01-12-2013, 10:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | R800 play not getting unlock ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000010 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... qcReceivePacket: can't get packet data. FAILED TO SETUP PHONE Unlock FAILED this err showing with test point |
01-12-2013, 17:52 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 45
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | New phone with security bug fixed, no way to unlock these phones by software at this time more info here. HOW TO WORK WITH SEMC PDA PHONES - Page 2 BR |
The Following User Says Thank You to mbcommunication For This Useful Post: |
01-13-2013, 13:15 | #7 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | if you sure that you did testpoint properly and did testpoint procedure properly, then phone have mcu with fixed security bug and you can't unlock phone using any known 3rd-party tools. however, this is very strange, as r800 is quite old phone to use mcu's with fixed security. and from error text it is likely NOT your case. i remeber that i had similar problem with r800 on one PC, it was because of usb port incompatibility and it can be fixed using two ways : - change usb port to different one, preferable port, connected directly to motherboard or to externally powered usb hub - disabled USB 2.0 mode in PC BIOS for port, which was used for unlock |
The Following User Says Thank You to the_laser For This Useful Post: |
01-14-2013, 18:09 | #12 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | disable usb 2.0 mode in pc bios. use short usb cable connect short usb cable directly to motherboard rear ports, not to case connectors. if this will not help sorry, i can not help you more. |
