful Post: |
12-23-2008, 08:24 | #9 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skype:[email protected] Age: 38
Member: 469651 Status: Offline Sonork: 100.1584040 Thanks Meter: 115 | tm 506 unlock 100% don se tool but emergency calls only pls help me |
The Following User Says Thank You to imran qma For This Useful Post: |
12-23-2008, 17:51 | #10 (permalink) |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | After i unlock mine,, i got the same problem bro but solved by factory setting with simcard inside. All done, but didnt take all operator and that is due to our network operator. Means, must of sonyericson phone doesnt take all network before 2 to 3week. GHood Luck regards. |
The Following User Says Thank You to .:==di@bila==:. For This Useful Post: |
01-31-2009, 08:48 | #11 (permalink) |
Registered User Join Date: Mar 2008 Location: dhaka
Member: 733031 Status: Offline Sonork: +8801922544522 Thanks Meter: 166 | Sonyericsson tm506 unlock free setool SONYERICSSON TM506 UNLOCK FREE SETOOL [COLOR="Blue"]Model is not on the supported list so I tried to identify unit and I found out it uses db31xx loader so I assumed it is a A2 type phone so I tried it using w595 model (I think it doesn't matter what model to choose for A2 phones unlock the same)[/COLOR] |
The Following 3 Users Say Thank You to cyme01913 For This Useful Post: |
01-31-2009, 09:27 | #12 (permalink) |
Freak Poster Join Date: Nov 2008 Location: pakistan Age: 37
Member: 896397 Status: Offline Sonork: 100.1603751 Thanks Meter: 91 | Tm506 1/28/2009 5:31:01 PM v0.915030/UNI 1/28/2009 5:31:01 PM CARD SERIAL: xxxxxxxx 1/28/2009 5:31:01 PM Loaded 51 flash descriptors 1/28/2009 5:32:14 PM PROCEDURE WAS STOPPED BY USER 1/28/2009 5:32:14 PM Can't load ID loader ! 1/28/2009 5:32:14 PM Elapsed: 48 secs. 1/28/2009 5:32:22 PM ChipID:C900,EMP protocol:0401 1/28/2009 5:32:22 PM BOOTROM MODE DETECTED 1/28/2009 5:32:25 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302165819 CERT:RED 1/28/2009 5:32:26 PM LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 1/28/2009 5:32:28 PM LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 1/28/2009 5:32:28 PM 1/28/2009 5:32:28 PM Model:TM506 1/28/2009 5:32:29 PM MAPP CXC article: R3CA033 prg12033655_TMOUS_BL 1/28/2009 5:32:29 PM MAPP CXC version: R3CA033 1/28/2009 5:32:29 PM Language Package:TMO-US 1/28/2009 5:32:29 PM CDA article: 1207-2630 1/28/2009 5:32:29 PM CDA version: R28A 1/28/2009 5:32:29 PM Default article: 1203-3659 1/28/2009 5:32:29 PM Default version: R3CA033 1/28/2009 5:32:29 PM PROVIDER: 000-00 1/28/2009 5:32:29 PM Network LOCKED 1/28/2009 5:32:29 PM 1/28/2009 5:32:29 PM Elapsed: 13 secs 1/28/2009 5:43:59 PM SIGNED MODE (USING SERVER) 1/28/2009 5:43:59 PM ALTERNATIVE SECURITY BYPASS ENABLED. 1/28/2009 5:43:59 PM PRELOADER SECURITY BYPASS ENABLED. 1/28/2009 5:43:59 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 1/28/2009 5:44:07 PM ChipID:C900,EMP protocol:0401 1/28/2009 5:44:07 PM BOOTROM MODE DETECTED 1/28/2009 5:44:09 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302165819 CERT:RED 1/28/2009 5:44:13 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 1/28/2009 5:44:13 PM DEVICE KEY:646EEA1C3CDCF8625FBCF4A6059EB57F (1) 1/28/2009 5:44:14 PM LDR:2008-07-23 11:57 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A065 1/28/2009 5:44:15 PM LDR:2008-07-23 11:57 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A065 1/28/2009 5:44:19 PM GOT SEED:B28E50753480777225B07B28 1/28/2009 5:44:19 PM P96 AUTH PASSED 1/28/2009 5:44:20 PM RESETTING SECURITY TO FACTORY STATE... 1/28/2009 5:44:20 PM RESTARTING... 1/28/2009 5:44:20 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 1/28/2009 5:44:28 PM ChipID:C900,EMP protocol:0401 1/28/2009 5:44:28 PM BOOTROM MODE DETECTED 1/28/2009 5:44:30 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35698302165819 CERT:BROWN 1/28/2009 5:44:31 PM LDR:2008-07-23 11:59 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 65 1/28/2009 5:44:33 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 1/28/2009 5:44:33 PM WRITING SEMCBOOT... 1/28/2009 5:44:35 PM PREPARING SECURITY... 1/28/2009 5:44:35 PM WRITING CLEAR SIMLOCK UNITS... 1/28/2009 5:44:35 PM ALL UNLOCK/LOCK CODES SET TO "75466341" 1/28/2009 5:44:37 PM CHANGING DOMAIN TO "CURRENT" 1/28/2009 5:44:37 PM SIGNING... 1/28/2009 5:44:37 PM DEVICE KEY RESTORED 1/28/2009 5:44:37 PM Unlock DONE 1/28/2009 5:44:37 PM Elapsed: 38 secs. UNLOCK DONE 100% |
The Following User Says Thank You to road_hunter420 For This Useful Post: |
sonyericsson tm506 after unlock done vodafone sim | mohit_kripalu01 | SETool2 | 5 | 06-26-2010 08:07 |
sonyericsson tm506 unlock done | GsmSumonBd | SETool2 | 2 | 03-22-2010 09:46 |
Sonyericsson TM506 T-Mobile Usa unlocked ok | Unlocker AL | Cruiser Suite | 3 | 01-21-2009 15:56 |
Sonyericsson T250i unlock done with infinity box | Shohel_sst | Infinity-Box | 1 | 01-20-2009 14:29 |
@InfinitySupport: SonyEricsson R306 Unlock Done | yawarniazi | Infinity-Box | 13 | 11-22-2008 18:33 |
