Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-11-2012, 08:10   #1 (permalink)
Member: 146480
plzzz help for unlock U5i Vivaz
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110010000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "GREEN" BUTTON ...
RUNNING S1_EROM VER "R8A017"
EROM_AID : 0001
LOADER_AID : 0004
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
SIMLOCK STATE: "NOT TAMPERED"
DEVICE ID: 89CCDF2E9177EC3C679B5AF1A3412EB290E6C088
FLASH ID: "0020/0040"
LOADER VERSION: "R4A048"
PHONE IMEI : 01245100******
ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE
Unlock FAILED
Elapsed: 16 secs.
All Update is ok
Please click on reader with setool2 SmartCard.
Ready to work
SmartCard update started...
CARD SERIAL: 00******
Checking with server.....
auth #0 err: [update not required]
Need solution
Old 06-11-2012, 08:31   #2 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Don't waste your your time and credits, your phone CAN NOT be unlocked by any box as it has loader aid_004.
Your only opportunity is to buy a code from network operator.
Old 06-11-2012, 10:23   #3 (permalink)
farhannyb's Avatar
Member: 762819
I think, it can be unlocked with Setool, but need 3 credits for unlocking ... Maybe, try ur luck.
Old 06-11-2012, 10:26   #4 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
farhannyb > Don't say stupid things, to unlock aid 004 s1 servers must be online, which has not be the case for the last year...
Trying will only lead to loose credits !
Old 06-12-2012, 19:18   #5 (permalink)
Member: 1679003
Sonork: ramon2012
good¡¡¡¡¡¡¡¡¡¡¡
I have friends I uffff logoso and SEtool3 but it fails when I do unlock repair the error is 144 that means that the server service is strong and we have to wait for me and the client almost killed me by the time we have endured .. aver if anyone is encouraged and we passed some concrete slucion ...
Old 06-12-2012, 19:29   #6 (permalink)
Member: 1679003
Sonork: ramon2012
check here friends..
RUNNING v 1.1286/01.15/UNI
CARD SERIAL 00092222
USBFLASH DRIVER VERSION 02.02.00.05
CFG:100010000000
EROM_AID : 0001
LOADER_AID : 0004
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
DEVICE ID: F70D41EE300392D16516989678D70EF3992A2036
FLASH ID: "00EC/0040"
PHONE IMEI : 01245100963212
Checking for signature ...
Waiting for calculation process ...
remote dongle not available
signature calculation not done,err: 144
Unlock FAILED
Elapsed: 22 secs.
Old 06-12-2012, 19:30   #7 (permalink)
Member: 1679003
Sonork: ramon2012
hellll pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 06-12-2012, 21:57   #8 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
What the hell don't you understand ????
AID 004 CAN NOT be unlocked !
How big must we write it ???
Old 06-12-2012, 22:03   #9 (permalink)
Member: 1679003
Sonork: ramon2012
jummmmmmmm
and your damn expression have to say on that page and use your answer is the same as you ..
Old 06-12-2012, 22:37   #10 (permalink)
Member: 1508616
CFG:100010000000
EROM_AID : 0001
LOADER_AID : 0004
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
Unlock FAILED
Elapsed: 22 secs.
Congratulations you have lost few credits without unlocking the mobile.
I have been asking for a better and clear user/credit management.
We all are NOT capable of using SETool (rocket science involved).
I takes few days/ages for you/me to master this device. Mean while practice, practice and practice !
You will not get any help from the team ...
except you will read like ...
* SETool is not for noobs
* Read before you ask (read all the manuals)
(@ramon obdulio me and you are in the same boat, hope some fine day @laser understands ...)
Old 06-12-2012, 23:17   #11 (permalink)
Member: 1624770
Don't waste your Time , your phone can not be unlocked by any box as it has loader aid_004
Old 06-13-2012, 08:10   #12 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
I'm sorry some people took offense about that but there is a simple thing I'd like to make clearer :
I made some mistakes when I began working with all boxes. That leaded me to a simple reflex : before unlocking a set I've never did before, I always use the search button to search if there are usual problems or particular things to do about it.
That is the correct behaviour, and not only with setool, which is of course one of the hardest to master, but with every box (i;e with z3x, reading post avoided me to brick i9000, with universal box I avoided to spend credits when it wasn't needed etc...).
In u5i case, there are I think one billion of threads regarding aid 004 problem, a simple search also, when you face issue with unlocking, gives you the answer in almost all the cases.
A notice should be given for all beginners, but as in everyday life, nobody reads the manual
Don't worry we all made mistakes (and still do sometimes), but before complaining try to understand what is wrong. That's a job that is not so easy, you have to learn everyday. And for one time you loose, you win a hundred times.
BR to all
Old 06-13-2012, 09:56   #13 (permalink)
:Aishur:'s Avatar
Member: 1315677
he had lost nothing, no a single credit is taken
For the aid0004, many threads already answered about it and lazy people still starting similiar thread like ths present one
noobs should learn about the jobs they are doing like i did
what is so heard to read below and to induct some questions
what are a1, a2, pda, odm, si s1 vi, s2 v2
which models are supported without server, which procedure i shoulsd use
which models are not supported dor unlock
if it is not supported, i should search before asking why.
etc....
it is clearly written that aid0004 is not supported
in short, use your brain to understand, ask intelligent questions
nobody will spoon-feeds lasy people.
Old 06-14-2012, 22:01   #14 (permalink)
KG-GSM's Avatar
Member: 352591
etc....
Ohhhhhhhhh , lets calm down, cause the real issue here is when this masters will but this server to work cause a long time ago we were able to do this models, and one day, simply server starts getting down for this models . Answers for this server problems already seen many, but noone reasonable. Only te ones that always says "yes" and "thanks" for everything this team do that don´t complaint what they do. But i thnk the ones that really works and want to work, and pay for updates with no complaitning, couse understand that we need to help the hard work of team must have the respect of them aswell, with good updates and server issues solved or trying to solve at least.
B.R. Karyn Guerra.
6303c can't read file for lbf .cpu not supported Agadir__Gsm BB5 Easy Service Tool (BEST) Nokia Dongle 6 06-26-2012 22:16
zte relince 3g mf190 unlock problem mmkhan1000 GSM / HSDPA Modems and Routers 1 06-11-2012 10:27
Need Help LT15i arafay67 SETool2 8 06-10-2012 13:28
LOOKING FOR Noika MCU&PPM&DTF-4 ezz2003 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-14-2001 13:52
Page generated in 0.36329 seconds with 11 queries
