07-31-2009, 14:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: algeria
Member: 816596 Status: Offline Sonork: zinnou Thanks Meter: 14 | problem unlock sony ericsson s500i CARD SERIAL: 00****** Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297202470221 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed file block NAK,err:0003 Can't write file to filesystem DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM23 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 60 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297202470221 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed file block NAK,err:0003 Can't write file to filesystem DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM23 PHONE READY TO PROCEED There is NO EXECUTOR in phone ! Elapsed: 76 secs. |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
problem Unlock Sony Ericsson G900 | AOYUE | Cruiser Suite | 0 | 10-27-2009 18:57 |
sony ericsson s500i fonts problem | ponetec | Sony Ericsson | 5 | 03-24-2009 10:02 |
problem unlock sony ericsson j110i | hosnisat | Infinity-Box | 2 | 01-17-2008 19:59 |
Unlock Sony Ericsson s500i?? | vraptor | Phone Unlocking Codes & Maps | 0 | 01-16-2008 19:46 |
