Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-10-2012, 23:24   #1 (permalink)
boussoula's Avatar
Member: 425935
plzzz help for unlock xperia E10i
plzzzzz can any one tell me how unlock xperia E10i step by step
and how i know the firmeware for this phone
thank for u help
Old 06-11-2012, 00:21   #2 (permalink)
Ta@of!k's Avatar
Member: 1754434
Sonork: 100.1603928
thank for u help
Here is procedure.
1.
make sure you have firmware with android 2.x, NOT 1.6.
flash required firmware, if needed.
2.
power on phone without sim card, go to menu->settings->applications->development, enable "usb debugging"
connect phone to PC, install drivers from setool2 distr ( drivers\ADB_Drivers)
3.
select proper phone model.
select USB as interface
on settings check
signed mode, use alternative security bypass, do full unlock instead usercode reset
press unlock
when prompted, detach phone, turn it on fully, connect it again.
( or you can leave phone on cable, then power it on manually )
when program tells "warming up...", manually power on phone fully, cause it will automatically enter charging mode.
after you see "GETTING ROOT ACCESS ..."
DO NOT TOUCH PHONE until procedure complete.
DO NOT DETACH PHONE FROM CABLE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE.
DO NOT REMOVE BATTERY FROM PHONE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE.
SUCH KILLED PHONES CAN BE REPAIRED WITH RESURRECTION CABLES.
Asangsm team
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.20974 seconds with 11 queries
