04-06-2009, 16:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Algeria
Member: 218246 Status: Offline Thanks Meter: 58 | problem with setool I have a small problem with setool when I like to unlock T303 it's give me this error: v0.915034/UNI CARD SERIAL: 00067900 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) SERVER CREDITS LEFT/USED: 28/2 CARD COUNTERS: FLASH 226, UNLOCK 15 Elapsed: 5 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35899402595398 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" Checking for EROM signature... Waiting for calculation process... remote dongle daylimit reached signature calculation not done,err: 144 Elapsed: 15 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:3589940xxxxxxx MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" Checking for EROM signature... Waiting for calculation process... remote dongle daylimit reached signature calculation not done,err: 144 Elapsed: 21 secs. If there is any body have any idea please where is the problem.......Thinks |
04-06-2009, 19:16 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: lebanon Age: 49
Member: 141363 Status: Offline Sonork: 100.1594362 Thanks Meter: 148 | flash full flash the phone and i try need to unlock it and the phne is dead i flash it and now is locked i try 2nd time same 1st plz help me here the log SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35342701397314 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM103 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 154 secs. |
04-06-2009, 20:25 | #5 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
u must flash ur phone firstly to power on, then unlock it if old security if new security use seking server its support s1 unlock server setool is down b.r toutou_gsm | |
problem with setool and k608i red49 | kemel | SETool2 | 13 | 04-08-2008 22:31 |
cid 52 unlock problem with setool | beni b | Sony Ericsson | 8 | 11-16-2007 01:23 |
w850 unlock problem with setools 3 | whiteribbon | SETool2 | 30 | 09-25-2007 11:20 |
w550i problem with setool | .:LOCK UNLOCK:. | SETool2 | 1 | 10-22-2006 22:03 |
Problem with SETool and IMEI with w550 | Bohosh | Sony Ericsson | 4 | 01-14-2006 10:57 |
