Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 10-15-2010, 13:28   #1 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
plz help me masters
ChipID:9900,EMP protocol:0301
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170701338584 CERT:N/A
FLASH CID:0 COLOR:N/A
IMEI MISMATCH ! GDFS IMEI:35170701616552
Model (from GDFS):K810i
Brand:Generic
MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM
MAPP CXC version: R1KC001
Language Package: EUROPE_4
CDA article: CDA111111/DEV
CDA version: R2A
Default article: cxc1250813
Default version: R1KC001
PROVIDER: MULTIPLE
Network LOCKED
Elapsed: 11 secs.
what happened to this k800 can someone solve this
Old 10-15-2010, 14:06   #2 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
showing FLASH CID:0 COLOR:N/A
Old 10-15-2010, 15:05   #3 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,437
Perform/resume the reset procedure
CID 50,51,52,53
that is so-called reset procedure.
1. go to emptyboard tab
2. select proper model
3. on settings, check "signed mode"
4. press recovery
5. after succeful recovery
6. on settings uncheck all
7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step
8. add to firmware area proper EROM (EROM CID >= OTP CID)
9. press flash
10. if needed,reflash phone on usual semc tab with needed settings.
The Following 2 Users Say Thank You to :Aishur: For This Useful Post:
Old 10-15-2010, 16:01   #4 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
can you provide me cid53 erom and gdfs plz
Old 10-15-2010, 17:43   #5 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
loader not responding when flashing fone what to do
Old 10-15-2010, 18:10   #6 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,437
GDFS
Setool\gdfs_in_ssw_format\db2020\K810_GDFS_SSW.ssw
EROM
Setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw
Post the log, mate
The Following User Says Thank You to :Aishur: For This Useful Post:
Old 10-16-2010, 08:36   #7 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
my problem is that phone is showing flash cid0 and colour n/a
i tried to flash or write gdfs it gives error about loader
Old 10-16-2010, 09:18   #8 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,437
Perform reset operation
LOG LOG LOG of the reset operations
Old 10-16-2010, 09:22   #9 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,437
Reset more detailled
2. select K810
4. press recovery
5. after successful recovery
6. on settings uncheck all and return to emptyfill tab and work on it
7. add to firmware area Setool\gdfs_in_ssw_format\db2020\K810_GDFS_SSW.ssw
8. add to firmware area proper Setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw
9. press flash
10. reflash phoneon usual semc tab with needed settings. and cid53 firmware
Old 10-16-2010, 17:19   #10 (permalink)
rana_jee's Avatar
Member: 290794
Thanks Meter: 31
recovery is done following log
RESET MODE STARTED
Speed:115200
RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
FLASH ID: 897E
GOT SEED:FFA2BEFB2180DB5D1580A952
P96 AUTH PASSED
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
Elapsed: 15 secs.
but when writing gdfs following error
SIGNED MODE (USING SERVER)
CFG:100000000000
Speed:115200
BYPASS FAILED.
Elapsed: 25 secs.
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.19501 seconds with 9 queries
