08-24-2011, 11:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 362622 Status: Offline Thanks Meter: 43 | problem with j20i i have a problem with a j20i unlocking .sur i made a mistake now when i put the original simcard ( or a test card) it shows message insert a correct sim card is there any solution to resolve this problem please there is log RUNNING v 1.1101/01.11/UNI CARD SERIAL 00086618 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 credits consumption for full signature unlock: S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1106 SERVER CREDITS LEFT/USED: 20/10 CARD COUNTERS: FLASH 23, UNLOCK 257 Elapsed: 4 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01227300557012] OTP LOCKED:1 CID:81 PAF:1 IMEI:01227300557012 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01227300557012 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100011000000 SERVER CREDITS LEFT/USED: 15/15 CARD COUNTERS: FLASH 23, UNLOCK 257 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01227300557012 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 01227300557012 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 758 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01227300557012 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):J20i MAPP CXC article: R7CA061 prg1231-9304_GENERIC_SY MAPP CXC version: R7CA061 Language Package: FRANCE CDA article: 1233-5753 CDA version: R9A Default article: 1231-9366 Default version: R7CA061 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 11 secs. |
08-26-2011, 18:54 | #2 (permalink) |
Member: 362622 Status: Offline Thanks Meter: 43 | please bro any help for my j20 i m desasperate with it it doesnt accept any simcard even original and when i want unlock it with bypass ticked i have this message ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE thanks |
08-26-2011, 19:25 | #3 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | first reflash your phone, then try to unlock with correct settings (1+5+6 I guess) |
The Following User Says Thank You to cycofcgb For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
