12-12-2008, 14:28 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Vienna
Member: 833567 Status: Offline Thanks Meter: 9 | Pls Help K610i dead after flash v0.915021/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors Open COM port OK Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 45 secs. Open COM port OK unknown ChipID (602), RETRY Can't load ID loader ! Elapsed: 10 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED Model:K610i Brand:One MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package:EUROPE_2 CDA article: CDA102497/105 CDA version: R1A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 232-05 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 17 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing security... server step1 error:No server found. unlock failed, that is fatal Elapsed: 67 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok bypassing security... server step1 error:No server found. unlock failed, that is fatal Elapsed: 67 secs. Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 48 secs. Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 24 secs. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED Model:K610i Brand:One MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package:EUROPE_2 CDA article: CDA102497/105 CDA version: R1A Default article: cxc1250376 Default version: R1CB001 PROVIDER: 232-05 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 18 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM45 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 183 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit PROCEDURE WAS STOPPED BY USER Elapsed: 79 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 34 secs. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok phone CID not supported in that mode Elapsed: 5 secs. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 46 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 9 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. FAILED TO SETUP PHONE PROCEDURE WAS STOPPED BY USER Elapsed: 9 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED payload block 57 NAK Elapsed: 50 secs. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 36 secs. |
12-12-2008, 15:26 | #2 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | v0.915021/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 28 secs. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED no ack during gdfs_readvar ! Can't read SCRC unit Elapsed: 38 secs. FAILED TO SETUP PHONE PROCEDURE WAS STOPPED BY USER Elapsed: 2 secs. SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:115200 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901767208 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 9 secs. |
12-12-2008, 15:39 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Quote:
12-12-2008, 17:05 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | yah flash with cid49 main and fs files, select signed mode and complete phone after flash in settings and click on flash. every thing will be ok |
12-12-2008, 17:54 | #6 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: IRAN
Member: 828490 Status: Offline Thanks Meter: 229 | Quote:
The Following User Says Thank You to Reza.Ahmadi For This Useful Post: |
12-12-2008, 20:57 | #8 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | I have no ide by testpoint but i don,t know what i have fals done that the phone is dead that next time i don,t fall in the same problem?? and realy i have always problem with unlocking sony ericsson!! but for me very intersting to learn how to work with setool, it,s not easy like jaf or ust pro but it,s intersting i go reading the old and new post and learnig so. thanx for all who try to help me. |
12-13-2008, 09:05 | #9 (permalink) |
Member: 828490 Status: Offline Thanks Meter: 229 | for unlock DB2020 phones.use signed mode,compelet phone after flash and unlock after flash ticks and click unlock/repair. for unlock DB2010 phones:use copmlete phone after flash and unlock after flash ticks and click unlock/repair. and for more information,read F.A.Q http://forum.gsmhosting.com/vbb/showthread.php?t=528732 |
12-13-2008, 09:06 | #10 (permalink) |
12-14-2008, 20:14 | #12 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | 1. download from support fs & main cid 49 ~ 2.in setool soft select fs & main go to settings tab select signed mode and complet phone after flash in the end click flash......... |
The Following User Says Thank You to svchost For This Useful Post: |
PLs help w300 dead after unlock with se-tool | YasinŽ | Sony Ericsson | 2 | 06-07-2007 16:51 |
pls help me..!!6630 after flash phone start-up failer.contect the retailer | ahsam | Nokia Hardware & Hardware Repair | 12 | 05-26-2007 11:14 |
pls help E770V dead after unlock with smart | rolko_mobile | Motorola P2k | 8 | 08-30-2006 12:22 |
pls help E770V dead after unlock with smart | rolko_mobile | Motorola P2k | 1 | 08-26-2006 12:59 |
PLS HELP. blinking screen after flashing GD87 | popaz | Panasonic | 6 | 08-20-2003 16:47 |
