05-02-2011, 09:13 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | r306 flashing problem RUNNING v 1.10/UNI CARD SERIAL 00158227 USBFLASH DRIVER VERSION 02.02.00.05 Found 5 FTDI device(s). UFS #71259 READY SIGNED MODE (USING SERVER) CFG:100111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 6 secs. Found 5 FTDI device(s). UFS #71259 READY SIGNED MODE (USING SERVER) CFG:100111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 5 secs. CFG:000111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 73 secs. CFG:000111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 25 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 10 secs. CFG:000111000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 45 secs. CFG:001010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 54 secs. CFG:001010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 33 secs. CFG:001010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 181 secs. CFG:001010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 37 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 5 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 94 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 85 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 20 secs. CFG:001000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 19 secs. CFG:001000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 19 secs. CFG:001000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected Can't load ID loader ! Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:101110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 45 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 29 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 17 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 19 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 16 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... error #1 not received FAILED TO SETUP PHONE Elapsed: 11 secs. CFG:001110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 15 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 33 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 10 secs. CFG:001100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 300 secs. CFG:001100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 31 secs. CFG:001100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 19 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 40 secs. CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 37 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:010000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 44 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:010000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 248 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:010000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls CRC error at 07F80000 Can't create RAM TA image FAILED TO SETUP PHONE Elapsed: 19 secs. what is this problem why this set not flash, it is hang on sony logo after that white screen come is it repairble by flashing or not ? |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
