03-01-2009, 14:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | plz tell me how to chenge cid i face this problem my phone show ver cid52 r10ba015 red and i have cid53 r10ba015 red i try maney time flash but not sucsess plz help about this matter |
03-02-2009, 15:12 | #3 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Extract the attached files Put the first one into MISC field go to settings tick SIGNED MODE Back to SEMC select com port or UFS Press RECOVERY and connect the phone to COM or UFS Once process done, Fully power on the phone and identify again if not worked, try the second file ! BR Max_B |
03-10-2009, 05:10 | #5 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Land of Promise
Member: 659309 Status: Offline Thanks Meter: 121 | be sure have this file (DB2020_CID49_51_to_CID52_OLD) to convert your cid.. add to the miscfile tab and check setting signed mode then click the write script.. after its done try to identify and check the cid good luck.. |
03-10-2009, 05:13 | #6 (permalink) |
Junior Member Join Date: Mar 2009 Location: Mexico
Member: 990921 Status: Offline Sonork: cel_unlock_2009 Thanks Meter: 0 | i dont understand , can you explain what do you want to do ? if your phone is cid 53 or your phone is cid 52 whats the matter ?? may i can help ¡ |
12-30-2009, 16:45 | #8 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 289307 Status: Offline Thanks Meter: 44 | v0.915057/UNI CARD SERIAL: xxxxxxx Loaded 51 flash descriptors CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35160003383624 CERT:N/A FLASH CID:53 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS |
PLZ! tell me how to unlock NEC DB2000? | lovely_dash | NEC | 3 | 06-10-2007 16:39 |
PLZ! tell me how to unlock NEC DB2000? | lovely_dash | NEC | 1 | 06-06-2007 13:36 |
plz tell me how to use UFS-5 flashing software | avtarkaint | Nokia Hardware & Hardware Repair | 1 | 02-14-2007 04:34 |
plz tell me how to flash u 8180 plz | .::ricky rayya::. | LG | 1 | 05-01-2006 13:17 |
Anyone Plz tell me how to enter unlock Codes in C300 | DrMobile | Motorola ODM | 3 | 01-19-2006 14:15 |
