12-25-2008, 16:33 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 144091 Status: Offline Thanks Meter: 73 | Pls help failed "go support" i tried this solution below but it didn't work 1. "%windir%\system32\drivers\etc\hosts" open this file using notepad 2. Add following two lines to bottom 216.246.35.78 setool.net 216.246.35.78 www.setool.net 3. Save the file 4. Click "Go Support" i need Z310 flash file so how could i have it? |
12-25-2008, 17:20 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | server log failed Brother, firstly If u have any browser (as like as safari, mozila etc) then plz remove it from pc then run clean up soft http://depositfiles.com/files/sigyyxmit then restart ur pc and after then plz install again any browser for ur pc. Then try to login server from soft. And i hope ur problem ill be solve. |
12-25-2008, 18:49 | #4 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | thanks for replies but no one work. I got the latest version and remove google crome, apply restore point, use clea-up soft and even manaul clean-up not one work. i tried the old Supporter it didn't work. Before it works fine even some complain they can't, now perhaps im the last one left...hehe. need help Setool Team. I need flash files from support very urgent. TIA |
i can't access "go support" option | shivashakthi | SETool2 | 3 | 02-01-2010 17:11 |
Plz Add "go Support" Button | meisam | DreamBox | 8 | 04-01-2008 20:01 |
Update ufs2 error message **** failed pls reconnectbox pls help me!!! | !!!TaaTTalTi!!! | UFS2 + UFS3-Tornadoflasher | 1 | 12-02-2003 06:31 |
R210S call failed problem pls help??? | proxy_gsm | VLSI, Conexant, Skyworks and Old Models | 4 | 10-11-2003 23:14 |
N620 Synchronization failed pls help??? | proxy_gsm | VLSI, Conexant, Skyworks and Old Models | 4 | 09-22-2003 08:42 |
